### How to use GitHub
* Please use the 👍 [reaction](https://blog.github.com/2…016-03-10-add-reactions-to-pull-requests-issues-and-comments/) to show that you are affected by the same issue.
* Please don't comment if you have no relevant information to add. It's just extra noise for everyone subscribed to this issue.
* Subscribe to receive notifications on status change and new comments.
### Steps to reproduce
1. add a folder to external storage
### Expected behaviour
to have my user/groups in "Available for" field
### Actual behaviour
No user or groups
### Server configuration
**Operating system:**
freenas jail 11.3-RELEASE-p12
**Web server:**
Apache2
**Database:**
Mariadb
**PHP version:**
7.4
**Nextcloud version:** (see Nextcloud admin page)
20.0.0
**Updated from an older Nextcloud/ownCloud or fresh install:**
fresh
**Where did you install Nextcloud from:**
nextcloud.com
**Signing status:**
<details>
<summary>Signing status</summary>
Login as admin user into your Nextcloud and access
http://example.com/index.php/settings/integrity/failed
No errors have been found.
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
- accessibility: 1.6.0
- activity: 2.13.1
- bruteforcesettings: 2.0.1
- calendar: 2.1.2
- cloud_federation_api: 1.3.0
- comments: 1.10.0
- contacts: 3.4.0
- contactsinteraction: 1.1.0
- dashboard: 7.0.0
- dav: 1.16.0
- federatedfilesharing: 1.10.1
- federation: 1.10.1
- files: 1.15.0
- files_external: 1.11.1
- files_pdfviewer: 2.0.1
- files_rightclick: 0.17.0
- files_sharing: 1.12.0
- files_trashbin: 1.10.1
- files_versions: 1.13.0
- files_videoplayer: 1.9.0
- firstrunwizard: 2.9.0
- logreader: 2.5.0
- lookup_server_connector: 1.8.0
- mail: 1.5.0
- nextcloud_announcements: 1.9.0
- notifications: 2.8.0
- oauth2: 1.8.0
- password_policy: 1.10.1
- photos: 1.2.0
- privacy: 1.4.0
- provisioning_api: 1.10.0
- recommendations: 0.8.0
- richdocuments: 3.7.4
- serverinfo: 1.10.0
- settings: 1.2.0
- sharebymail: 1.10.0
- spreed: 10.0.0
- support: 1.3.0
- survey_client: 1.8.0
- systemtags: 1.10.0
- text: 3.1.0
- theming: 1.11.0
- twofactor_backupcodes: 1.9.0
- updatenotification: 1.10.0
- user_status: 1.0.0
- viewer: 1.4.0
- weather_status: 1.0.0
- workflowengine: 2.2.0
- admin_audit
- encryption
- user_ldap
</details>
**Nextcloud configuration:**
<details>
<summary>Config report</summary>
"10.0.0.48",
"nextcloud.aivallecrosia.com"
"dbtype": "mysql",
"version": "20.0.0.9",
"overwrite.cli.url": "http:\/10.0.0.48",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0
"0": [
"path": "\/usr\/local\/www\/nextcloud\/apps",
"url": "\/apps",
"writable": true
"path": "\/usr\/local\/www\/nextcloud\/apps-pkg",
"url": "\/apps-pkg",
"writable": false
</details>
**Are you using external storage, if yes which one:local
**Are you using encryption:** no
**Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/...
Insert your webserver log here
</details>
#### Nextcloud log (data/nextcloud.log)
<details>
<summary>Nextcloud log</summary>
{"reqId":"XLW0XDp5nAvDJgY5LwG0","level":3,"time":"2020-10-05T10:58:20+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#187","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":187,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"XLW0XDp5nAvDJgY5LwG0","level":3,"time":"2020-10-05T10:58:20+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#188","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":188,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"XLW0XDp5nAvDJgY5LwG0","level":3,"time":"2020-10-05T10:58:20+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"index","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Exception","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":110,"Previous":{"Exception":"TypeError","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":191,"function":"strpos"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","Line":191},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"qw4gq8v7lKnZ8aT71TFp","level":3,"time":"2020-10-05T10:58:31+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#187","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":187,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"qw4gq8v7lKnZ8aT71TFp","level":3,"time":"2020-10-05T10:58:31+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#188","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":188,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"qw4gq8v7lKnZ8aT71TFp","level":3,"time":"2020-10-05T10:58:31+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"index","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Exception","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":110,"Previous":{"Exception":"TypeError","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":191,"function":"strpos"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","Line":191},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"2RorscnaO1kaqrhG3fTv","level":3,"time":"2020-10-05T11:04:42+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#187","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":187,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"2RorscnaO1kaqrhG3fTv","level":3,"time":"2020-10-05T11:04:42+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"PHP","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Error","Message":"Undefined offset: 0 at /usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php#188","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":188,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"2RorscnaO1kaqrhG3fTv","level":3,"time":"2020-10-05T11:04:42+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"index","method":"GET","url":"/index.php/settings/admin/serverinfo","message":{"Exception":"Exception","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":110,"Previous":{"Exception":"TypeError","Message":"strpos() expects parameter 1 to be string, null given","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","line":191,"function":"strpos"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Os.php","line":132,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\OperatingSystems\\FreeBSD","type":"->"},{"file":"/usr/local/www/nextcloud/apps/serverinfo/lib/Settings/AdminSettings.php","line":111,"function":"getNetworkInterfaces","class":"OCA\\ServerInfo\\Os","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":141,"function":"getForm","class":"OCA\\ServerInfo\\Settings\\AdminSettings","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":83,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php","line":152,"function":"getSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/apps/settings/lib/Controller/AdminSettingsController.php","line":68,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/usr/local/www/nextcloud/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/usr/local/www/nextcloud/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/usr/local/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/usr/local/www/nextcloud/apps/serverinfo/lib/OperatingSystems/FreeBSD.php","Line":191},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
{"reqId":"pQl9QfmhAgI6hn7e2KtK","level":4,"time":"2020-10-05T12:37:42+00:00","remoteAddr":"192.168.1.254","user":"Flavio","app":"ocs_api","method":"POST","url":"/ocs/v2.php/cloud/users","message":"Failed addUser attempt: User already exists.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.121 Safari/537.36","version":"20.0.0.9"}
</details>
#### Browser log
<details>
<summary>Browser log</summary>
Insert your browser log here, this could for example include:
a) The javascript console log
b) The network log
c) ...
</details>
