The first beta of Nextcloud 26 is now available on our download server! ![]()
If you notice anything out of order, please report back on the appropriate github repository! ![]()
Downloads
Rough changelog
- Limit number of concurrent preview generations (server#18210)
- Ldapi unix socket support (server#24574)
- Use mimetype from cache for workflow checks (server#25768)
- Cleanup old IE/edge properties and implement unsupported browser error page (server#26358)
- Remove the CAN_INSTALL file when occ maintenance:install is complete (server#27492)
- Align checksum dav property with desktop client parsing (server#28117)
- Do not setup a session when not required on API requests (server#28311)
- Nested ldap groups (server#30223)
- Harden disk_free_space check in CheckSetupController (server#30608)
- Add a background job to prune outdated sync tokens (server#31064)
- Add fallback routines for empty secret cases (server#31499)
- Fix Error: Undefined index: redirect_url (server#31947)
- Cleanup tags and share component (server#32012)
- Fix sync errors for card creation with the same uri from different sources (server#32057)
- Add repair command to fix wrong share ownership (server#32211)
- Bump @nextcloud/moment from 1.2.0 to 1.2.1 (server#32226)
- Bump nextcloud-vue-collections from 0.9.0 to 0.10.0 (server#32530)
- Modernize the error handler (server#32565)
- Fix a bunch of deprecation in the phpunit for core (server#32572)
- Fix User profile picture when performing the search (server#32635)
- [S3] Add option to specify an SSE-C customer provided key (server#32798)
- Cast to int (server#32838)
- Fix Uninitialized string offset 0 at GenerateMimetypeFileBuilder.php#39 (server#32859)
- Expose Doctrine support for persistent connections in PDO in Nextcloud settings (server#32899)
- Fix external storages access (server#33087)
- Federation - add logging, update the server status if sync fails (server#33104)
- Bump moment from 2.29.2 to 2.29.4 (server#33162)
- Update behat/behat requirement from ~3.10.0 to ~3.11.0 in /build/integration (server#33181)
- Improve container return type annotations (server#33388)
- Bump clipboard from 2.0.10 to 2.0.11 (server#33410)
- Fix photo url generation (add URI type to VCard2Array) (server#33450)
- Allow disabling object store write check (server#33458)
- Show version from appinfo on occ app:list (server#33482)
- Bump @testing-library/user-event from 14.1.1 to 14.4.3 (server#33488)
- Extract GPS data from EXIF (server#33511)
- Trigger a rescan when trying to fopen a file that exists in cache but not on disk (server#33566)
- Use cached getDisplayName method (server#33605)
- Remove the loop of calendars when only one is needed (server#33608)
- Use the updated mariadb10.6 container in drone (server#33631)
- Clean up paged result handling. (server#33703)
- Move guest.css to scss (server#33708)
- Use display name cache on getStorageInfo (server#33709)
- Bump webdav from 4.8.0 to 4.11.0 (server#33725)
- Makes untrusted domain error on info (server#33737)
- Bump guzzlehttp/guzzle from 7.4.5 to 7.5.0 in /build/integration (server#33884)
- Bump moment-timezone from 0.5.34 to 0.5.37 (server#33887)
- PublickKeyTokenProvider: Fix password update routine with password hash (server#33898)
- Replace vue2-datepicker with native date picker for share expiration dates (server#33915)
- LDAP to not register new users when outside of fair use or over limits (server#33945)
- Add pre commit config for cs fixer, EOF checks, etc (server#33984)
- Migrate TagMapper to QBMapper instead of deprecated Mapper (server#34038)
- L10n: Fix text string (server#34134)
- Fix āemail changedā activity email check (server#34135)
- On installation save channel to config.php if not stable (server#34136)
- Move avatar clearing in the background (server#34142)
- Do not store generated mysql password if it was not used (server#34152)
- Detect weird local ips (server#34160)
- User list : User name and Display name visibility improvement (server#34163)
- Add support for application/scim+json (server#34172)
- Bumped shipped apps list (server#34183)
Master is now 26 (server#34186)- Expose clearing the profiles and fix it (server#34188)
- Remove CoreBundle as we now ship the lat app that was referenced there (server#34190)
- DashBoard : Allow up to 5 widgets side by side (server#34191)
- Fix various theming bugs (server#34204)
- Fixing missing theming variables (server#34210)
- Fix loading custom background (server#34212)
- Add cache header for image endpoint if link previews (server#34215)
- Add fallback options for contacts array (server#34219)
- Make phpcs happy and remove unused setup thing (server#34220)
- Fix install page (server#34222)
- IncludeTags ā include_tags (server#34223)
- Fix node workflow error on master (server#34231)
- Compare cached filesize on download (server#34232)
- Bump nth-check and @vue/cli-service (server#34247)
- Ignore invalid share types (server#34248)
- Move Reference class to public namespace (server#34249)
- Remove unneeded and problematic vue-cli-plugin-unit-test (server#34260)
- Add endpoint to fetch a cachable reference data (server#34263)
- Bump versions to upgrade from (server#34267)
- Remove listeners to OC_Filesystem::(write|rename) old style hooks (server#34269)
- Add primary color presets for shipped backgrounds (server#34272)
- Fix highcontrast theme (server#34287)
- Fix focussing to internal link after copy (server#34288)
- Url encode the web dav url for copying (server#34289)
- Fix grid view button in public page (server#34292)
- Use color preset of shipped background as primary color (server#34298)
- Add color variables for text on blurred background (server#34299)
- Fix: Prevent deadlocks during mtime/size/etag propagation (server#34302)
- Fix default value for updatedirectory setting (server#34306)
- Fix user status emoji picking (server#34308)
- Remove unwanted settings button background (server#34311)
- Unbundle files_videoplayer and clean up a little (server#34313)
- Fix invisible status (server#34321)
- Only match http(s) URLs for references (server#34322)
- Update theming screenshots (server#34323)
- Fix starred favourite icon (server#34327)
- Correctly handle Redis::keys returning false (server#34328)
- Remove some constants and functions which have been long deprecated (server#34329)
- Fix ContactsStoreTests under PHP 8.2 (server#34330)
- Fix public view (server#34331)
- Fix the tertiary button text (server#34333)
- [master] Update psalm-baseline.xml (server#34336)
- Fix URLs on reference resolving (server#34339)
- Fix missing maintenance mode header for OCS request (server#34343)
- Ignore files which are modified by our tests (server#34344)
- Add .pre-commit-config.yaml to expected files in checker (server#34346)
- Fix renaming in shared with you file list (server#34348)
- Add a capability for the reference API and expose the regex to clients (server#34350)
- Reference url can always fallback to the link itself (server#34353)
- Rewrite admin theming in Vue (server#34359)
- Update OpenDyslexia to v0.91.12 (server#34363)
- Also use updatedir for cleanup of backups (server#34364)
- Add typings to OCP\Calendar\ICalendar and implementation (server#34376)
- Add isDeleted to OCP\Calendar\ICalendar (server#34378)
- Run session token renewals in a database transaction (server#34379)
- Feat(contacts): exclude contact from birthday calendar (server#34388)
- Fix positioning of the public page footer (server#34396)
- Pass logger to passwordless auth WebAuthn lib (server#34400)
- File reference: fallback icon to file type if no preview (server#34401)
- Wrap address book creation causal read in a transaction (server#34412)
- Fix causal reads in CalDAV backend (server#34415)
- Fix typo in deprecated (server#34421)
- Use default system primary (server#34437)
- Return proper error code when reporting exception fails in remote.php (server#34438)
- Fix reference preview when no server-side cache configured (server#34450)
- Fix missing background on upgrade (server#34461)
- [master] Update psalm-baseline.xml (server#34462)
- Reduce number of database queries during WebDAV propfind request (server#34471)
- Fix excessive increase of cachebuster value (server#34473)
- Show group name instead of group id as recommendation (server#34477)
- Fix hasBigIntConversionPendingColumns missing files_trash (server#34485)
- Fix typehints for generated migrations (server#34487)
- Typehint migrationservice closures (server#34488)
- Type closure to make psalm a bit happier (server#34489)
- Remove long depreated AppFramework/Db/Mapper (server#34490)
- Fix password length limitation (server#34500)
- Propagate attributes when resharing (server#34502)
- WebDAV - use file/folder name for dav:displayname (server#34508)
- Do not show editlocally on mobile (server#34513)
- [master] Update ca-cert bundle (server#34517)
- Also backport the cacert to stable25 (server#34521)
- Update security.txt expires field (server#34522)
- Avoid double ldap_unbind in Wizard.php (server#34523)
- Handle badly named version files more gracefully and log information (server#34528)
- Avoid allocating too much memory for the buffer on s3 uploads (server#34537)
- Bump @nextcloud/password-confirmation from 4.0.1 to 4.0.2 (server#34541)
- More flexible date validation (server#34544)
- Disable translucency on high contrast themes (server#34545)
- Add seperator in high contrast mode (server#34546)
- [master] Update psalm-baseline.xml (server#34548)
- Fix wrong types in phpdoc for twofactor registry (server#34554)
- Fix reading updater token for web updater (server#34558)
- Require token for local editing (server#34559)
- Fix TooManyArguments warning for carddav.php (server#34563)
- Fix TooManyArguments for FakeLockerPlugin (server#34565)
- Filter out backup user status (those beginning with _ as userId) (server#34569)
- Fix avatar menu icons in darkmode (server#34571)
- Make CI green again (server#34572)
- Add admin user customization kill switch (server#34576)
- Fix null error in getUnencryptedSize (server#34579)
- Fix file creation issue if no action are registered (server#34595)
- Scope the appdata theming storage for global and users (server#34599)
- Set theming app to alwaysEnabled (server#34609)
- Fix checkmark for theme settings in dark mode (server#34613)
- Fix regexp for unified searching in apps (server#34614)
- Fix logo not correctly inverted (server#34615)
- L10n: Fixed grammar (server#34618)
- Bump vue and vue-template-compiler (server#34619)
- Add a repair step to cleanup old theming cache (server#34620)
- [master] Update psalm-baseline.xml (server#34621)
- Bump jquery-ui-dist from 1.13.1 to 1.13.2 (server#34622)
- Update behat and friends (server#34623)
- Multiple fix for files external (server#34624)
- Fix icon of encrypted folders in filepicker (server#34625)
- Rename personal Groupware settings section to āAvailabilityā (server#34626)
- Various psalm fixes in files_sharing (server#34628)
- Fix case sensitivity of email when saving settings (server#34629)
- Disable automatic Dependabot rebases (server#34631)
- Add rate limiting on lost password emails (server#34632)
- Fix unnecessary highlighting of selected element (server#34634)
- Fix vertical alignment of user status icon (server#34636)
- Bump moment-timezone from 0.5.37 to 0.5.38 (server#34639)
- Revert minimum length for tags (server#34642)
- Bump exports-loader from 3.1.0 to 4.0.0 (server#34643)
Support postgres15 (server#34645)- Fix rebuild navigation (server#34650)
- Use proper error pages instead of always redirecting (server#34662)
- Update OCI workflow of server (server#34664)
- Invert header icons on bright preset backgrounds (server#34665)
- Bump jest-environment-jsdom from 29.0.3 to 29.2.1 (server#34668)
- Optimize background image migration job (server#34677)
- Interlace all output JPEG (server#34678)
- Display invalid input message (server#34683)
- Fix alternative logins custom css class (server#34685)
- Donāt crash with outdated share provider on update with the web updater (server#34688)
- Add backtrace to ldap profiler collector (server#34691)
- Allow to remove the background and select a custom colour + cypress (server#34696)
- Clean up LDAP Wizard typing (server#34702)
- Use vue lib multiselect tags component (server#34703)
- Update notifications for one-click instances (server#34706)
- Fix more icon color (server#34714)
- [master] Update psalm-baseline.xml (server#34717)
- Fix reading newly written encrypted files before their cache entry is written (server#34724)
- Fix autotest creating PostgreSQL database before install (server#34736)
- Add ico image/x-icon (server#34740)
- Only check unsupported browsers on user rendering (server#34741)
- Add .well-known/changepassword handler (server#34742)
- Extract $ignoreMaxApps from array_map callback in AppSettingsController (server#34745)
- Add Calendar settings section (server#34746)
- Revert āfix external storages accessā (server#34756)
- Port files_versions to vue (server#34769)
- Make sure to use AccessFactory to create Access instances and use DI (server#34772)
- Expose mapped user count from LDAP and use that for user limit check (server#34774)
- Do not throw errors when invalid setTo email is provided (server#34775)
- Update browser warning (server#34776)
- Fix disabled federated scope (server#34785)
- Check share attributes on preview endpoints (server#34788)
- Do not apply codestyle to composer autoloaders (server#34789)
- Emit typed event when preview is requested (server#34799)
- Skip general login with email for non-valid addresses and LDAP (server#34804)
- Compute notification parsed subject from rich subject when possible (server#34807)
- Fix getMetadata return type (server#34809)
- Fix some phpunit test warnings (server#34819)
- Fix empty content regressions in comments app (server#34825)
- L10n: Improve styling (server#34829)
- Continue registering and loading other dashboard widgets when one fai⦠(server#34831)
- Allow to conditionally enable dashboard widgets (server#34832)
- Fix size calculation on copying the skeleton files (server#34834)
- Rename LocalAddressChecker methods to lower case (server#34847)
- Add an hint about reasons why files canāt be accessed (server#34849)
- Add remote host validation API (server#34852)
- Disable browser translations (server#34858)
- Add logging to Scheduling Plugin (server#34865)
- Add new CS fixer cache file to .gitignore (server#34866)
- Update @nextcloud/dialogs and fix toasts styling (server#34868)
- Fix visibility of internal expire date (server#34871)
- Bump @nextcloud/event-bus from 2.1.1 to 3.0.2 (server#34879)
- Bump @babel/node from 7.17.10 to 7.20.0 (server#34880)
- Bump @nextcloud/calendar-availability-vue from 0.5.0-beta.2 to 0.5.0-beta.3 (server#34881)
- Bump phpunit/phpunit from 9.5.23 to 9.5.26 in /build/integration (server#34883)
- [master] Update psalm-baseline.xml (server#34884)
- Move iMIP to its own interface (server#34893)
- Add Talk converstation delete API (server#34894)
- Use the official phpDocumentor release (server#34895)
- Update 64-bit check wording (server#34906)
- Remove 32-bit workarounds (server#34907)
- Disable upgrades to 26 for 32-bit (server#34908)
- Fix duplicate event email notifications (server#34909)
- Added parameter to disallow calendar subscription via link (server#34920)
- Escape path prefix when doing cache jail search (server#34924)
- Clean up and deprecate app container parameter aliases (server#34929)
- [master] Update psalm-baseline.xml (server#34933)
- Read encrypted session data again on reopen (server#34934)
- Avoid a crash when a PHP extension has no version (server#34937)
- Add mastodon and reorganize profile info section (server#34940)
- Add a Group display name cache (server#34941)
- Dump autoloaders for new IHandleImipMessage (server#34954)
- Fix invalid date in security.txt (server#34963)
- Bump bamarni/composer-bin-plugin from 1.8.1 to 1.8.2 (server#34984)
- Bump @nextcloud/l10n from 1.4.1 to 1.6.0 (server#34985)
- Bump handlebars-loader from 1.7.1 to 1.7.2 (server#34986)
- [master] Update psalm-baseline.xml (server#34987)
- L10n: Shorten link (server#34989)
- [Performance] Test valid path only if file info has to be retrieved (server#34994)
- Bump microsoft/azure-storage-blob to 1.5.4 (server#34996)
- Drop PHP 7.4 on master (server#34997)
- Fix cron warning with time insensitive jobs (server#35000)
- Fix unsuccessful token login logged as error (server#35007)
- Check quota on file copy (server#35009)
- Fix rendering of login headline (server#35014)
- Appropriate length check in Notification.php (server#35015)
- Deprecate PHP7.4 (server#35024)
- Fix missing share icon (server#35027)
- Fix DNS Pin Middleware throwing for public IPs (server#35028)
- Fix AppMenu icons for firefox (server#35029)
- Fix dashboard scrolling (server#35033)
- Add description for calendar uri (server#35042)
- Update crl after revoke drawio.csr (server#35043)
- Fix sidebar not automatically hidden in Files app (server#35052)
- Fix HTML entities not decoded in comment just added (server#35054)
- Add brute force protection on all methods wrapped by PublicShareMiddleware (server#35057)
- Fix top margin in empty versions list (server#35063)
- [LDAP] always create instance of own user manager (server#35070)
- Add alt to the logo, adapt css for logo (server#35071)
- Make sure that path is normalized and then checked, (server#35074)
- Remove reference to Redis sentinel from configuration docs (server#35075)
- Bump swiftmailer/swiftmailer to 6.3.0 (server#35076)
- Fix PublicKeyTokenProviderTest import and mock (server#35077)
- Close global search menu when keyboard focus leaves (server#35090)
- Allow single character search by default (server#35091)
- Run integration tests on 3rdparty bump (server#35093)
- Mark more config values as sensitive (server#35096)
- Improve email results for sharing (server#35097)
- Fix distorted previews when using imaginary (server#35105)
- Add migration for encryption keys in wrong location (server#35107)
- Allow running encryption:fix-encrypted-version for all users (server#35108)
- Bump sass-loader from 12.6.0 to 13.2.0 (server#35119)
- Bump @vue/test-utils from 1.3.0 to 1.3.3 (server#35120)
- Revert āAppropriate length check in Notification.phpā (server#35139)
- Update CODEOWNERS (server#35142)
- Add pull request template with checklist (server#35143)
- Fix devcontainer url (closing #35145) (server#35146)
- Place
<h1>into main content (server#35147) - Fix dynamic properties and other problems in tests for PHP 8.2 (server#35156)
- Make sure to not pass null to DateTime::createFromFormat (server#35157)
- Disable style override on vue-select elements (server#35165)
- User status dialog a11y: make different focus and active state (server#35170)
- Add test for received share in share_folder (server#35173)
- Add text/asciidoc mimetype (server#35176)
- Restoring clearCachedConfig() (server#35177)
- Bump @nextcloud/vue to 7.1.0-beta0 (server#35179)
- Fix more tests for PHP 8.2 (server#35181)
- Generate user themed icons (server#35182)
- Fix s3 directory copy (server#35184)
- Hide warning about missing apps for when shipped in the next version (server#35185)
- Fix missing native submit type from OAuth client add button (server#35186)
- Fix mentions rendering in comment editor (server#35187)
- Fix github action āperformance-8.0ā when PR is from a fork. (server#35192)
- [master] Update psalm-baseline.xml (server#35194)
- Default Jpeg quality to 80 (server#35203)
- Fix forwarding the object id when searching comments (server#35206)
- Fix sharing expiration date handling and saving (server#35207)
- Fix settings for setting default expiration date (server#35210)
- Honor permissions of new link share via OCS API (server#35213)
- Delay updating setup providers untill we register the mounts (server#35218)
- Fix contrast of global search headings (server#35222)
- Smaller performance optimizations (server#35223)
- Drop deprecated node-sass (server#35224)
- Do not auto merge package-lock.json, but treat as text file (server#35225)
- Only setup redis connection if needed (server#35226)
- Limit toggle grid view button scope (server#35227)
- User_ldap - Cache group display name even if it was not filled (server#35228)
- Use a dedicated LDAP host and port for background jobs if configured (server#35229)
- Log switching to LDAP backup host because main one is not available (server#35230)
- Cache the fetched list of groups (server#35231)
- Bump doctrine/dbal to 3.3 in master (server#35234)
- Copy to clipboard with button instead of link (server#35240)
- [master] Update psalm-baseline.xml (server#35241)
- Set page title for each sidebar section through App management pages (server#35249)
- Increase the fair-use push limit to 1.000 users (server#35251)
- Fix warnings in dev mode on login page (server#35253)
- Set page titel for each sidebar section through User management pages (server#35257)
- Also cancel XHR when cancelling uploads (server#35259)
- Remove completed comments (server#35269)
- Show success on share actions (server#35271)
- Add label to sharing search field (server#35272)
- Prevents the selection of encrypted folders when clicking on the āSelect allā checkbox (server#35299)
- Generate proper URL for unsupported browsers page (server#35302)
- Donāt use quota cache through user management (server#35308)
- Help pages: set window title for sidebar sections (server#35309)
- Fix border color contrast (server#35315)
- Bump engine.io and socket.io (server#35316)
- [master] Update psalm-baseline.xml (server#35317)
- Remove potential mismatching dav session data during login (server#35318)
- Fix navigation order (server#35325)
- Skip files that cant be opened for FixEncryptedVersion (server#35337)
- Feat: add event for failed logins (server#35345)
- Fix user settings layout (server#35350)
- Update cache when file size === 0 (server#35353)
- Allow to set a custom timeout for ldap connections (server#35355)
- Add repair job that will ensure that secret and passwordsalt are set (server#35368)
- Fix UX of renaming token (server#35370)
- Run s3 primary tests sequential (server#35376)
- Fix remaining user settings issues (server#35380)
- Fix PHP lint CI failure (server#35383)
- Fix type of PreviewController::$userId (server#35385)
- Use correct filter for app icons in the right sidebar of app management (server#35389)
- Update vue to v7.1.0-beta.2 (server#35393)
- Do not check quota for non Node (server#35398)
- Fix share admin page (server#35399)
- Fix name of dymanic var $mountOptions to fix PHP 8.2 compatibility (server#35400)
- Fix theming tests for PHP 8.2 (server#35403)
- Bump laravel/serializable-closure to 1.2.2 in master (server#35405)
- More appropriate wording for background selection (server#35407)
- Fix login loop if login CSRF fails and user is not logged in (server#35419)
- Minimum desktop client that is supported is 2.3.0 (server#35425)
- Cleanup contactsinteraction (server#35426)
- Fix update for 32-bit (server#35434)
- Add success popup message for copying share links (server#35437)
- Fix multiline-format-error in file-conflict modal (server#35442)
- Change header semantic in the user status dialog (server#35455)
- Bump egulias/email-validator to 3.2.1 in master (server#35468)
- Allow upgrading from ownCloud 10.11 (server#35471)
- Fix the popovermenu (server#35484)
- Remove Bootstrap version reference from tooltip.scss (server#35485)
- Remove old code from comment to not trigger automatic scanners more than needed (server#35494)
- Strict typing lib/base.php (server#35496)
- Change app menu focused items behavior that neighbor elements (text and border) have no overlapping (server#35501)
- Fix SQL comparison with int array during external storage deletion (server#35502)
- [BUGFIX] Prevents the selection of encrypted files at the bottom of the list(before scrolling) (server#35521)
- Faster theming tests, better colours comparison and properly follow admin theming changes (server#35525)
- Improve verbosity of search description (server#35529)
- Bump @nextcloud/vue to 7.1.0 (server#35530)
- Revert āCopy to clipboard with button instead of linkā (server#35533)
- Language fixes in example config (server#35534)
- Improve dependency injection error message (server#35537)
- Add styles for #33741. Remove boards and add underlines. (server#35545)
- Delete the --image-background-size variable (server#35547)
- Add new border color variable and adjust primary color for increased contrast (server#35549)
- Bump decode-uri-component from 0.2.0 to 0.2.2 (server#35550)
- Revert unrelated change from #34940 (server#35556)
- Extend reference API for (future) frontend picker (server#35557)
- Remove obsolete GD function overwrites (server#35560)
- Read loginName from token (server#35562)
- Revert āFix border color contrastā (server#35563)
- Preview: respect quality in Imaginary (server#35566)
- Bump behat/behat from 3.11.0 to 3.12.0 in /build/integration (server#35568)
- [master] Update ca-cert bundle (server#35571)
- Handle possible null value for file in OC\Files\SimpleFS\NewSimpleFile (server#35576)
- Downgrade ubuntu in order to fix CI (server#35580)
- Replace getSystemValue with getSystemValueString in Util.php (server#35586)
- Replace getSystemValue in encryption app (server#35590)
- Bump sass from 1.52.1 to 1.56.1 (server#35592)
- Use TimedJob from OCP instead of OC (server#35596)
- Fix migration to non-empty secret (server#35600)
- Document frontend sass compilation (server#35603)
- Fix default redirect on successful WebAuthn login (server#35604)
- Add section-id and section-type data attributes to settings
- navigation items (server#35609)
- Adjust branding of errorlog log messages (server#35612)
- Change mail icon to the material design icon (server#35613)
- Fix array to string conversion in errorlog writer (server#35614)
- [master] Update psalm-baseline.xml (server#35615)
- Explicitly inherit stricly typed database schema closure of migrations (server#35618)
- Fix errors in calendar tests saying function handleIMipMessage does n⦠(server#35620)
- Allow additional Sabre plugins in publicwebdav.php (server#35621)
- Automatically build sass and sass:icons after build (server#35622)
- Fix profile visibility not appearing (server#35628)
- Docs: document types flag for search options (server#35632)
- Update update-psalm-baseline workflow for NC25 (server#35635)
- Focus trap contacts menu with NcHeaderMenu port (server#35637)
- Update the unencrypted file size when closing streams (server#35649)
- Ci: update minio image for s3 primary storage tests (server#35653)
- Replace custom tooltips with native one in vue components and views (server#35655)
- Docs: add design contribution guidelines (server#35656)
- Increase default global input field border contrast (server#35660)
- [master] Update psalm-baseline.xml (server#35662)
- Revert āDisable style override on vue-select elementsā (server#35665)
- Invert header if primary is bright and background disabled (server#35666)
- Allow target=ā_blankā in apps navigation items (server#35667)
- Updte handlebars-loader to 1.7.3 (server#35672)
- Catch NotFoundException as well in JSCombiner (server#35679)
- Take out stable23 from dependabot config (server#35686)
- Preview: fix HEIC orientation (server#35689)
- Bump jsdoc from 3.6.10 to 4.0.0 (server#35693)
- Bump karma-spec-reporter from 0.0.34 to 0.0.35 (server#35695)
- Bump handlebars-loader from 1.7.2 to 1.7.3 (server#35700)
- Update sensitive config list of Talk (server#35705)
- Fix vue-select styles (server#35714)
- Bump @nextcloud/vue to 7.2.0 (server#35717)
- Bump @testing-library/jest-dom from 5.16.4 to 5.16.5 (server#35718)
- Bump phpunit/phpunit from 9.5.26 to 9.5.27 in /build/integration (server#35719)
- Fix: Make sure to reopen session before cleaning (server#35723)
- Switch logical operators (server#35739)
- Update README main screenshot (server#35745)
- Add app config for default template path (server#35759)
- Remove comment and guests option from Invitations UI (server#35761)
- L10n: Make productname/version info bold in update notification (server#35769)
- Port Files navigation to vue (server#35772)
- [PHP8] check if params given to API are really an array (server#35779)
- Fix missing cast of double controller parameters (server#35780)
- Inject services into controller methods (server#35783)
- Make the LoginController strict (server#35784)
- Replace custom tooltips with native one for files sharing (server#35785)
- Rename SabrePublicPluginEvent to BeforeSabrePubliclyLoadedEvent (server#35789)
- Replace custom tooltips with native ones in files (server#35795)
- Bump phpseclib/phpseclib to 2.0.40 in master (server#35813)
- Fix parameter type for EntityCollection::setReadMarker in comments app (server#35814)
- Avoid using the word āpasswordā in the APP_TOKEN_CREATED activity (server#35820)
- Fix PHP error on PHP >= 8.2 about dynamic property use in tests (server#35828)
- Fix: remove other shares from ui when deleted (server#35836)
- Apply a longer TTL of 15min to falling back on backup server (server#35839)
- Doc: add description how BackgroundCleanupJob.getNewPreviewLocations works (server#35844)
- [master] Update psalm-baseline.xml (server#35846)
- Add DESIGN.md to expected files (server#35855)
- Increase preview_max_memory and make it easier to debug (server#35856)
- Fix(session): Always setup the session if a session cookie is passed (server#35866)
- Refine file comments design (server#35870)
- Add option to return an exit-code when occ status signals an update is needed (server#35873)
- Adding option to set Auto-Submitted email header (server#35876)
- Improve sample.config.php parameter descriptions (server#35881)
- Checkout current branch in cypress tests in CI (server#35889)
- Avatar generation - disable setimageformat (server#35891)
- Replace custom tooltips with native ones in users page (server#35893)
- Fix moving files of encrypted local storage to unencrypted local storage (server#35894)
- Fix video fullscreen on public page (server#35897)
- Replace custom tooltips with native tooltips in personal and administration settings (server#35901)
- Replace custom tooltips with native ones in apps page (server#35903)
- Chore(actions): update php min supported to 8.0 (server#35911)
