Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 29.0.5): 29.0.3
Operating system and version (eg, Ubuntu 24.04): Ubuntu 24.04 LTS
Apache or nginx version (eg, Apache 2.4.25): 2.4.61
PHP version (eg, 8.3): 8.3
Permissions issues when adding an external drive formatted NTFS. Nextcloud is unable to see the drive path: (ex: /media/user/shuttle/). If I just put “/media/user/” the red exclamation turns to a green check but the folder created in Nextcloud does not show any of the folders or files on the drive and says I do not have permission to create or edit anything in the folder. NTFS is a requirement for me as I have multiple drives with data on them already that I will be connecting to this machine.
Steps I’ve taken:
I followed Nextcloud’s documentation and changed ownership with
Sudo chown -R www-data:www-data /media/user/shuttle
and
Sudo chmod -R 0750 /media/user/shuttle
- this unfortunately left me unable to access the drive at all outside of Nextcloud and Nextcloud still did not see the drive path.
To get access back I set it back to default (I think) with:
sudo chown -R root:root /media/user/shuttle
and
sudo chmod -R 0777 /media/user/shuttle
I’ve read through a a few similar posts here about this permissions issue. I’ve followed @szaimen 's solution here about it Add NTFS drive as external storage with no luck.
/etc/fstab currently has:
$UUID /media/user/shuttle ntfs-3g windows_names,uid=33,gid=33,umask=770 0 0
I used the drive’s UUID at the beginning and uid/gid of 33 in place of www-data as instructed in the post by @Fab mentioned here You don't have permissions to upload or create files here - local (external ntfs-3g storage)
*note the difference of umask=770 on mine because 007 makes the drive completely inaccessible outside of Nextcloud
Is this the first time you’ve seen this error? (Y/N): Y - It’s my first time attempting it.
- Green check if I use the partial path /media/user (permission denied/directory listing failed error in log)
- red exclamation if I try the path of any folder on the drive or the drive name (ex: /media/user/shuttle) (storage path does not exist error in log)
Error files_external
StorageNotAvailableException Local storage path does not exist "/media/****/shuttle/"
"Jul 9, 2024, 1:47:49 PM"
Error webdav
ServiceUnavailable Directory listing failed
"Jul 9, 2024, 1:46:42 PM"
Error PHP
opendir(/media/****/): Failed to open directory: Permission denied at /var/www/nextcloud/lib/private/Files/Storage/Local.php#164
Error webdav
Error PHP
