Nextcloud version (20.0.1 ):
Operating system and version ( CentOS Linux 7):
Apache or nginx version ( Apache 2.4.25):
PHP version (7.3):
{"reqId":"KUcK5TQOJhi6zJOOpKnp","level":3,"time":"2020-11-04T06:22:48+00:00","remoteAddr":"144.52.134.28","user":"Admin","app":"PHP","method":"GET","url":"/index.php/apps/files/","message":{"Exception":"Error","Message":"Undefined offset: 3 at /home/www/wwwroot/www.yc18.top/lib/private/legacy/OC_Helper.php#548","Code":0,"Trace":[{"file":"/home/www/wwwroot/www.yc18.top/lib/private/legacy/OC_Helper.php","line":548,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[8,"Undefined offset: 3","/home/www/wwwroot/www.yc18.top/lib/private/legacy/OC_Helper.php",548,{"path":"/","rootInfo":{"__class__":"OC\\Files\\FileInfo"},"includeExtStorage":false,"used":387788070,"quota":-3,"mount":{"__class__":"OC\\Files\\Mount\\MountPoint"},"storage":{"cache":null,"scanner":{"__class__":"OC\\Files\\Cache\\Scanner"},"watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\Files_Trashbin\\Storage"},"sourceStorage":{"cache":null,"scanner":{"__class__":"OC\\Files\\Cache\\Scanner"},"watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\Files_Trashbin\\Storage"},"free":169337729024,"total":169725517094,"relative":0.23,"ownerId":"Admin","ownerDisplayName":"Admin","owner":{"__class__":"OC\\User\\User"}}]},{"file":"/home/www/wwwroot/www.yc18.top/apps/files/lib/Controller/ViewController.php","line":139,"function":"getStorageInfo","class":"OC_Helper","type":"::","args":["/",{"__class__":"OC\\Files\\FileInfo"}]},{"file":"/home/www/wwwroot/www.yc18.top/apps/files/lib/Controller/ViewController.php","line":187,"function":"getStorageInfo","class":"OCA\\Files\\Controller\\ViewController","type":"->","args":[]},{"file":"/home/www/wwwroot/www.yc18.top/lib/private/AppFramework/Http/Dispatcher.php","line":169,"function":"index","class":"OCA\\Files\\Controller\\ViewController","type":"->","args":["","",null,false]},{"file":"/home/www/wwwroot/www.yc18.top/lib/private/AppFramework/Http/Dispatcher.php","line":100,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Files\\Controller\\ViewController"},"index"]},{"file":"/home/www/wwwroot/www.yc18.top/lib/private/AppFramework/App.php","line":152,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Files\\Controller\\ViewController"},"index"]},{"file":"/home/www/wwwroot/www.yc18.top/lib/private/Route/Router.php","line":308,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Files\\Controller\\ViewController","index",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"action":null,"_route":"files.view.index"}]},{"file":"/home/www/wwwroot/www.yc18.top/lib/base.php","line":1009,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/files/"]},{"file":"/home/www/wwwroot/www.yc18.top/index.php","line":37,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/home/www/wwwroot/www.yc18.top/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.111 Safari/537.36 Edg/86.0.622.61","version":"20.0.1.1","id":"5fa249e122001"}
How can I solve it?
