CODE built-in for collabora and custom port
Nextcloud version : 28.0.11
Operating system and version : Linux 6.6.18 aarch64
Apache or nginx version : Apache 2.4.62 (Debian)
PHP version : 8.1.29
I’m using the CODE built-in for collabora. Everything was working fine. I decided to use custom port for my server. I updated my router to open another port let’s say XXXX to 443.
I updated the CODE built-in element, everything seems OK : it updated with the custom port and is showing : “Collabora Online server is reachable.”
BUT… I can’t open .odt, .ods… Althought .png, .pdf, .md are fine.
I tried updating the WOPI thing, but even making it blank or with 0.0.0.0/0, it doesn’t work.
Do I need to update something somewhere else ? Or is the issue maybe not related to the port change ?
Reading this : Making sure you're not a bot!
I’m stopped at the very first step : there is no Collabora Online’s configuration file here : /etc/coolwsd/coolwsd.xml.
Actually, I don’t even have a coolwsd folder in /etc/…
likely you broke the integration.
why do you do this? as collabora-built-in is by design made available through an integrated “reverse proxy” component you would have adjusted this one as well… but in general I would recommend to keep it using the default port there is no good reason to change it.
Please review Collabora integration guide to fully understand the integration.
Well, I’d like to use non standard port for my server… So not the usual 80 or 443 (I mean for the outside world).
Since I’m using it on a RPi, I had to update de check URL like this :
https://mydomain.cloud.net:XXXX/apps/richdocumentscode_arm64/proxy.php?req=/hosting/capabilities
  • XXXX being my custom port
  • richdocumentscode_arm64 being where the Collabora code is (I guessed, since I don’t have a richdocumentscode folder)
Then I can see it’s all up and running.
So I guess the question is : how can I adjust the integrated “reverse proxy” component to make it work with my custom port ?
And, do I need to change something somewhere to specify the “_arm64” for the folder name ?
I suppose this is not intended and not supported. Go the hard way read, understand and change the code. repeat after every update.
So are you saying that no-one using the Build-in CODE uses custom ports for their Nextcloud setup ?
Now, I read that if I want to use my own server for Collabora : Nextcloud Office requires a separate server running Collabora Online to provide editing capabilities. Collabora Online requires a separate server acting as a WOPI-like Client to provide editing capabilities.
Can this be on the same “physical” machine, but a subdomain ? Like I see mentionned for exemple *office*.mycloud.net in some of the guides ? This way I should be able to add specific elements in the VirtualHost stuff, like my custom port, right ?
Seems my problem is coming from seomthing else, cause I have the same issue even if I go back to the regular 443 port…
My bad… Sorry for that… I just saw I had a pending update for Collabora, and everything is working fine now :slight_smile:
