Hi all, I’m out of ideas. I tried to install the newest docker ncp and started the container. But the docker logs always comes with the following text: Nextcloud is not installed - only a limited number of commands are available and subsequent with: There are no commands defined in the “config:system” namespace.
After activation the WebUI shows: NextCloudPi not yet initialized, trying again in a few seconds … it ran for more than 8 hours (during night) and still no forward to the ncp login page, rather than the nextcloud login page.
If I dispaly nc-info within the container everything looks good, except the line with the datadir (doesn’t exist), but data has been written to the directory specified
I’m running a cubietruck with armbian buster 20.08.7 and a Raspberry PI with RPi OS (buster) August 2020 edition. Both have the same issue!
I start the container as follows:
sudo docker run -d -p 4443:4443 -p 443:443 -p 80:80 -v /data/ncdata:/data --restart unless-stopped --name nextcloudpi ownyourbits/nextcloudpi-armhf myip
Maybe there are some hints I need to follow, so any help or feedback is much appreciated.
