I’m new here and I don’t know if this is exactly the channel for this question.
I’m looking for a way to integrate Talk with my application, using webhook, or even api, but I wasn’t successful, I only found webhook for some events, but nothing related to Talk (which is my need). Could someone help me by giving a direction or indicating something ready that can be used?
Thanks
This could be what you are searching for?
https://nextcloud-talk.readthedocs.io/en/latest/bots/
“Bots” (bots-v1 capability) is available in Nextcloud 27.1, still in Beta at present.
But it is the cutting edge, so if you begin to develope now, your integration will work for a long time ![]()
Hope this helps,
much luck!
maybe this helps: Help with NextTalk Chat API
