Help for nextcloud
I accidentally set the beta channel
and I have the following problems
text aldin
  • Some files have not passed the integrity check. List of invalid files… Rescan… Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • No High-performance backend configured - Running Nextcloud Talk without the High-performance backend only scales for very small calls (max. 2-3 participants). Please set up the High-performance backend to ensure calls with multiple participants work seamlessly. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • Your webserver is not set up to serve .js.map files. Without these files, JavaScript Source Maps won’t function properly, making it more challenging to troubleshoot and debug any issues that may arise.
  • Unable to run check for JavaScript support. Please remedy or confirm manually if your webserver serves .mjs files using the JavaScript MIME type. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its trusted_domains or the overwrite.cli.url. This failure may be the result of a server-side DNS mismatch or outbound firewall rule.
  • Your web server is not properly set up to resolve .well-known URLs, failed on: /.well-known/webfinger Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • 29773 errors in the logs since 1 februarie 2025, 17:27:56
  • One or more mimetype migrations are available. Occasionally new mimetypes are added to better handle certain file types. Migrating the mimetypes take a long time on larger instances so this is not done automatically during upgrades. Use the command occ maintenance:repair --include-expensive to perform the migrations.
  • Some headers are not set correctly on your instance - The X-Robots-Tag HTTP header is not set to noindex,nofollow. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • Detected some missing optional indices. Occasionally new indices are added (by Nextcloud or installed applications) to improve database performance. Adding indices can sometimes take awhile and temporarily hurt performance so this is not done automatically during upgrades. Once the indices are added, queries to those tables should be faster. Use the command occ db:add-missing-indices to add them. Missing indices: “mail_messages_strucanalyz_idx” in table “mail_messages”, “mail_acc_prov_idx” in table “mail_accounts”, “mail_alias_accid_idx” in table “mail_aliases”, “systag_objecttype” in table “systemtag_object_mapping”, “mail_messages_mb_id_uid_uidx” in table “mail_messages”, “mail_smime_certs_uid_email_idx” in table “mail_smime_certificates”, “mail_trusted_senders_idx” in table “mail_trusted_senders”, “mail_coll_idx” in table “mail_coll_addresses”. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • MariaDB version “11.7.1-MariaDB-deb12” detected. MariaDB >=10.6 and <=11.4 is suggested for best performance, stability and functionality with this version of Nextcloud.
  • PHP nu pare să fie configurat corespunzător pentru a interoga variabilele de mediu ale sistemului. Testul cu getenv(“PATH”) returnează doar un răspuns gol. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • The PHP OPcache module is not properly configured. The OPcache interned strings buffer is nearly full. To assure that repeating strings can be effectively cached, it is recommended to apply “opcache.interned_strings_buffer” to your PHP configuration with a value higher than “8”… Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • Could not check for otf loading support. Please check manually if your webserver serves .otf files. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its trusted_domains or the overwrite.cli.url. This failure may be the result of a server-side DNS mismatch or outbound firewall rule. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • The database is used for transactional file locking. To enhance performance, please configure memcache, if available. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • You have not set or verified your email server configuration, yet. Please head over to the “Basic settings” in order to set them. Afterwards, use the “Send email” button below the form to verify your settings. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
  • Could not check for WASM loading support. Please check manually if your web server serves .wasm files. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its trusted_domains or the overwrite.cli.url. This failure may be the result of a server-side DNS mismatch or outbound firewall rule. Pentru mai multe detalii vedeți documentația :arrow_upper_right:.
Versiunea
Nextcloud Hub 10 (31.0.0 RC3)
how can I downgrade?
By restoring from a recent backup (using whatever method you’re using to keep your Nextcloud environment backed up).
I didn’t
does he do it automatically?
Where would it back up to automatically?
Though some installation methods (you didn’t fill out the support template so no idea what you’re using), do have some rollback and backup options built-in (i.e. the Nextcloud Snap and Nextcloud AIO), which you can configure and use if you wish.
Otherwise, the backups are an administrative task. A basic approach for setting up backups is covered in the Admin Manual here.
