Issue login in with the desktop client when using SSO (SAML with Keycloak)
We run a Nectcloud instance on Hetzner and using Keycloak ID server witch allows SSO with SAML.
On the browser everything works great, but we can’t login into Nextcloud with the Desktop Client.
Android Client works too, but with the Desktop client the process stucks when I want to give Acces to the files.
grafik
The client shows then this state forever. The same siutation is when I using the app token instead of password. When I look in my settings I see there both Desktop and Android client are connected properly, so I assume the error is neither at the server or the Keycloak side. It must be a Desktop Client issue.
I have installed client Windows version: Version 2.5.1final (build 20181204).
And Ubuntu ppa version 2.5.1. It is the same issue.
Nextcloud Version is: Nextcloud 15.0.2
I’m having the exact same problem +1
SAML on Azure.
same problem here
I have posted an issue on Github: https://github.com/nextcloud/desktop/issues/1084
when i try to connect via NC Desktop Client (V2.5.1) and SSO & SAML Login, I get the following error message.
is that a bug?
In The previous NC Dektop Client Version 2.3.3.1 the Login-Window for user ad PW Authentication was not shown at all, just a “White Screen”.
Guys, any workaround of this issue, i am facing the same problem.
The usual way to enable app access is by setting-up individual app passwords, because they will
work wothout a 2FA dialog. Check-out Settings->Personal->Security->Devices and Sessions.
now its stuck on this screen
stuck
As far as I remember different ways to authenticate should be displayed.Choose user/password
and directly enter the account details instead of using this simplified authentication.
We have disabled all other login options other them SSO.
@j-ed if you read the issue carefully, you see that the same issue occurs with app token. O do you mean something else with “individual app passwords”.
I have in mind that “Grant access” is only shown if the simplified way of authentication has been selected, which means you enter you’ve already logged in via your web browser and want to create
a new app token on the fly.
If you’ve created an app token manually and want to use it, you have to choose alternative login via app token first
20190225_nc_client-1
and enter the login and app token in a second step.
20190225_nc_client-2
I’ve just logged-out and in by going that way on my PC and it worked like a charme and without any problem.
@j-ed it is also not working. i have already mentioned in previous post
Due to the fact that there is always room for misunderstanding it is always better to asked twice :wink:
Have you tried to start the Nextcloud client from the command line providing the “–logwindow” command line switch? Maybe it prints-out valuable information about the root cause of the problem.
20190225_nc_client-3
  • Is it necessary to upgrade to NC Server V15 to get the SSO Service work properly for NC Desktop Client V2.5.1 or should it also work with NC Server V13?
  • in our case we still stuck after putting the login credentionals in the Microsoft ADFS Login screen the Token is not accepted. that SSO service still works with many other SSO Applikations.
  • With NC Desktop Client V2.3.3.1 the ADFS Credential Login Page does not appear and we just see a whitescreen.
  • Could someone provide me please with the necessary structure of the NC Desktop Client Webtoken - How has the NC Desktop client “claim rule” must look like?? - maybe that´s why the Webtoken is not provided
THX all!
InkedSSO_Login_failed_2_2
Logs
I don’t get any logs, because the client is not yet running.
1. Web server error log:
   not accessible
2. Server logfile: nextcloud log (data/nextcloud.log):
   No server logs
Maybe it helps to speed this up if some of you, enter their feedback in the related Github issue.
Please provide the necessary enviroment infos there. Server/Desktop version. SSO server type aso.
I’m not meant the logging of the server, but the logging of the Nextcloud desktop client. It start logging what it is doing right after you’re starting it. So it might be possible that he helps to understand why it could login. Example
|[OCC::FolderMan::setupFolders |Setup folders from settings file|
|[OCC::defaultJournalMode |Detected filesystem "NTFS" for "C:/Users/<user>/Nextcloud/._sync_4bc7bcd5f0e.db"|
|[OCC::ConfigFile::setupDefaultExcludeFilePaths |Adding user defined ignore list to csync: "C:/Users/<user>/AppData/Roaming/Nextcloud/sync-exclude.lst"|
|[OCC::FolderMan::addFolderInternal |Adding folder to Folder Map  OCC::Folder(0x1bd7b2f8660) "1"|
|[OCC::FolderMan::scheduleFolder |Schedule folder  "1"  to sync!|
|[OCC::FolderMan::scheduleFolder |Folder is not ready to sync, not scheduled!|
|[OCC::ownCloudGui::slotSyncStateChange |Sync state changed for folder  "https://<nextcloud--server-fqdn>/remote.php/webdav/" :  "Not yet Started"|
|[OCC::SyncJournalDb::checkConnect |sqlite3 version "3.24.0"|
|[OCC::SyncJournalDb::checkConnect |sqlite3 journal_mode= "wal"|
|[OCC::ClientProxy::setupQtProxyFromConfig |Set proxy configuration to use NO proxy|
|[OCC::WebFlowCredentials::fetchFromKeychain |Fetch from keyhchain!|
|[OCC::SocketApi::slotNewConnection |New connection QLocalSocket(0x1bd7b223430)|
|[OCC::SocketApi::slotNewConnection |New connection QLocalSocket(0x1bd7b222790)|
|[OCC::SocketApi::slotNewConnection |New connection QLocalSocket(0x1bd7b222c50)|
|[OCC::AccountState::slotCredentialsFetched |Fetched credentials for "https://<nextcloud-server-fqdn>" attempting to connect|
|[OCC::WebFlowCredentials::createQNAM |Get QNAM|
|[OCC::AccessManager::createRequest |2 "" "https://<nextcloud-server-fqdn>/status.php" has X-Request-ID "8178d6b2-3222-4c0c-b8dd-9742dcbd6e27"|
|[OCC::AbstractNetworkJob::start |OCC::CheckServerJob created for "https:/</nextcloud-server-fqdn>" + "status.php" "OCC::ConnectionValidator"|
|[OCC::WebFlowCredentials::slotFinished |request finished|
|[OCC::WebFlowCredentials::stillValid |Still valid?|
Here are client logs
OCC::PropfindJob::finished not successful, http result code is 302 “https://mync.xxxxx.co/index.php/apps/user_saml/saml/selectUserBackEnd?redirectUrl=”
[OCC::OwmyncSetupWizard::slotAuthError Authed request was redirected to “https://mync.xxxxx.co/index.php/apps/user_saml/saml/selectUserBackEnd?redirectUrl=”
[OCC::WebViewPageUrlSchemeHandler::requestStarted Got user: “YMudasar” , server: “https://mync.xxxxx.co”
[OCC::WebViewPage::urlCatched Got user: “YMudasar” , server: “https://mync.xxxxx.co”
[OCC::WebViewPage::urlCatched URL: “https://mync.xxxxx.co”
[OCC::OwmyncSetupWizard::slotConnectToOCUrl Connect to url: “https://mync.xxxxx.co”
[OCC::WebFlowCredentials::createQNAM Get QNAM
[OCC::AccessManager::createRequest 6 “PROPFIND” “https://mync.xxxxx.co/remote.php/webdav/” has X-Request-ID “xxxxx-6ac2-4efd-9147-xxxxxxx”
[OCC::AbstractNetworkJob::start OCC::PropfindJob created for “https://mync.xxxxx.co” + “/” “OCC::OwmyncSetupWizard”
[OCC::WebFlowCredentials::slotFinished request finished
[OCC::WebFlowCredentials::stillValid Still valid?
[OCC::WebFlowCredentials::stillValid QNetworkReply::NetworkError(NoError)
[OCC::WebFlowCredentials::stillValid “Unknown error”
The only thing which catches my attention is the mixed writing of the login name “YMudasar”.
I don’t know if this has any effect in this case but it might be worse to test a login with only lowercase
characters or similar how the user has been created…
The ""Unknown error" at the end of the log seems also be no real error because I can see it
in my log file too, although I’m using a normal login/password authentication for the desktop client
app authentication.
