Sorry not sure then… Maybe you can also search through the issues on GitHub and similar threads in the forums. Lately I noticed an accumulation of users who seem to have issues with cornjobs on NC25. So far I have only updated my test instance to NC25, and cron continued to work, without any issues…
this is how i need my command:
*/5 * * * * php --define apc.enable_cli=1 -f /var/www/nextcloud/cron.php
i was doing this before as it says to append it to the command. So novice here was putting --define apc.enable_cli=1 after the file path like this
*/5 * * * * php -f /var/www/nextcloud/cron.php --define apc.enable_cli=1
and also tried this one that didnt work
*/5 * * * * php -f --define apc.enable_cli=1 /var/www/nextcloud/cron.php
but these are clearly all lack of linux knowledge as the issue!
