Cronjob problem and admin name
Hi there,
I have a problem with my cronjob. It’s not working.
I use the official docker and try to use additionally the cronjob docker on my unraid installation.
I noticed that on the basic settings it says that the user to launch the cronjob is <<>>.
Also when I launch the console of my nextcloud docker it says “I have no name!”.
But I manage to call the cron.php file anyway.
Could you help me?
NC 37.0.1
OS : Unraid 6.12.11
Web server : Apache (i think)
PHP : the version in nextcloud docker (i think)
At the initial config i have this error
Cloudflare tunnel
Hello @JacksDice, welcome to the community of Nextcloud :handshake:
You started a topic in support category. Unfortunately you ignored the template and a lot of information to help you is missing. Please edit your original post and add all required details like compose file, Nextcloud version, webserver type and version, os version, related log file content. Use the support template. Without additional information the community members cannot help you.
the recommended way to run NC background tasks in Docker is a “sidecar” container - review Nextcloud Docker Container - best way to run cron job or Docker .examples or docker-compose-setup-with-notify-push-2024 for details. You’ll find many relatedtopics following respective tags e.g. cron docker or both together Topics tagged cron & docker
Regards,
wwe
Hello wwe.
I will correct that.
Sorry for my mistakes.
is that enough ?
what do you think? could anybody know how you setup your system from this details?
I think no. which docker image, how it is setup - everything is missing. please review the support template and the links I shared.
OK i will edit with the template. Sorry again for your waste of time.
