After the update to Nextcloud 20 and fulltextsearch 2.0 I’m getting the following errors when searching:
Error: Undefined offset: 1 at /var/www/html/custom_apps/fulltextsearch/lib/Search/UnifiedSearchProvider.php#158
Error: Array to string conversion at /var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php#81
Also the fulltextsearch:search command throws this error:
TypeError: Argument 1 passed to OCA\Files_FullTextSearch\Service\FilesService::getFileFromId() must be of the type string, null given, called in /var/www/html/custom_apps/files_fulltextsearch/lib/Service/SearchService.php on line 269 and defined in /var/www/html/custom_apps/files_fulltextsearch/lib/Service/FilesService.php:463
Stack trace:
#0 /var/www/html/custom_apps/files_fulltextsearch/lib/Service/SearchService.php(269): OCA\Files_FullTextSearch\Service\FilesService->getFileFromId(NULL, 86505)
#1 /var/www/html/custom_apps/files_fulltextsearch/lib/Service/SearchService.php(233): OCA\Files_FullTextSearch\Service\SearchService->setDocumentInfo(Object(OCA\Files_FullTextSearch\Model\FilesDocument))
#2 /var/www/html/custom_apps/files_fulltextsearch/lib/Provider/FilesProvider.php(335): OCA\Files_FullTextSearch\Service\SearchService->improveSearchResult(Object(OCA\FullTextSearch\Model\SearchResult))
#3 /var/www/html/custom_apps/fulltextsearch/lib/Service/SearchService.php(198): OCA\Files_FullTextSearch\Provider\FilesProvider->improveSearchResult(Object(OCA\FullTextSearch\Model\SearchResult))
#4 /var/www/html/custom_apps/fulltextsearch/lib/Service/SearchService.php(161): OCA\FullTextSearch\Service\SearchService->searchFromProviders(Object(OCA\FullTextSearch_ElasticSearch\Platform\ElasticSearchPlatform), Array, Object(OC\FullTextSearch\Model\DocumentAccess), Object(OCA\FullTextSearch\Model\SearchRequest))
#5 /var/www/html/custom_apps/fulltextsearch/lib/Command/Search.php(109): OCA\FullTextSearch\Service\SearchService->search('Admin', Object(OCA\FullTextSearch\Model\SearchRequest))
#6 /var/www/html/3rdparty/symfony/console/Command/Command.php(255): OCA\FullTextSearch\Command\Search->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#7 /var/www/html/core/Command/Base.php(169): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#8 /var/www/html/3rdparty/symfony/console/Application.php(1000): OC\Core\Command\Base->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#9 /var/www/html/3rdparty/symfony/console/Application.php(271): Symfony\Component\Console\Application->doRunCommand(Object(OCA\FullTextSearch\Command\Search), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#10 /var/www/html/3rdparty/symfony/console/Application.php(147): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#11 /var/www/html/lib/private/Console/Application.php(215): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /var/www/html/console.php(100): OC\Console\Application->run()
#13 /var/www/html/occ(11): require_once('/var/www/html/c...')
Here is also a link to the full log: https://pastiebin.com/view/5f8ccebf89add
Does anyone have the same problems and how can I solve this?
