I can log in normally through the account password on the webpage, which means that the account password is correct. However, when using a third-party image upload software to connect to nextcloud, it prompts’ required failed with code 401 '. How can I troubleshoot and resolve this issue. I hope to receive your help. Thank you.
| Nextcloud version (eg, 26.0.1): | 27.0.2 - 27.0.2.1 |
| Operating system and version (eg, Ubuntu 22.04): | Ubuntu 22.04 |
| Apache or nginx version (eg, Apache 2.4.25): | Apache/2.4.57 |
| PHP version (eg, 8.1): | 8.2.9 |
| Database (sqlite or MariaDB or Postgres) | mysql 5.7.40 |
| Docker (compose) | |
| Snap | |
| Is this the first time you’ve seen this error? | no |
1.install picgo.
2.Configure imgurl information.
3.upload picture -
{“reqId”:“ubFZO4cKjsd4OfXVk58F”,“level”:2,“time”:“2023-09-02T02:01:55+00:00”,“remoteAddr”:“myip”,“user”:“–”,“app”:“core”,“method”:“PUT”,“url”:“/remote.php/dav/files/imgurl/remote.php/dav/files/imgurl//imgurl/2Bq70Xywpo.png”,“message”:“Login failed: ‘’ (Remote IP: ‘myip’)”,“userAgent”:“PicGo”,“version”:“27.0.2.1”,“data”:{“app”:“core”}}
The output of your config.php file in /path/to/nextcloud **
- activity: 2.19.0
- circles: 27.0.1
- cloud_federation_api: 1.10.0
- comments: 1.17.0
- contactsinteraction: 1.8.0
- dashboard: 7.7.0
- dav: 1.27.0
- federatedfilesharing: 1.17.0
- federation: 1.17.0
- files: 1.22.0
- files_pdfviewer: 2.8.0
- files_rightclick: 1.6.0
- files_sharing: 1.19.0
- files_trashbin: 1.17.0
- files_versions: 1.20.0
- firstrunwizard: 2.16.0
- logreader: 2.12.0
- lookup_server_connector: 1.15.0
- nextcloud_announcements: 1.16.0
- notifications: 2.15.0
- oauth2: 1.15.1
- password_policy: 1.17.0
- photos: 2.3.0
- privacy: 1.11.0
- provisioning_api: 1.17.0
- recommendations: 1.6.0
- related_resources: 1.2.0
- serverinfo: 1.17.0
- settings: 1.9.0
- sharebymail: 1.17.0
- support: 1.10.0
- survey_client: 1.15.0
- suspicious_login: 5.0.0
- systemtags: 1.17.0
- text: 3.8.0
- theming: 2.2.0
- twofactor_backupcodes: 1.16.0
- updatenotification: 1.17.0
- user_status: 1.7.0
- viewer: 2.1.0
- weather_status: 1.7.0
- workflowengine: 2.9.0
- admin_audit
- bruteforcesettings
- encryption
- files_external
- twofactor_totp
- user_ldap
- for Docker/Podman list environment variables ( run “
docker inspect {container name}”)**
“Id”: “b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5”,
“Created”: “2023-08-29T17:27:28.843252519Z”,
“Path”: “/entrypoint.sh”,
“Args”: [
“apache2-foreground”
“State”: {
“Status”: “running”,
“Running”: true,
“Paused”: false,
“Restarting”: false,
“OOMKilled”: false,
“Dead”: false,
“Pid”: 418573,
“ExitCode”: 0,
“Error”: “”,
“StartedAt”: “2023-08-29T17:27:29.75961523Z”,
“FinishedAt”: “0001-01-01T00:00:00Z”
“Image”: “sha256:23b13545650ee1b43f8509553b1a1f7b2cc5b0aa985ff748a54c56f92d139bf0”,
“ResolvConfPath”: “/var/lib/docker/containers/b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5/resolv.conf”,
“HostnamePath”: “/var/lib/docker/containers/b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5/hostname”,
“HostsPath”: “/var/lib/docker/containers/b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5/hosts”,
“LogPath”: “/var/lib/docker/containers/b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5/b70d62206ebac960bc2f96750a9d41e9ed81f4b549fd1b2cee9b4ad30ef848c5-json.log”,
“Name”: “/cranky_lamarr”,
“RestartCount”: 0,
“Driver”: “overlay2”,
“Platform”: “linux”,
“MountLabel”: “”,
“ProcessLabel”: “”,
“AppArmorProfile”: “docker-default”,
“ExecIDs”: [
“9a4d5383f5cbf15ae1c13a339ad31bf537d928fcf4345529647e59b13bbae1bf”
“HostConfig”: {
“Binds”: null,
“ContainerIDFile”: “”,
“LogConfig”: {
“Type”: “json-file”,
“Config”: {}
“NetworkMode”: “default”,
“PortBindings”: {
“80/tcp”: [
“HostIp”: “”,
“HostPort”: “8080”
“RestartPolicy”: {
“Name”: “no”,
“MaximumRetryCount”: 0
“AutoRemove”: false,
“VolumeDriver”: “”,
“VolumesFrom”: null,
“ConsoleSize”: [
31,
271
“CapAdd”: null,
“CapDrop”: null,
“CgroupnsMode”: “private”,
“Dns”: [],
“DnsOptions”: [],
“DnsSearch”: [],
“ExtraHosts”: null,
“GroupAdd”: null,
“IpcMode”: “private”,
“Cgroup”: “”,
“Links”: null,
“OomScoreAdj”: 0,
“PidMode”: “”,
“Privileged”: false,
“PublishAllPorts”: false,
“ReadonlyRootfs”: false,
“SecurityOpt”: null,
“UTSMode”: “”,
“UsernsMode”: “”,
“ShmSize”: 67108864,
“Runtime”: “runc”,
“Isolation”: “”,
“CpuShares”: 0,
“Memory”: 0,
“NanoCpus”: 0,
“CgroupParent”: “”,
“BlkioWeight”: 0,
“BlkioWeightDevice”: [],
“BlkioDeviceReadBps”: [],
“BlkioDeviceWriteBps”: [],
“BlkioDeviceReadIOps”: [],
“BlkioDeviceWriteIOps”: [],
“CpuPeriod”: 0,
“CpuQuota”: 0,
“CpuRealtimePeriod”: 0,
“CpuRealtimeRuntime”: 0,
“CpusetCpus”: “”,
“CpusetMems”: “”,
“Devices”: [],
“DeviceCgroupRules”: null,
“DeviceRequests”: null,
“MemoryReservation”: 0,
“MemorySwap”: 0,
“MemorySwappiness”: null,
“OomKillDisable”: null,
“PidsLimit”: null,
“Ulimits”: null,
“CpuCount”: 0,
“CpuPercent”: 0,
“IOMaximumIOps”: 0,
“IOMaximumBandwidth”: 0,
“MaskedPaths”: [
“/proc/asound”,
“/proc/acpi”,
“/proc/kcore”,
“/proc/keys”,
“/proc/latency_stats”,
“/proc/timer_list”,
“/proc/timer_stats”,
“/proc/sched_debug”,
“/proc/scsi”,
“/sys/firmware”
“ReadonlyPaths”: [
“/proc/bus”,
“/proc/fs”,
“/proc/irq”,
“/proc/sys”,
“/proc/sysrq-trigger”
“GraphDriver”: {
“Data”: {
“LowerDir”: “/var/lib/docker/overlay2/1d7537d792db2fcd8237947ef02db89baea3eed56c9556299b6775f736d6c4e6-init/diff:/var/lib/docker/overlay2/27a667ea7ed383d53b955605de88004464fff36a661b71674ec69ba67a996d68/diff:/var/lib/docker/overlay2/8b9283e8e9568f443cb4a21effd3061b0e0e6f11c7ad192166800c73660fb77b/diff:/var/lib/docker/overlay2/d3d107994e2854dbe3d3ad306dfb8e73f33135e4e0e952ab295fd1651787ca58/diff:/var/lib/docker/overlay2/2649921c6bb68213f3f2940fa38917556393797c230ef4f7ead099d35817e9e5/diff:/var/lib/docker/overlay2/304dbc795d4f458132cf5cca99a75f80c47def558572effc850ac820a15bf557/diff:/var/lib/docker/overlay2/1fbc6b272a2b0f10cd3d8289e390bdba558006dff0d0d0402d5d76a5ef91d995/diff:/var/lib/docker/overlay2/c33db52da088f48a0ffe64fb4a4d40c33d34415e9b9bba2614ef865698363452/diff:/var/lib/docker/overlay2/d1ffdd493fbe899bfaf84b67005bc7a3a1ad8410356a22e04c693411710bfd83/diff:/var/lib/docker/overlay2/eb5f8d1b07a5e79b4272753f1c841d910561a87b5931c862548301b19bf13818/diff:/var/lib/docker/overlay2/bcdc9cee7562a1de9d28c7535d4d557ef01f7ab6d9243c9f3ad6f9b0a1992203/diff:/var/lib/docker/overlay2/b814a9460230c5f463c1fa52635f0b1f7ea93eff1abd3f408c220162aec62e8c/diff:/var/lib/docker/overlay2/a360e086f50f8c50a823abd42083fb660fa9a963f2faa7784c13ab7320ada2c1/diff:/var/lib/docker/overlay2/51da470af09da777362b584eed9348f0c528d167cb001be288a6f68ee6ac3cf6/diff:/var/lib/docker/overlay2/e541e90277f7c94b26b4eb7a8872243e9a9e099e9ecb38f6454756bd04dcbc52/diff:/var/lib/docker/overlay2/26e97f99affc6a2b071a013b9abbedfea27ba7670d7a055533eb0ae9c1b2dcfa/diff:/var/lib/docker/overlay2/7cb1d7c2c2ebc409b28a3f0e98573b515abec5de562f0ed945408c22af3c2bb6/diff:/var/lib/docker/overlay2/4edbf31ad7e17f26d461e4740b58a6ce36e4e1db4e9e0809180b455892f693c7/diff:/var/lib/docker/overlay2/928f49fc0c484b5016752ea1242c8137955b41e09dec43198493231fae260163/diff:/var/lib/docker/overlay2/966a77814d5a85fbfef3ab3423c628543aa8a9fa0be62dbec20ec59c881544b8/diff:/var/lib/docker/overlay2/93b4062c021c80c059f9d765d8bfc1e96f674dccb5f492594a8290119b620731/diff”,
“MergedDir”: “/var/lib/docker/overlay2/1d7537d792db2fcd8237947ef02db89baea3eed56c9556299b6775f736d6c4e6/merged”,
“UpperDir”: “/var/lib/docker/overlay2/1d7537d792db2fcd8237947ef02db89baea3eed56c9556299b6775f736d6c4e6/diff”,
“WorkDir”: “/var/lib/docker/overlay2/1d7537d792db2fcd8237947ef02db89baea3eed56c9556299b6775f736d6c4e6/work”
“Name”: “overlay2”
“Mounts”: [
“Type”: “volume”,
“Name”: “ad072d0cc3236b73211ac3f0c80d70600ddcf0fe81048ca77c754a27fea8ece6”,
“Source”: “/var/lib/docker/volumes/ad072d0cc3236b73211ac3f0c80d70600ddcf0fe81048ca77c754a27fea8ece6/_data”,
“Destination”: “/var/www/html”,
“Driver”: “local”,
“Mode”: “”,
“RW”: true,
“Propagation”: “”
“Config”: {
“Hostname”: “b70d62206eba”,
“Domainname”: “”,
“User”: “”,
“AttachStdin”: false,
“AttachStdout”: false,
“AttachStderr”: false,
“ExposedPorts”: {
“80/tcp”: {}
“Tty”: false,
“OpenStdin”: false,
“StdinOnce”: false,
“Env”: [
“PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin”,
“PHPIZE_DEPS=autoconf \t\tdpkg-dev \t\tfile \t\tg++ \t\tgcc \t\tlibc-dev \t\tmake \t\tpkg-config \t\tre2c”,
“PHP_INI_DIR=/usr/local/etc/php”,
“APACHE_CONFDIR=/etc/apache2”,
“APACHE_ENVVARS=/etc/apache2/envvars”,
“PHP_CFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64”,
“PHP_CPPFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64”,
“PHP_LDFLAGS=-Wl,-O1 -pie”,
“GPG_KEYS=39B641343D8C104B2B146DC3F9C39DC0B9698544 E60913E4DF209907D8E30D96659A97C9CF2A795A 1198C0117593497A5EC5C199286AF1F9897469DC”,
“PHP_VERSION=8.2.9”,
“PHP_URL=https://www.php.net/distributions/php-8.2.9.tar.xz”,
“PHP_ASC_URL=https://www.php.net/distributions/php-8.2.9.tar.xz.asc”,
“PHP_SHA256=1e6cb77f997613864ab3127fbfc6a8c7fdaa89a95e8ed6167617b913b4de4765”,
“PHP_MEMORY_LIMIT=512M”,
“PHP_UPLOAD_LIMIT=512M”,
“NEXTCLOUD_VERSION=27.0.2”
“Cmd”: [
“Image”: “nextcloud”,
“Volumes”: {
“/var/www/html”: {}
“WorkingDir”: “/var/www/html”,
“Entrypoint”: [
“/entrypoint.sh”
“OnBuild”: null,
“Labels”: {},
“StopSignal”: “SIGWINCH”
“NetworkSettings”: {
“Bridge”: “”,
“SandboxID”: “655277b9661128caa994fc386d458e2c0e65bdabd665758b53c94b86697d200d”,
“HairpinMode”: false,
“LinkLocalIPv6Address”: “”,
“LinkLocalIPv6PrefixLen”: 0,
“Ports”: {
“80/tcp”: [
“HostIp”: “0.0.0.0”,
“HostPort”: “8080”
“HostIp”: “::”,
“HostPort”: “8080”
“SandboxKey”: “/var/run/docker/netns/655277b96611”,
“SecondaryIPAddresses”: null,
“SecondaryIPv6Addresses”: null,
“EndpointID”: “2b0d8b9802a8f9f5543ae66049ece74178e9e9a0f5ce8e52c73874ba047ffc1f”,
“Gateway”: “172.17.0.1”,
“GlobalIPv6Address”: “”,
“GlobalIPv6PrefixLen”: 0,
“IPAddress”: “172.17.0.2”,
“IPPrefixLen”: 16,
“IPv6Gateway”: “”,
“MacAddress”: “02:42:ac:11:00:02”,
“Networks”: {
“bridge”: {
“IPAMConfig”: null,
“Links”: null,
“Aliases”: null,
“NetworkID”: “c70af32c1d2a790485b600ddf9b00bac8d85235f6fc4c02aa8eccfa825494980”,
“IPPrefixLen”: 16,
“IPv6Gateway”: “”,
“DriverOpts”: null
