I’m search information on the performance of nextcloudpi on a Raspberry Pi 8GB with an SSD. How many users I can hope manage with a good user experience?
Maybe it’s not the right place to talk about it, maybe it’s information that we don’t want to broadcast … do not hesitate to tell me.
I found some information but it’s not specific to nextcloudpi and the Raspberry Pi:
The old deployment recommendations could be an orientation. Back then, spreed wasn’t considered. Already on real servers, people try to optimize for good performance.
Apart from that, just file syncing and calendars, it really depends how intensive the cloud is used. If you have 5 users that upload 5 pictures a day, it’s probably no problem. If each has 1 TB of data synced, with several devices at the same time, and they change a considerable amount of this data, you can easily saturate the RPi.
There are a few posts here where people use raspberries and share how to optimize them. It could give you a rough idea.
Considering the price, you can always start and play around with the Raspberry Pi, and perhaps it is sufficient in the beginning. If you see limits, you can upgrade the hardware and move your Nextcloud setup.
