Collabora integration not working hosting/discovery not found
I’m reading Collabora integration guide
According the troubleshooting checklist I open https://office.mydomain/hosting/discovery
But this page cannot be found.
How do I continue?
  • Nextcloud Server version:
    • Nextcloud 31.0.6
    • #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30)
  • Web server and version:
    • Server version: Apache/2.4.62 (Debian)
  • Reverse proxy and version:
    • nginx version: openresty/1.27.1.1
  • PHP version:
    • PHP 8.3.22 (cli) (built: Jun 11 2025 00:56:01) (NTS)
    • yes
    • prob direct after installation
    • OMV Container
    • nope
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
            "srv-nas-pi.kingma:8080",
            "office.kingma.ch",
            "office.king.ma"
        "dbtype": "mysql",
        "version": "31.0.6.2",
        "dbport": "",
        "mysql.utf8mb4": true,
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smpttimeout": 30,
        "mail_smtpsecure": "ssl",
        "loglevel": 3,
        "maintenance_window_start": 3,
        "default_phone_region": "CH",
        "app_install_overwrite": [],
        "ldapProviderFactory": "OCA\\User_LDAP\\LDAPProviderFactory"
  • activity: 4.0.0
  • admin_audit: 1.21.0
  • app_api: 5.0.2
  • bruteforcesettings: 4.0.0
  • calendar: 5.3.4
  • circles: 31.0.0
  • comments: 1.21.0
  • contacts: 7.1.4
  • contactsinteraction: 1.12.0
  • cookbook: 0.11.3
  • dashboard: 7.11.0
  • dav: 1.33.0
  • federation: 1.21.0
  • files: 2.3.1
  • files_downloadlimit: 4.0.0
  • files_external: 1.23.0
  • files_pdfviewer: 4.0.0
  • files_reminders: 1.4.0
  • files_sharing: 1.23.1
  • files_trashbin: 1.21.0
  • files_versions: 1.24.0
  • firstrunwizard: 4.0.0
  • fulltextsearch: 31.0.0
  • groupfolders: 19.1.2
  • logcleaner: 1.1.8
  • logreader: 4.0.0
  • notes: 4.12.1
  • notifications: 4.0.0
  • oauth2: 1.19.1
  • password_policy: 3.0.0
  • photos: 4.0.0-dev.1
  • privacy: 3.0.0
  • profile: 1.0.0
  • provisioning_api: 1.21.0
  • recommendations: 4.0.0
  • related_resources: 2.0.0
  • richdocuments: 8.7.1
  • richdocumentscode_arm64: 25.4.202
  • serverinfo: 3.0.0
  • settings: 1.14.0
  • sharebymail: 1.21.0
  • support: 3.0.0
  • survey_client: 3.0.0
  • suspicious_login: 9.0.1
  • systemtags: 1.21.1
  • text: 5.0.0
  • theming: 2.6.1
  • updatenotification: 1.21.0
  • user_ldap: 1.22.0
  • user_status: 1.11.0
  • viewer: 4.0.0
  • weather_status: 1.11.0
  • webhook_listeners: 1.2.0
  • workflowengine: 2.13.0
  • encryption: 2.19.0 (installed 2.19.0)
  • files_antivirus: 6.0.2 (installed 6.0.2)
  • richdocumentscode: 25.4.202
sudo docker exec --user www-data nextcloud php occ richdocuments:activate-config
✓ Reset callback url autodetect
Checking configuration
🛈 Configured WOPI URL: https://office.kingma.ch
🛈 Configured public WOPI URL: https://office.kingma.ch
🛈 Configured callback URL:
Failed to fetch discovery endpoint from https://office.kingma.ch
Client error: `GET https://office.kingma.ch/hosting/discovery` resulted in a `404 Not Found` response:
<!DOCTYPE html>
<html class="ng-csp" data-placeholder-focus="false" lang="en" data-locale="en" translate="no" >
        <head
I try to follow these steps: Collabora integration guide
  1. docker compose exec ${service name} php occ config:app:set richdocuments wopi_url --value ${CODE_URL}
  2. docker compose exec ${service name} php occ richdocuments:activate-config
none
PASTE
PASTE HERE
PASTE HERE
also
https://office.kingma.ch/apps/richdocumentscode/proxy.php?req=/hosting/discovery
not found
you are mixing 2 different Installation methods. the url with proxy belongs to built-in CODE the other to dedicated. which one are you using. I’m sorry OMV container is not self explaining for me..
in Collabora integration guide I read under prerequisites:
prerequisites
  • Nextcloud (WOPI server)
  • Collabora CODE (WOPI client)
    • public DNS name
    • valid TLS certificate
So that doesn’t mean I need Nextcloud Ofice and Collabora CODE? I’m totally confused with the documentation
Collabora Online is a LibreOffice-based online office suite with collaborative editing, which supports all major documents, spreadsheet and presentation file formats and works together with all modern browsers. The Nextcloud Office integration app provides a Nextcloud interface for editing documents with Collabora Online.
Collabora CODE (Collabora Office Development Edition) is the development version of Collabora Online. It is perfect for testing, home use or small teams, but not recommended for production environments. Collabora CODE together with Nextcloud Office enables editing Office documents within your Nextcloud instance.
There are various methods to run Collabora CODE together with Nextcloud Office.
TIP
Regardless which Collabora CODE service you’re planning to use, Nextcloud Office is required and must be installed on your Nextcloud instance to provide an interface for editing documents in Nextcloud.
as you can see in the list of apps both Nextcould Office and Collabora Online Build-in CODE Server (ARM64) are installed. What else is needed?
in this case your CODE URL is .../apps/richdocumentscode/proxy.php?req=/hosting/discovery the logic and troubleshooting steps remain the same.. in the guide there are many references related to collabora-built-in as well also showing many problems.
