Nextcloud version (eg, 20.0.5): 23.0.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.52
PHP version (eg, 7.4): 7.4
I had some physical problems with my bootdrive so I had to reinstall Ubuntu on a new drive.
I luckily had my documentation up to date so I was able to reinstall quickly and since i did backups of my mySQL database I was also able to restore the database without any dataloss (eg. calendar entrys or tasks) via https://docs.nextcloud.com/server/latest/admin_manual/maintenance/restore.html. So success there.
But i noticed that the system is responding pretty slowly compared to before. I DO have switched from an SSD to a HDD since it was available and performance was not a primary concern for my home installation. But it is so slow it even times out sometimes so clients (2 Desktops and 3 Android clients) get disconnected.
So i tried to dig a bit and i think this has sth. to do with database syncing:
iotop reports 99% usage by jdb2 for very long periods of time which seems kind of odd:
Total DISK READ: 0.00 B/s | Total DISK WRITE: 1435.99 K/s
TID to ionice:
TID PRIO USER DISK READ DISK WRITE SWAPIN IO> COMMAND
330 be/3 root 0.00 B/s 0.00 B/s 0.00 % 99.97 % [jbd2/sda2-8]
1196 be/4 mysql 0.00 B/s 0.00 B/s 0.00 % 22.90 % mysqld [ib_io_wr-3]
1204 be/4 mysql 0.00 B/s 0.00 B/s 0.00 % 14.94 % mysqld [ib_log_flush]
1198 be/4 mysql 0.00 B/s 360.88 K/s 0.00 % 12.00 % mysqld [ib_pg_flush_co]
1199 be/4 mysql 0.00 B/s 300.73 K/s 0.00 % 9.03 % mysqld [ib_pg_flush-1]
1201 be/4 mysql 0.00 B/s 240.59 K/s 0.00 % 6.98 % mysqld [ib_pg_flush-3]
1195 be/4 mysql 0.00 B/s 0.00 B/s 0.00 % 6.06 % mysqld [ib_io_wr-2]
1206 be/4 mysql 0.00 B/s 67.66 K/s 0.00 % 5.48 % mysqld [ib_log_writer]
3031 be/4 mysql 0.00 B/s 101.50 K/s 0.00 % 4.93 % mysqld [connection]
3253 be/4 mysql 0.00 B/s 48.87 K/s 0.00 % 4.53 % mysqld [connection]
1200 be/4 mysql 0.00 B/s 300.73 K/s 0.00 % 2.35 % mysqld [ib_pg_flush-2]
3252 be/4 mysql 0.00 B/s 15.04 K/s 0.00 % 1.83 % mysqld [connection]
This only happens when apache2 is running and the only site i am serving is nextcloud. And nextcloud is also the only database that i am running.
What throws me off a bit (besides the 99%) is that there is no DISK READ but so much DISK WRITE. If syncing is done from memory (I have setup as advised in https://docs.nextcloud.com/server/latest/admin_manual/installation/server_tuning.html, so e.g. caching is activated) i do not get why there should be that much DISK WRITE when actually nothing changed on any client …
Also there is enough RAM (16GB currently, will pull out 8GB soon since not needed), as also shown by top:
Tasks: 176 total, 1 running, 175 sleeping, 0 stopped, 0 zombie
%Cpu(s): 4,7 us, 1,2 sy, 0,0 ni, 66,4 id, 26,8 wa, 0,0 hi, 0,8 si, 0,0 st
MiB Mem : 15898,6 total, 10547,0 free, 1222,0 used, 4129,6 buff/cache
MiB Swap: 4096,0 total, 4096,0 free, 0,0 used. 14304,0 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1162 mysql 20 0 3874700 716056 38960 S 10,6 4,4 21:50.36 mysqld
3542 root 20 0 20236 14564 7324 S 6,3 0,1 11:34.31 iotop
2029 www-data 20 0 366900 80452 58840 S 1,7 0,5 0:51.32 php-fpm7.4
4709 www-data 20 0 364724 78088 58700 S 1,3 0,5 0:19.20 php-fpm7.4
890 redis 20 0 52748 5664 3624 S 0,7 0,0 0:52.65 redis-server
1045 www-data 20 0 2724104 26752 9408 S 0,7 0,2 0:50.33 apache2
2031 www-data 20 0 370800 87776 62340 S 0,7 0,5 0:50.14 php-fpm7.4
3037 www-data 20 0 360672 75800 59592 S 0,7 0,5 0:43.71 php-fpm7.4
4732 www-data 20 0 366456 78860 57656 S 0,7 0,5 0:17.21 php-fpm7.4
330 root 20 0 0 0 0 D 0,3 0,0 1:03.15 jbd2/sda2-8
1736 media 20 0 9248 3884 3236 R 0,3 0,0 0:53.59 top
2033 www-data 20 0 364740 78208 59752 S 0,3 0,5 0:52.25 php-fpm7.4
3034 www-data 20 0 381204 96068 60264 S 0,3 0,6 0:42.51 php-fpm7.4
3041 www-data 20 0 343488 63576 50592 S 0,3 0,4 0:42.20 php-fpm7.4
3535 www-data 20 0 366604 80004 58824 S 0,3 0,5 0:38.30 php-fpm7.4
4733 www-data 20 0 366744 78624 57212 S 0,3 0,5 0:18.91 php-fpm7.4
4734 www-data 20 0 348592 70012 53148 S 0,3 0,4 0:18.17 php-fpm7.4
i googled a bit and found this answer on serverfault.com: linux - High server load - [jbd2/md1-8] using 99.99% IO - Server Fault
So i enabled debug tracing and got the following output:
cat /sys/kernel/debug/tracing/trace_pipe
ib_pg_flush_co-1179 [003] .... 76909.482568: ext4_sync_file_enter: dev 8,2 ino 17967725 parent 17967302 datasync 0
jbd2/sda2-8-330 [001] .... 76909.510310: jbd2_commit_flushing: dev 8,2 transaction 6838369 sync 0
connection-107736 [003] .... 76909.510445: ext4_sync_file_enter: dev 8,2 ino 17964866 parent 17967302 datasync 1
ib_log_flush-1184 [003] .... 76909.512979: ext4_sync_file_enter: dev 8,2 ino 17967723 parent 17967302 datasync 0
jbd2/sda2-8-330 [001] .... 76909.581287: jbd2_commit_flushing: dev 8,2 transaction 6838370 sync 0
ib_io_wr-3-1177 [003] .... 76909.581615: ext4_sync_file_enter: dev 8,2 ino 17967730 parent 17967302 datasync 0
jbd2/sda2-8-330 [002] .... 76909.622985: jbd2_commit_flushing: dev 8,2 transaction 6838371 sync 0
ib_log_flush-1184 [001] .... 76909.623073: ext4_sync_file_enter: dev 8,2 ino 17967723 parent 17967302 datasync 0
connection-108343 [000] .... 76909.623334: ext4_sync_file_enter: dev 8,2 ino 17964866 parent 17967302 datasync 1
ib_log_flush-1184 [001] .... 76909.667207: ext4_sync_file_enter: dev 8,2 ino 17967723 parent 17967302 datasync 0
jbd2/sda2-8-330 [002] .... 76909.667207: jbd2_commit_flushing: dev 8,2 transaction 6838372 sync 0
connection-107736 [000] .... 76909.708276: ext4_sync_file_enter: dev 8,2 ino 17964866 parent 17967302 datasync 1
ib_log_flush-1184 [000] .... 76909.708397: ext4_sync_file_enter: dev 8,2 ino 17967723 parent 17967302 datasync 0
jbd2/sda2-8-330 [002] .... 76909.708574: jbd2_commit_flushing: dev 8,2 transaction 6838373 sync 0
I am not sure what to do now. I do not even undertand what i did with the debug there tbh.
I thought about build up a new nextcloud DB, Add the users manually, restore calendar and contacts from backups using the WebGUI and then rescan the data directory for the users to restore the “real” data. And then reshare the folders/files and alike. Would that help? Any other suggestions?
- mess up your bootdrive
- reinstall nextcloud on new drive
- recover database as shown in https://docs.nextcloud.com/server/latest/admin_manual/maintenance/restore.html
- get high I/O from jdb2
Fehler PHP Error: disk_free_space(): No such file or directory at /var/www/nextcloud/lib/private/Files/Storage/Local.php#381
2022-03-10T09:17:19+0100
2022-03-10T09:16:22+0100
Fehler PHP Error: dns_get_record(): A temporary server error occurred. at /var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php#83
2022-03-10T06:19:26+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 3696023 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T01:19:22+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 2513569 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T01:18:23+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 344796 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:49:22+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 175772 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:49:21+0100
2022-03-10T00:48:49+0100
2022-03-10T00:48:48+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 236349826 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 262144 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:22:45+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 334195014 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 311296 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:22:30+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 181701407 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 352256 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 334195014 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:22:21+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 181701407 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:22:20+0100
2022-03-10T00:21:42+0100
2022-03-10T00:21:41+0100
2022-03-10T00:21:07+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 50655641 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 344064 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:17:12+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 50655641 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2613248 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:15:32+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 50655641 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:15:25+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 50655641 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 376832 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:13:57+0100
2022-03-10T00:13:23+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 319507884 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 344064 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:09:58+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 319507884 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 466944 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:08:56+0100
Fehler no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 319507884 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 16580608 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
2022-03-10T00:08:55+0100
(note: probably caused by my testing, after a reboot and waiting 4h no new erros were logged while the problem still persisted)
cat /var/www/nextcloud/config/config.php
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => '***.ddns.net',
'datadirectory' => '/***/nextcloud',
'version' => '23.0.2.1',
'overwrite.cli.url' => 'https://***.ddns.net',
'overwritehost' => '***.ddns.net',
'default_language' => 'de',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 0,
'dbindex' => 0,
'loglevel' => '2',
'logfile' => '/var/log/nextcloud.log',
'dbname' => '***',
'dbhost' => 'localhost',
'dbuser' => '***',
'dbpassword' => '***',
cat /var/log/apache2/error.log
[Thu Mar 10 09:54:17.082584 2022] [proxy_fcgi:error] [pid 105342:tid 139834046785280] [client 192.168.2.13:55398] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 09:54:17.518283 2022] [mpm_event:notice] [pid 105331:tid 139834256768320] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 09:57:09.684708 2022] [mpm_event:notice] [pid 105608:tid 139820634340672] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 09:57:09.684738 2022] [core:notice] [pid 105608:tid 139820634340672] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 10:10:28.623686 2022] [proxy_fcgi:error] [pid 105610:tid 139820290074368] [client 192.168.2.6:54046] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:10:28.623723 2022] [proxy_fcgi:error] [pid 105610:tid 139820290074368] (104)Connection reset by peer: [client 192.168.2.6:54046] AH01075: Error dispatching request to :
[Thu Mar 10 10:10:28.625634 2022] [proxy_fcgi:error] [pid 105609:tid 139820357216000] [client 192.168.2.28:57736] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:10:28.625663 2022] [proxy_fcgi:error] [pid 105609:tid 139820357216000] (104)Connection reset by peer: [client 192.168.2.28:57736] AH01075: Error dispatching request to :
[Thu Mar 10 10:10:28.625785 2022] [proxy_fcgi:error] [pid 105610:tid 139820009502464] [client 192.168.2.12:48838] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:10:28.625794 2022] [proxy_fcgi:error] [pid 105610:tid 139820009502464] (104)Connection reset by peer: [client 192.168.2.12:48838] AH01075: Error dispatching request to :
[Thu Mar 10 10:10:28.627587 2022] [proxy_fcgi:error] [pid 105609:tid 139820298467072] [client 192.168.2.28:57668] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:10:28.627619 2022] [proxy_fcgi:error] [pid 105609:tid 139820298467072] (104)Connection reset by peer: [client 192.168.2.28:57668] AH01075: Error dispatching request to :
[Thu Mar 10 10:10:28.645197 2022] [proxy:error] [pid 105609:tid 139820298467072] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:10:28.645216 2022] [proxy_fcgi:error] [pid 105609:tid 139820298467072] [client 192.168.2.28:57668] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:10:28.650899 2022] [proxy:error] [pid 105609:tid 139820298467072] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:10:28.650913 2022] [proxy_fcgi:error] [pid 105609:tid 139820298467072] [client 192.168.2.28:57736] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:10:28.839540 2022] [mpm_event:notice] [pid 105608:tid 139820634340672] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 10:10:32.198739 2022] [core:warn] [pid 105608:tid 139820634340672] AH00045: child process 105610 still did not exit, sending a SIGTERM
[Thu Mar 10 10:10:34.200980 2022] [core:warn] [pid 105608:tid 139820634340672] AH00045: child process 105610 still did not exit, sending a SIGTERM
[Thu Mar 10 10:10:36.202750 2022] [core:warn] [pid 105608:tid 139820634340672] AH00045: child process 105610 still did not exit, sending a SIGTERM
[Thu Mar 10 10:10:38.204635 2022] [core:error] [pid 105608:tid 139820634340672] AH00046: child process 105610 still did not exit, sending a SIGKILL
[Thu Mar 10 10:10:39.261101 2022] [mpm_event:notice] [pid 107584:tid 139872587828544] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 10:10:39.261130 2022] [core:notice] [pid 107584:tid 139872587828544] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 10:21:34.086565 2022] [proxy_fcgi:error] [pid 107586:tid 139872327489280] [client 192.168.2.6:54070] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:21:34.086605 2022] [proxy_fcgi:error] [pid 107586:tid 139872327489280] (104)Connection reset by peer: [client 192.168.2.6:54070] AH01075: Error dispatching request to :
[Thu Mar 10 10:21:34.086700 2022] [proxy_fcgi:error] [pid 107585:tid 139872310703872] [client 192.168.2.28:57788] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:21:34.086712 2022] [proxy_fcgi:error] [pid 107585:tid 139872310703872] (104)Connection reset by peer: [client 192.168.2.28:57788] AH01075: Error dispatching request to :
[Thu Mar 10 10:21:34.088358 2022] [proxy_fcgi:error] [pid 107585:tid 139872010446592] [client 84.138.167.39:34986] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:21:34.088369 2022] [proxy_fcgi:error] [pid 107585:tid 139872010446592] (104)Connection reset by peer: [client 84.138.167.39:34986] AH01075: Error dispatching request to :
[Thu Mar 10 10:21:34.106126 2022] [proxy:error] [pid 107585:tid 139872310703872] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:21:34.106146 2022] [proxy_fcgi:error] [pid 107585:tid 139872310703872] [client 192.168.2.28:57788] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:21:34.370000 2022] [proxy:error] [pid 107586:tid 139872327489280] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:21:34.370014 2022] [proxy_fcgi:error] [pid 107586:tid 139872327489280] [client 192.168.2.6:54070] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:21:34.591448 2022] [proxy:error] [pid 107586:tid 139872327489280] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:21:34.591462 2022] [proxy_fcgi:error] [pid 107586:tid 139872327489280] [client 192.168.2.13:56472] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:21:34.592198 2022] [proxy:error] [pid 107586:tid 139872327489280] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /run/php/php7.4-fpm.sock (*) failed
[Thu Mar 10 10:21:34.592207 2022] [proxy_fcgi:error] [pid 107586:tid 139872327489280] [client 192.168.2.13:56472] AH01079: failed to make connection to backend: httpd-UDS
[Thu Mar 10 10:21:34.707190 2022] [mpm_event:notice] [pid 107584:tid 139872587828544] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 10:22:03.072024 2022] [mpm_event:notice] [pid 109091:tid 140609008110912] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 10:22:03.072055 2022] [core:notice] [pid 109091:tid 140609008110912] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 10:40:22.893456 2022] [mpm_event:notice] [pid 109091:tid 140609008110912] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 10:40:23.304369 2022] [mpm_event:notice] [pid 110342:tid 139825484291392] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 10:40:23.304397 2022] [core:notice] [pid 110342:tid 139825484291392] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 10:48:25.643642 2022] [mpm_event:notice] [pid 110342:tid 139825484291392] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 10:48:47.613917 2022] [mpm_event:notice] [pid 111434:tid 140506363239744] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 10:48:47.613949 2022] [core:notice] [pid 111434:tid 140506363239744] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 10:54:32.855681 2022] [proxy_fcgi:error] [pid 111435:tid 140506010580736] [client 192.168.2.13:58412] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:54:32.855713 2022] [proxy_fcgi:error] [pid 111435:tid 140506010580736] (104)Connection reset by peer: [client 192.168.2.13:58412] AH01075: Error dispatching request to :
[Thu Mar 10 10:54:32.869266 2022] [proxy_fcgi:error] [pid 111436:tid 140506010580736] [client 192.168.2.28:57962] AH01067: Failed to read FastCGI header
[Thu Mar 10 10:54:32.869301 2022] [proxy_fcgi:error] [pid 111436:tid 140506010580736] (104)Connection reset by peer: [client 192.168.2.28:57962] AH01075: Error dispatching request to :
[Thu Mar 10 10:54:32.872918 2022] [mpm_event:notice] [pid 111434:tid 140506363239744] AH00492: caught SIGWINCH, shutting down gracefully
[Thu Mar 10 10:56:02.824103 2022] [mpm_event:notice] [pid 1044:tid 139793746419008] AH00489: Apache/2.4.52 (Ubuntu) OpenSSL/1.1.1f configured -- resuming normal operations
[Thu Mar 10 10:56:02.908093 2022] [core:notice] [pid 1044:tid 139793746419008] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 10 12:08:06.443319 2022] [access_compat:error] [pid 1045:tid 139792989808384] [client 79.192.66.239:59283] AH01797: client denied by server configuration: /var/www/nextcloud/config
(note: probably caused by my testing, after a reboot and waiting 4h no new erros (ignoring the one client deny from the internet) were logged while the problem still persisted)
