Nextcloud version (eg, 20.0.5): 23.0.3
Operating system and version (eg, Ubuntu 20.04): CentOS 7.8
Apache or nginx version (eg, Apache 2.4.25): Apache
PHP version (eg, 7.4): php 8.0.18
Docker version : 20.10.14
Docker-compose version : 1.29.2 -
The issue you are facing :
hi all,
I tried to mount my s3 compatible storage as external storage on GUI.
and there is no error when i save my storage information.
But I got error when I enter the folder that mounted as external storage. -
is it possible, to use s3 compatible storage as external storage on docker?
in logs
<Message>GET BUCKET VERSIONING not supported in container mode</Message>
“in container mode” means docker container?
please let me know how to solve this problem… thanks
Steps to replicate it :
- get docker-compose.yaml (Base version - apache) from github
- docker-compose up -d
- admin user top right menu ‘Apps’ → ‘External storage support’ [able check] on GUI
- admin user top right menu ‘Settings’ → left menu ‘Administration’ → ‘External Storage’ → add storage(Amazon S3)
- admin user top left menu ‘Files’ → ‘External Storage’ → enter the mounted folder → Error
The output of your Nextcloud log in Admin > Logging :
- Aws\S3\Exception\S3Exception: Error executing “GetBucketVersioning” on “https://my-bucket-name.kr.object.ncloudstorage.com/?versioning”; AWS HTTP error: Client error:
GET https://my-bucket-name.kr.object.ncloudstorage.com/?versioning
resulted in a400 Bad Request
response: <?xml version="1.0" encoding="UTF-8" standalone="yes"?>UnsupportedOperation
GET BUCKET VERSI (truncated…) UnsupportedOperation (client): GET BUCKET VERSIONING not supported in container mode - <?xml version="1.0" encoding="UTF-8" standalone="yes"?>UnsupportedOperation
GET BUCKET VERSIONING not supported in container mode/my-bucket-name/7da53007-67d7-40d3-84f2-f1bcbd5f1bab400
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'instanceid',
'passwordsalt' => 'pwd',
'secret' => 'secret',
0 => 'url',
'version' => '23.0.3.2',
'overwrite.cli.url' => 'http://my-url',
'dbname' => 'my-dbname',
'dbhost' => 'db',
'dbuser' => 'my-dbuser',
'dbpassword' => 'my-dbpassword',
Aws\S3\Exception\S3Exception: Error executing "GetBucketVersioning" on "https://nc-dt-bucket.kr.object.ncloudstorage.com/?versioning"; AWS HTTP error: Client error: `GET https://nc-dt-bucket.kr.object.ncloudstorage.com/?versioning` resulted in a `400 Bad Request` response: <?xml version="1.0" encoding="UTF-8" standalone="yes"?><Error><Code>UnsupportedOperation</Code><Message>GET BUCKET VERSI (truncated...) UnsupportedOperation (client): GET BUCKET VERSIONING not supported in container mode - <?xml version="1.0" encoding="UTF-8" standalone="yes"?><Error><Code>UnsupportedOperation</Code><Message>GET BUCKET VERSIONING not supported in container mode</Message><Resource>/nc-dt-bucket/</Resource><RequestId>0f81aab9-5d48-42a7-bf33-75809cbcabe7</RequestId><httpStatusCode>400</httpStatusCode></Error>
0. /var/www/html/3rdparty/aws/aws-sdk-php/src/WrappedHttpHandler.php - line 97:Aws\WrappedHttpHandler->parseError("*** sensiti ... *", GuzzleHttp\Psr7\Request {}, Aws\Command {}, [])
1. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 204:Aws\WrappedHttpHandler->Aws\{closure}("*** sensiti ... *")
2. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 169:GuzzleHttp\Promise\Promise::callHandler(2, "*** sensiti ... *", null)
3. /var/www/html/3rdparty/guzzlehttp/promises/src/RejectedPromise.php - line 42:GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
4. /var/www/html/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 48:GuzzleHttp\Promise\RejectedPromise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
5. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 158:GuzzleHttp\Promise\TaskQueue->run()
6. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 183:GuzzleHttp\Handler\CurlMultiHandler->tick()
7. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 248:GuzzleHttp\Handler\CurlMultiHandler->execute(true)
8. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 224:GuzzleHttp\Promise\Promise->invokeWaitFn()
9. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 269:GuzzleHttp\Promise\Promise->waitIfPending()
10. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 226:GuzzleHttp\Promise\Promise->invokeWaitList()
11. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 269:GuzzleHttp\Promise\Promise->waitIfPending()
12. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 226:GuzzleHttp\Promise\Promise->invokeWaitList()
13. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:GuzzleHttp\Promise\Promise->waitIfPending()
14. /var/www/html/3rdparty/aws/aws-sdk-php/src/AwsClientTrait.php - line 58:GuzzleHttp\Promise\Promise->wait()
15. /var/www/html/3rdparty/aws/aws-sdk-php/src/AwsClientTrait.php - line 86:Aws\AwsClient->execute(Aws\Command {})
16. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 735:Aws\AwsClient->__call("getBucketVersioning", [ { Bucket: "nc-dt-bucket"}])
17. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 712:OCA\Files_External\Lib\Storage\AmazonS3->versioningEnabled()
18. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 354:OCA\Files_External\Lib\Storage\AmazonS3->getDirectoryMetaData(".")
19. /var/www/html/lib/private/Files/Storage/Common.php - line 187:OCA\Files_External\Lib\Storage\AmazonS3->stat(".")
20. /var/www/html/lib/private/Files/Storage/Common.php - line 713:OC\Files\Storage\Common->filemtime("")
21. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Common->getMetaData("")
22. /var/www/html/lib/private/Files/Storage/Wrapper/PermissionsMask.php - line 140:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
23. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Wrapper\PermissionsMask->getMetaData("")
24. /var/www/html/lib/private/Files/Storage/Wrapper/Availability.php - line 447:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
25. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Wrapper\Availability->getMetaData("")
26. /var/www/html/lib/private/Files/Cache/Scanner.php - line 116:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
27. /var/www/html/lib/private/Files/Cache/Scanner.php - line 154:OC\Files\Cache\Scanner->getData("")
28. /var/www/html/lib/private/Files/View.php - line 1493:OC\Files\Cache\Scanner->scanFile("")
29. /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php - line 264:OC\Files\View->getDirectoryContent("/")
30. /var/www/html/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php - line 71:OCA\DAV\Connector\Sabre\Directory->getChildren()
31. /var/www/html/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php - line 116:OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->cacheDirectory(OCA\DAV\Files\FilesHome {})
32. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->handleGetProperties(Sabre\DAV\PropFind {}, OCA\DAV\Files\FilesHome {})
33. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1052:Sabre\DAV\Server->emit("propFind", [ Sabre\DAV\ ... }])
34. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 984:Sabre\DAV\Server->getPropertiesByNode(Sabre\DAV\PropFind {}, OCA\DAV\Files\FilesHome {})
35. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1661:Sabre\DAV\Server->getPropertiesIteratorForPath("files/admin", [ "{DAV:}get ... "], 1)
36. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1646:Sabre\DAV\Server->writeMultiStatus(Sabre\Xml\Wr ... ]}, Generator {}, false)
37. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 346:Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
38. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
39. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 472:Sabre\DAV\Server->emit("method:PROPFIND", [ Sabre\HTTP ... }])
40. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 253:Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
41. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 321:Sabre\DAV\Server->start()
42. /var/www/html/apps/dav/lib/Server.php - line 339:Sabre\DAV\Server->exec()
43. /var/www/html/apps/dav/appinfo/v2/remote.php - line 35:OCA\DAV\Server->exec()
44. /var/www/html/remote.php - line 166:require_once("/var/www/ht ... p")
Caused by GuzzleHttp\Exception\ClientException: Client error: `GET https://nc-dt-bucket.kr.object.ncloudstorage.com/?versioning` resulted in a `400 Bad Request` response: <?xml version="1.0" encoding="UTF-8" standalone="yes"?><Error><Code>UnsupportedOperation</Code><Message>GET BUCKET VERSI (truncated...)
0. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php - line 69:GuzzleHttp\Exception\RequestException::create(GuzzleHttp\Psr7\Request {}, "*** sensiti ... *", null, [], null)
1. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 204:GuzzleHttp\Middleware::GuzzleHttp\{closure}("*** sensiti ... *")
2. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 153:GuzzleHttp\Promise\Promise::callHandler(1, "*** sensiti ... *", null)
3. /var/www/html/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 48:GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}("*** sensiti ... *")
4. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 158:GuzzleHttp\Promise\TaskQueue->run()
5. /var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlMultiHandler.php - line 183:GuzzleHttp\Handler\CurlMultiHandler->tick()
6. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 248:GuzzleHttp\Handler\CurlMultiHandler->execute(true)
7. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 224:GuzzleHttp\Promise\Promise->invokeWaitFn()
8. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 269:GuzzleHttp\Promise\Promise->waitIfPending()
9. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 226:GuzzleHttp\Promise\Promise->invokeWaitList()
10. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 269:GuzzleHttp\Promise\Promise->waitIfPending()
11. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 226:GuzzleHttp\Promise\Promise->invokeWaitList()
12. /var/www/html/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:GuzzleHttp\Promise\Promise->waitIfPending()
13. /var/www/html/3rdparty/aws/aws-sdk-php/src/AwsClientTrait.php - line 58:GuzzleHttp\Promise\Promise->wait()
14. /var/www/html/3rdparty/aws/aws-sdk-php/src/AwsClientTrait.php - line 86:Aws\AwsClient->execute(Aws\Command {})
15. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 735:Aws\AwsClient->__call("getBucketVersioning", [ { Bucket: "nc-dt-bucket"}])
16. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 712:OCA\Files_External\Lib\Storage\AmazonS3->versioningEnabled()
17. /var/www/html/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 354:OCA\Files_External\Lib\Storage\AmazonS3->getDirectoryMetaData(".")
18. /var/www/html/lib/private/Files/Storage/Common.php - line 187:OCA\Files_External\Lib\Storage\AmazonS3->stat(".")
19. /var/www/html/lib/private/Files/Storage/Common.php - line 713:OC\Files\Storage\Common->filemtime("")
20. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Common->getMetaData("")
21. /var/www/html/lib/private/Files/Storage/Wrapper/PermissionsMask.php - line 140:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
22. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Wrapper\PermissionsMask->getMetaData("")
23. /var/www/html/lib/private/Files/Storage/Wrapper/Availability.php - line 447:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
24. /var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php - line 599:OC\Files\Storage\Wrapper\Availability->getMetaData("")
25. /var/www/html/lib/private/Files/Cache/Scanner.php - line 116:OC\Files\Storage\Wrapper\Wrapper->getMetaData("")
26. /var/www/html/lib/private/Files/Cache/Scanner.php - line 154:OC\Files\Cache\Scanner->getData("")
27. /var/www/html/lib/private/Files/View.php - line 1493:OC\Files\Cache\Scanner->scanFile("")
28. /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php - line 264:OC\Files\View->getDirectoryContent("/")
29. /var/www/html/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php - line 71:OCA\DAV\Connector\Sabre\Directory->getChildren()
30. /var/www/html/apps/dav/lib/Connector/Sabre/CommentPropertiesPlugin.php - line 116:OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->cacheDirectory(OCA\DAV\Files\FilesHome {})
31. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:OCA\DAV\Connector\Sabre\CommentPropertiesPlugin->handleGetProperties(Sabre\DAV\PropFind {}, OCA\DAV\Files\FilesHome {})
32. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1052:Sabre\DAV\Server->emit("propFind", [ Sabre\DAV\ ... }])
33. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 984:Sabre\DAV\Server->getPropertiesByNode(Sabre\DAV\PropFind {}, OCA\DAV\Files\FilesHome {})
34. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1661:Sabre\DAV\Server->getPropertiesIteratorForPath("files/admin", [ "{DAV:}get ... "], 1)
35. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1646:Sabre\DAV\Server->writeMultiStatus(Sabre\Xml\Wr ... ]}, Generator {}, false)
36. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 346:Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
37. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php - line 89:Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
38. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 472:Sabre\DAV\Server->emit("method:PROPFIND", [ Sabre\HTTP ... }])
39. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 253:Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
40. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 321:Sabre\DAV\Server->start()
41. /var/www/html/apps/dav/lib/Server.php - line 339:Sabre\DAV\Server->exec()
42. /var/www/html/apps/dav/appinfo/v2/remote.php - line 35:OCA\DAV\Server->exec()
43. /var/www/html/remote.php - line 166:require_once("/var/www/ht ... p")
