Configure HPB client push for Nextcloud snap
Developers GitHub: GitHub - nextcloud/notify_push: Update notifications for nextcloud clients · GitHub
This app attempts to solve the issue where Nextcloud clients have to periodically check the server if any files have been changed. In order to keep sync snappy, clients wants to check for updates often, which increases the load on the server.
With many clients all checking for updates a large portion of the server load can consist of just these update checks.
By providing a way for the server to send update notifications to the clients, the need for the clients to make these checks can be greatly reduced.
Update notifications are provided on a “best effort” basis, updates might happen without a notification being sent and a notification can be sent even if no update has actually happened. Clients are advised to still perform periodic checks for updates on their own, although these can be run on a much lower frequency.
FQDN / trusted proxy configuration
Verify FDQN is correctly configured and trusted proxies are correctly set up.
See Hosts & FQDN configuration
Install
A. Install the Nextcloud app
Install the “Client Push” app via the App Store or via the cli:
sudo nextcloud.occ app:enable notify_push
B. Create the systemd unit
- Create and open a new systemd unit file via
sudo nano /etc/systemd/system/notify_push.serviceand paste the following template in:
[Unit]
Description = Push daemon for Nextcloud clients
After = snap.nextcloud.nextcloud-fixer.service
[Service]
Environment=SOCKET_PATH=/tmp/snap-private-tmp/snap.nextcloud/tmp/sockets/notify_push.sock
Environment=DATABASE_URL=mysql://nextcloud:CHANGEME@localhost/nextcloud?socket=/tmp/snap-private-tmp/snap.nextcloud/tmp/sockets/mysql.sock
Environment=REDIS_URL=redis+unix:///tmp/snap-private-tmp/snap.nextcloud/tmp/sockets/redis.sock
ExecStartPre=/bin/bash -c 'while /bin/systemctl is-active --quiet snap.nextcloud.nextcloud-fixer.service; do sleep 10; done'
TimeoutStartSec=15m
ExecStart=/var/snap/nextcloud/current/nextcloud/extra-apps/notify_push/bin/ARCHITECTURE/notify_push /var/snap/nextcloud/current/nextcloud/config/config.php
Type=notify
User=root
[Install]
WantedBy = multi-user.target
- Adjust the template with some system configurations:
- Replace
ARCHITECTUREwith one of the following, depending on your system. Some examples:- x86_64
- aarch64
- armv7
- Replace
CHANGEMEinDATABASE_URLwith the config valuedbpassword.
Get via cli with:sudo nextcloud.occ config:system:get dbpassword.
C. Start & enable the systemd unit
sudo systemctl start notify_pushsudo systemctl enable notify_push
D. Enable the reverse proxy
Enable the reverse proxy configuration for notify_push using the following command:
sudo snap set nextcloud http.notify-push-reverse-proxy=true
E. Setup the Nextcloud app
Setup the app via the following command:
sudo nextcloud.occ notify_push:setup https://cloud.example.com/push
Replacing cloud.example.com with your instance domain.
Verify client push operation
Verify notify_push metrics using occ commands
View client push metrics:
sudo nextcloud.occ notify_push:metrics
example output
Active connection count: 1
Active user count: 1
Total connection count: 10
Total database query count: 2
Events received: 12
Messages sent: 0
Messages sent (file): 0
Messages sent (notification): 0
Messages sent (activity): 0
Messages sent (custom): 0
Notify push self test
testing notify push functionality:
sudo nextcloud.occ notify_push:self-test
result should be something like:
âś“ redis is configured
âś“ push server is receiving redis messages
âś“ push server can load mount info from database
âś“ push server can connect to the Nextcloud server
âś“ push server is a trusted proxy
âś“ push server is running the same version as the app
Notify push logging and debugging
Debug option for notify_push
sudo nextcloud.occ notify_push:log debug
and
sudo journalctl -eu notify_push
By default, the push server only logs warnings, you can temporarily change the log level with an occ command
sudo nextcloud.occ notify_push:log <level>
Where level is error, warn, info, debug or trace, or restore the log level to the previous value using
sudo nextcloud.occ notify_push:log --restore
Uninstall
A. Stop & disable the systemd unit
sudo systemctl stop notify_pushsudo systemctl disable notify_push
B. Uninstall the Nextcloud app
Uninstall the “Client Push” app via the App Store or via the cli:
sudo nextcloud.occ app:remove notify_push
C. Disable the Reverse Proxy
Disable the reverse proxy configuration for notify_push using the following command:
sudo snap set nextcloud http.notify-push-reverse-proxy=false
Troubleshooting
- Ensure you configured
overwrite.cli.urlif required. Otherwise you may not be able to continue the setup. - Ensure you added
127.0.0.1totrusted_proxiesin config.php:
'trusted_proxies' =>
0 => '127.0.0.1',
Configuration when using Caddy as a reverse proxy
When using Caddy as a reverse proxy in front of you nextcloud instance, you also have to take this into account: the trusted_proxies array must contain all IP addresses in the chain that will forward connections to the server.
In the following example, where Caddy and the Nextcloud snap are both running as containers on an Incus server, and the Caddy container has two network interfaces:
- one physical (
eth0) connected to the home network (with range192.168.0.1/24), - and another one (
enp4s0) to the bridge network (incusbr0with range10.177.116.1/24).
| NAME | IPV4 |
| caddy-container | 10.177.116.10 (eth0) |
| | 192.168.0.25 (enp4s0) |
| nextcloud-container | 10.177.116.11 (eth0) |
You would need to add the following to the trusted_proxies array:
$ sudo nextcloud.occ config:system:get trusted_proxies
127.0.0.1
10.177.116.10
192.168.0.25
<public-IP>
Caddy
Besides that, the <public-IP> needs to be in the Caddy’s trusted_proxies:
Following the example above, this should be added to the Caddyfile:
servers {
trusted_proxies static <public-IP>/32
[!TIP]
Set Nextcloud Talk push notification in config.php to enable notification
Setting Talk push notification
edit config.php and add/edit line in config.php
'has_internet_connection' => 'true',
or issue command on host:
sudo nextcloud.occ config:system:set has_internet_connection --value="true"
