Help! Docker Domaincheck won't accept tailscale validated caddy reverse proxy
Hello, I’m following the local guide, and built upon this jellyfin/caddy/tailscale project which works flawlessly. I really am stuck on why nextcloud wouldn’t work the same way as the error is vague, if you could please direct me. Here’s my nextcloud config:
networks:
  # network created via docker
  # all other containers are also on it
  proxy-network:
volumes:
  # shared volumes any container in the same docker-compose file can access
  # used to share the tailscaled.sock file with caddy
    sock_volume:
  # you do not have to use the same local filepaths that I do for volume mapping in the containers,
  # but you do have to make sure whatever filepath you use is mapped to the correct filepath in the container
services:
  caddy:
    image: caddy
    container_name: "caddyn"
    hostname: caddy
    networks:
      # caddy is in the network with the other containers
      - proxy-network
    depends_on:
      # wait for tailscale to boot
      # to communicate to it using the tailscaled.sock
      - tailscale
    ports:
      - "80:80"
      - "443:443"
      - "443:443/udp"
    volumes:
      - ~/nextcloud/caddy/Caddyfile:/etc/caddy/Caddyfile
      - ~/nextcloud/caddy/data:/data
      - ~/nextcloud/caddy/config:/config
      # get socket tailscale created in the shared volume and share it with caddy
      # caddy expects the socket to be at /var/run/tailscale/tailscaled.sock
      - sock_volume:/var/run/tailscale
    restart: unless-stopped
  tailscale:
        container_name: tailscalen #tailscale n (nextcloud)
        image: tailscale/tailscale
        network_mode: host
        # tailscale sets new machine names to the OS hostname
        # docker-desktop is the default hostname for docker
        # if you modify this and recreate the container, the machine name will be updated automatically
        # make sure this matches the machine name you set in the Caddyfile
        hostname: nextcloud
        cap_add:
            - NET_ADMIN
            - NET_RAW
        volumes:
            # saves container state after container is recreated
            # used varlib because var folder isn't needed locally
            - ~/nextcloud/varlib:/var/lib
            # containerized version of tailscale uses /tmp/tailscaled.sock
            # binds the socket to a docker volume so it can be accessed by other containers
            # this can't be a local directory because the socket is created by the container
            - sock_volume:/tmp
        environment:
            # if you add a command key, it will override environment key variables with default values!
            # info: https://tailscale.com/kb/1282/docker#ts_socks5_server
            # set the authkey to reusable when generating it from tailscale #share old key?
            #- TS_AUTHKEY=
            # prevents a new machine from being added each time the container is restarted
            - TS_STATE_DIR=/var/lib/tailscale
            # https://tailscale.com/kb/1112/userspace-networking
            - TS_USERSPACE_NETWORKING=userspace-networking
  nextcloud:
    restart: always
    networks: #I'm adding this, maybe that's why it's not working with caddy?
      - proxy-network
    volumes:
    ports:
      #- 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - 8080:8080
      #- 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # - AIO_DISABLE_BACKUP_SECTION=false # Setting this to true allows to hide the backup section in the AIO interface. See https://github.com/nextcloud/all-in-one#how-to-disable-the-backup-section
      #- SKIP_DOMAIN_VALIDATION=true #might not be helping?
      - APACHE_PORT=11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - APACHE_IP_BINDING=0.0.0.0 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx, Cloudflare Tunnel and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # - BORG_RETENTION_POLICY=--keep-within=7d --keep-weekly=4 --keep-monthly=6 # Allows to adjust borgs retention policy. See https://github.com/nextcloud/all-in-one#how-to-adjust-borgs-retention-policy
      # - COLLABORA_SECCOMP_DISABLED=false # Setting this to true allows to disable Collabora's Seccomp feature. See https://github.com/nextcloud/all-in-one#how-to-disable-collaboras-seccomp-feature
      # - NEXTCLOUD_DATADIR=/mnt/ncdata # Allows to set the host directory for Nextcloud's datadir. ⚠️⚠️⚠️ Warning: do not set or adjust this value after the initial Nextcloud installation is done! See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
      # - NEXTCLOUD_MOUNT=/mnt/ # Allows the Nextcloud container to access the chosen directory on the host. See https://github.com/nextcloud/all-in-one#how-to-allow-the-nextcloud-container-to-access-directories-on-the-host
      - NEXTCLOUD_UPLOAD_LIMIT=1G # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-upload-limit-for-nextcloud
      - NEXTCLOUD_MAX_TIME=3600 # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-max-execution-time-for-nextcloud
      - NEXTCLOUD_MEMORY_LIMIT=1024M # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-php-memory-limit-for-nextcloud
      # - NEXTCLOUD_TRUSTED_CACERTS_DIR=/path/to/my/cacerts # CA certificates in this directory will be trusted by the OS of the nexcloud container (Useful e.g. for LDAPS) See See https://github.com/nextcloud/all-in-one#how-to-trust-user-defined-certification-authorities-ca
      # - NEXTCLOUD_STARTUP_APPS=deck twofactor_totp tasks calendar contacts notes # Allows to modify the Nextcloud apps that are installed on starting AIO the first time. See https://github.com/nextcloud/all-in-one#how-to-change-the-nextcloud-apps-that-are-installed-on-the-first-startup
      # - NEXTCLOUD_ADDITIONAL_APKS=imagemagick # This allows to add additional packages to the Nextcloud container permanently. Default is imagemagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-os-packages-permanently-to-the-nextcloud-container
      # - NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS=imagick # This allows to add additional php extensions to the Nextcloud container permanently. Default is imagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-php-extensions-permanently-to-the-nextcloud-container
      # - NEXTCLOUD_ENABLE_DRI_DEVICE=true # This allows to enable the /dev/dri device in the Nextcloud container. ⚠️⚠️⚠️ Warning: this only works if the '/dev/dri' device is present on the host! If it should not exist on your host, don't set this to true as otherwise the Nextcloud container will fail to start! See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-transcoding-for-nextcloud
      - TALK_PORT=3478 # This allows to adjust the port that the talk container is using. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-talk-port
      # - WATCHTOWER_DOCKER_SOCKET_PATH=/var/run/docker.sock # Needs to be specified if the docker socket on the host is not located in the default '/var/run/docker.sock'. Otherwise mastercontainer updates will fail. For macos it needs to be '/var/run/docker.sock'
    # networks: # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
    # - nextcloud-aio # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
    depends_on: #needs to be in same stack? Just start after jellyfin
      - caddy
# Steps
#1. run the command: docker-compose up -d
#2. run the command: docker exec tailscaled tailscale --socket /tmp/tailscaled.sock cert <machine-name>.<tailnet-name>.ts.net
#3. remove the auth key from docker-compose.yaml, save the file, you can keep the container running
#4. run the command: docker-compose up -d
# Filepath
# ├── caddy
# │   ├── Caddyfile
# │   ├── config
# │   └── data
# ├── docker-compose.yaml
# └── tailscale
#     └── varlib
and caddyfile:
nextcloud.wallaby-gopher.ts.net {
	header Strict-Transport-Security max-age=31536000; #would this stop timeout?
	reverse_proxy nextcloud:11000
# set to loopback address so it works on the host machine
127.0.0.1 {
Here’s the error I get in the domain checker:
Here’s that log:
Here’s caddy:
I’d really like to stay off the main web the same way I did with jellyfin. Thanks.
This was solved here: https://caddy.community/t/help-docker-caddy-suddenly-no-longer-can-find-dns-records/24983/20
