[Help] Automaticly adding anniversaries to birthday calendar
After the initial sync of my outlook contacts into nextcloud, a “birthday calendar” has been created automaticly.
This is a nice feature, since I am using this calendar a lot in outlook.
But I created a second date at my contacts called “anniversary”, which I had also linked into my outlook calendar.
The data has been synced to nextcloud - but this anniversary dates will not appear at the birthday calender nor will there an additional “anniversary calendar”.
Is it possible to have the one or the other thing happen automaticly?
Thanks
Dirk
Hello!
The task is done automatically if you properly set your cron job.
You can also trigger it with an occ command.
https://docs.nextcloud.com/server/stable/admin_manual/configuration_server/background_jobs_configuration.html?highlight=cron
https://docs.nextcloud.com/server/stable/admin_manual/configuration_server/occ_command.html?highlight=birthday#dav-commands
Birthdays are synced correct. This happend “out of the box” during the first import and each time, I add a new contact.
But we do use also the anniversary-Field at Outlook.
And this one is not synced into the Birthday-Calendar…
Could you post a vcard example of an outlook created contact with an anniversary field set here please? :slight_smile:
It should be the same property as Birthday, just different terminology :wink:
I attached the vcard to my webspace:
TestSecondContactname.vcf.
Here its content:
`BEGIN:VCARD
VERSION:2.1
N;LANGUAGE=de:Contactname;Test;Second;Herr
FN:Herr Test Second Contactname
ORG:Testcompany
X-MS-OL-DEFAULT-POSTAL-ADDRESS:0
BDAY:19700218
X-MS-ANNIVERSARY:19721014
EMAIL;PREF;INTERNET:contactname@testcompany.com
X-MS-CARDPICTURE;TYPE=JPEG;ENCODING=BASE64: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X-MS-OL-DESIGN;CHARSET=utf-8:
X-MS-SPOUSE:Emma
REV:20190302T123315Z
END:VCARD
We just have found out, that “SPOUSE” seems to be not synced into nextcloud too…
THIS is a big issue for us!
Is there any way to handle this?
Thanks
Dirk
I created a V3 Type VCF-File containing aniversary and Spouse to add it manually into nextcloud - and these Information are not visible on the contact.
item1.X-ABDATE:1997-10-13
item1.X-ABLABEL:$!!$
item2.X-ABRELATEDNAMES:Kerstin Müller
item2.X-ABLABEL:$!!$
So: Are they stored in the database at all?
If you export the imported vcf file again you should see all fields which are not displayed in the Contacts app too. But you have used custom and NOT standardized fields! Check out the CardDAV RFC to find out how correct fields should look like in a vcf file.
After Importing an V3 VCF-File and exporting it from nextcloud, I found no difference but in the style the date-fields are written
(19650325 vs 1965-03-25).
The “Item” Fields are all there…
So it seems, that these fields are not synced by caldav syncronizer.
Meanwhile I found a switch, so the anniversary IS synced now.
Missing the spouse…
Are not supported yet, see opened github issues.
As there is no feedback since a while I will close this ticket. If this is still happening please make sure to upgrade to the latest version. After that, feel free to reopen.
