Connection issue between Nextcloud and Coturn installed on two different servers.
Hello
I have a connection issue between Nextcloud Talk and Coturn. When both are installed on the same server, the solution works well internally and externally (with Nextcloud published using a domain). However, after separating them onto two different servers, I can no longer make calls externally, although it still works internally.
Hello there ,
welcome to the community of Nextcloud.
You started a topic in support category.
Unfortunately you ignored the template and a lot of information to help you is missing.
Please add all necessary information like Nextcloud version, webserver type and version, os version, related log file content.
Use the support template.
Without additional information the community members cannot help you.
Regards,
wwe
