Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): Nextcloud Hub 3 (25.0.1)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): 7.4.3
Overview mentions cron configuration as seen below. I have appended some config to config.php as stated in instructions but still shows. I believe the folder is owned correctly. Thanks
Is this the first time you’ve seen this error? (Y/N): N it has been there since beginning
A lot of Identifiable information here?
'instanceid' => 'xxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxx',
'secret' => '',
0 => 'xxxxxxxxxx',
'datadirectory' => '/var/www/nextcloudxxxxxxxxx/data',
'version' => '25.0.1.1',
'overwrite.cli.url' => 'https://xxxxxxxxxx',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxxxxxxxxx',
'dbpassword' => 'xxxxxxxxxx',
'default_phone_region' => 'UK',
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'xxxxxxxxxx',
'mail_domain' => 'xxxxxxxxxx',
'mail_smtpauth' => 1,
'app_install_overwrite' =>
0 => 'files_external_sia',
1 => 'backup',
2 => 'breezedark',
'twofactor_enforced' => 'true',
0 => 'xxxxxxxxxx',
1 => 'xxxxxxxxxx',
PASTE HERE
