Hi
My issue :
I had an DAVdroid account connecting to Nextcloud 12.0.4 (Or 12.0.3) and working fine.
I had to remove the account as I was moving domain (following the guide “moving-nextcloud-installation-from-one-domain-to-another”) but I can’t reconnect DAVdroid now. It now fails with error message (translated) “Configuration detection - No access to CalDAV or CardDAV services”. The DAVdroid debug shows “405 error - Method not allowed”.
The only thing I did appart from moving domain was playing with “Devices Token” but I am now using my main login and password for DAVdroid.
Web access, Nextcloud client on windows and Android works fine with main login
I did test on demo nextcloud com and it works, DAVdroid shows the next screen proposing to create an account on the phone
Any help is appreciated !
Ore
Nextcloud version : 12.0.4
Operating system and version : Linux based
Apache or nginx version : Unknown
PHP version : 7.0
Is this the first time you’ve seen this error?: Yes
Can you reliably replicate it? (If so, please outline steps): Yes
*Open DAVdroid
*click add an account
*type in the URL : [MY-DOMAIN]/remote.php
*login : main nextcloud login (user on web interface)
*click submit, after a while, the error message appears.
DAVdroid Version: 1.9.5-ose, uninstalled and reinstalled after reboot as per their FAQ.
The output of your Nextcloud log in Admin > Logging: https://framabin.org/?6f86181b7ae6949e#maVOBZGHNdvCXa27mI9wseNn6L+RjtDz2J+0cC0BhUQ=
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => '[MY-DOMAIN]',
'datadirectory' => '/home/[USERNAME]/nextcloud/data',
'overwrite.cli.url' => '[MY-DOMAIN]',
'version' => '12.0.4.3',
'dbname' => '[DB]',
'dbhost' => '[DB-HOST]',
'dbuser' => '[DB-USER]',
'dbpassword' => '[DB-PWD]',
'logtimezone' => 'UTC',
'theme' => '',
'loglevel' => 0,
'mail_domain' => '[EMAIL-DOMAIN]',
'mail_from_address' => '[EMAIL-LOGIN]',
'mail_smtpmode' => 'php',
The output of your Apache/nginx/system log in /var/log/____: https://framabin.org/?3689495fe946ab94#cHlh2mllTKQkd4twCgMXBqQ74IMzhAzCzufgEu0Sh2c=
DAVDroid log : https://framabin.org/?ce86170e5b9c6699#bemYhzfQG9zGa9LrwKVlwBuJZuSVApH6a2Gwuq3ZCC0=
