Connection timeout with Collabora Office
Error:
Failed to connect to the remote server: cURL error 28: Connection timed out after 5002 milliseconds (see libcurl - Error Codes) for https://nc.example.com/custom_apps/richdocumentscode/proxy.php?req=/hosting/discovery.
When downloading odt, docx, excel… files. infinite download. I realized that I need to install collabora office from the app store (My docker collabora container is running).
I think the built-in CODE for small tasks will be enough for me.
At first I was getting timeout errors due to collabora, but they were fixed by increasing the timeout in the nextcloud container configuration. But now I am getting the same error above
I am behind NAT (Any access from local network to my external ip will fail). Normal connection speed is ~20 Mbps
/etc/hosts:
127.0.0.1 localhost
127.0.1.1 servername
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
# Added by Docker Desktop
# To allow the same kube context to work on the host and the container:
127.0.0.1	kubernetes.docker.internal
# End of section
$ curl -vvvv https://$NC_DOMAIN:443/hosting/discovery (from nextcloud container)
* Host nc.example.com:443 was resolved.
* IPv6: (none)
* IPv4: 91.xxx.xxx.37
*   Trying 91.xxx.xxx37:443...
* connect to 91.xxx.xxx.37 port 443 from 172.20.0.8 port 53080 failed: Operation timed out
* Failed to connect to nc.example.com port 443 after 136063 ms: Could not connect to server
* closing connection #0
curl: (28) Failed to connect to nc.example.com port 443 after 136063 ms: Could not connect to server
$ curl -vvvv https://$NC_DOMAIN:443/standalone-signaling/api/v1/welcome (from nextcloud container)
* IPv6: (none)
*   Trying 91.xxx.xxx.37:443...
* connect to 91.xxx.xxx.37 port 443 from 172.20.0.8 port 58006 failed: Operation timed out
* Failed to connect to nc.example.com port 443 after 136231 ms: Could not connect to server
curl: (28) Failed to connect to nc.example.com port 443 after 136231 ms: Could not connect to server
I’m inexperienced in networking, so please point out what’s wrong, I’d be very grateful!
Ubuntu server 24.04 LTS, Nextcloud AIO 29.0.6.
Looks like this is your issue. Most likely your router or networking infrastructure does not allow the container to connect to its domain via the external ip-address.
You can fix this by following GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
That helped, I configured dnsmasq.
But now I got a new errors
Could not find urlsrc for application/vnd.openxmlformats-officedocument.wordprocessingml.document in WOPI discovery response
and
Didn't find urlsrc for mimetype application/vnd.openxmlformats-officedocument.wordprocessingml.document in this WOPI discovery response: <html><body> <h1>Socket proxy error</h1> <p>Error: no_glibc</p> </body></html
installed everything according to the instructions
I checked Callabora Office when installing, the container started successfully on port 9980.
Some say to downgrade the richdocuments version, others say to wait…
Apparently there is something with “no_glibc”, I’m not familiar with php, I don’t understand what this could mean
no_glibc and the URL ../custom_apps/richdocumentscode/proxy.php?req=/hosting/discovery makes me think you mix up installation methods. similar to Built-in CODE error: Didn't find urlsrc for mimetype application AiO doesn’t use built-in CODE (and the respective app in not required) it runs separate CODE container and the CODE URL configured in Nextcloud Office settings should be https://cloud.mydomain.tld/hosting/discovery which in turn must be accessible from the cloud and client as described in Collabora integration guide…
