Integrated OnlyOffice with one click. How?
Really excited to upgrade to nextcloud Hub from 17 - mainly because of the integrated OnlyOffice suite.
But can’t find it anywhere in the app store and don’t have the option to create documents in files. Any clues?
The old Only Office connector is still there, but that’s it…
plus the related posts about issues on github according this feature. forum search will help.
Thanks Reiner_Nippes.
The only problem now is that the thing won’t download. It always times out after 30 seconds with less than 100mb downloaded.
cURL error 28: Operation timed out after 30000 milliseconds with 73216548 out of 305969549 bytes received (see http://curl.haxx.se/libcurl/c/libcurl-errors.html)
It’s happened 15 times now with data transferred varying from 30mb to 96mb
maybe you can use the search in the upper right corner? :face_with_monocle::wink:
well. it’s a known problem in the it world…
OK. Thanks chaps I’m not an IT professional, and your patience is appreciated- downloaded and enabled - then it disables itself
From the error log:
[no app in context] Error: Error: Class ‘OCA\Onlyoffice\AppConfig’ not found at <>
  1. /var/www/html/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
    OCA\DocumentServer\AppInfo\Application->OCA\DocumentServer\AppInfo{closure}("*** sensitive parameters replaced ***")
  2. /var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php line 113
    Pimple\Container->offsetGet(“OCA\DocumentSe … g”)
  3. /var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php line 408
    OC\AppFramework\Utility\SimpleContainer->query(“OCA\DocumentSe … g”)
  4. /var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php line 386
    OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\DocumentSe … g”)
  5. /var/www/html/apps/documentserver_community/lib/AppInfo/Application.php line 84
    OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\DocumentSe … g”)
  6. /var/www/html/apps/documentserver_community/lib/AppInfo/Application.php line 88
    OCA\DocumentServer\AppInfo\Application->getAutoConfig()
  7. /var/www/html/apps/documentserver_community/appinfo/app.php line 4
    OCA\DocumentServer\AppInfo\Application->register()
  8. /var/www/html/lib/private/legacy/app.php line 266
    require_once("/var/www/html/a … p")
  9. /var/www/html/lib/private/legacy/app.php line 155
    OC_App::requireAppFile(“documentserver_community”)
  10. /var/www/html/lib/private/legacy/app.php line 128
    OC_App::loadApp(“documentserver_community”)
  11. /var/www/html/lib/base.php line 993
    OC_App::loadApps()
  12. /var/www/html/index.php line 38
    OC::handleRequest()
No luck with the search :shushing_face::wink:
Install also the OnlyOffice App first
