urbaman
September 16, 2025, 8:00pm
1
Together with this , I’m also installing with docker volumes on an NFS mount on the host.
Whenever I try to enable Fulltextsearch, it restarts complaining about stale files.
Is it possible to install Fulltextsearch (elasticsearch?) on an NFS mount?
Thank you very much.
urbaman
September 18, 2025, 5:40pm
2
Here are the actual logs:
docker logs nextcloud-aio-fullsearch
java.nio.file.FileSystemException: /usr/share/elasticsearch/data: Stale file handleat java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)at java.base/sun.nio.fs.UnixException.asIOException(UnixException.java:115)at java.base/sun.nio.fs.UnixFileSystemProvider.newDirectoryStream(UnixFileSystemProvider.java:452)at java.base/java.nio.file.Files.newDirectoryStream(Files.java:445)at java.base/java.nio.file.Files.list(Files.java:3419)at org.elasticsearch.xpack.security.cli.AutoConfigureNode.isDirEmpty(AutoConfigureNode.java:1163)at org.elasticsearch.xpack.security.cli.AutoConfigureNode.execute(AutoConfigureNode.java:170)at org.elasticsearch.server.cli.ServerCli.autoConfigureSecurity(ServerCli.java:185)at org.elasticsearch.server.cli.ServerCli.execute(ServerCli.java:91)at org.elasticsearch.common.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:55)at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:101)at org.elasticsearch.cli.Command.main(Command.java:54)at org.elasticsearch.launcher.CliToolLauncher.main(CliToolLauncher.java:65)
jtr
September 18, 2025, 6:45pm
3
Yes, if should be possible. But you’ll need to be willing to get more familiar with the underlying parts of your storage infrastructure and OS.
But possible isn’t the same as recommended.
Configuring NFS is fairly nuanced and implementation specific (on both the client - your AIO host in this case - and server-side). And some implementations are also simply not robust enough no matter how they’re configured.
The underlying cause may also be related to your other post’s issue.
system
Closed
December 15, 2025, 8:01pm
4
