Getting hash errors while trying to hunt down connection issues
I have been having a bunch of issues since I had an issue where I accidentally tried to copy a huge folder into another folder, then canceled it. Not sure if this is related, as I have reset/reinstalled NC. I thought reinstalling would fix my issue since I couldn’t sync anyway. Below (in the log section) are the issues I am getting now
    • 31
    • Ubuntu 24.04.2 LTS
    • Apache 2.4.58
    • replace me
    • 8.3.6
Error
index
Exception
hash_hkdf(): Argument #2 ($key) cannot be empty in file '/var/www/html/nextcloud/lib/private/Security/Crypto.php' line 147
Sep 9, 2025, 11:36:58 AM
Error
index
Exception
Error
index
Exception
Sep 9, 2025, 11:36:48 AM
Error
no app in context
Exception
Sep 9, 2025, 11:35:06 AM
Error
no app in context
BadRequest
Expected filesize of 9151852 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1245184 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Sep 9, 2025, 11:31:31 AM
Error
no app in context
Exception
Sep 9, 2025, 11:30:44 AM
Error
no app in context
Exception
Sep 9, 2025, 11:27:42 AM
Error
no app in context
Exception
Sep 9, 2025, 11:16:16 AM
Error
no app in context
Exception
Sep 9, 2025, 11:13:10 AM
Error
no app in context
Exception
Sep 9, 2025, 11:10:04 AM
Error
index
Exception
Sep 9, 2025, 11:09:34 AM
Error
index
Exception
Sep 9, 2025, 11:09:14 AM
Error
index
Exception
Error
index
Exception
Error
index
Exception
Sep 9, 2025, 11:05:11 AM
Error
index
Exception
Sep 9, 2025, 11:04:50 AM
Error
index
Exception
Error
index
Exception
Error
no app in context
BadRequest
Expected filesize of 3925215 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1835008 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Sep 9, 2025, 11:03:50 AM
Error
no app in context
BadRequest
Expected filesize of 8823068 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 6553600 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Sep 9, 2025, 11:02:54 AM
Error
no app in context
Exception
Sep 9, 2025, 10:58:42 AM
Error
no app in context
Exception
Sep 9, 2025, 10:55:36 AM
Error
no app in context
BadRequest
Expected filesize of 93845 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 49152 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Sep 9, 2025, 10:53:34 AM
Error
no app in context
Exception
Sep 9, 2025, 10:46:19 AM
Error
no app in context
Exception
Sep 9, 2025, 10:42:10 AM
Error
no app in context
Exception
Sep 9, 2025, 10:35:43 AM
PASTE
PASTE HERE
PASTE HERE
You’ll need to post the full stack trace from one of the log entries, as noted in the support template text.
The reset/reinstall could be related. For example, if you were using encryption if you didn’t migrate over the secret (such as if you dumped your config/config.php).
I have the nextcloud error logs from Aug. 1 to current here nextcloud error log 9/11 - Pastebin.com
Those appear to be your web server error logs, not contents of the Nextcloud log.
I put as much as i could here
