Second attempt at getting help with this on this site.
See first attempt here: Uploads write to SD Card before transferring to external…
I have successfully changed my data directory with Solution 1 seen here : How to change / move data directory
When I upload items, the behavior has changed. Now, my external drive fills up during the transfer, awesome!
However, I still see pretty large chunks of data continually being sent and then deleted from the SD Card.
How do I stop this behavior?
Things I’ve tried:
Sync folder directory is inside my external drive.
Changed data directory as mentioned above
Added a line to my config file:
‘datadirectory’ => ‘/mnt/my8TBeZ/nextcloud/data’,
’tempdirectory’ => ‘/mnt/my8TBeZ/nextcloud/data/tmp’,
after trying to solve this by posting on github.
Any other ideas? a 1 G transfer does several cycles of 100 MB + writes/deletes from the SD card
Thanks.
