Can't access outside my home
You can run the small programm “ddclient” on your NextcloudPi which periodically checks if your IP address has changed and in that case updates your FreeDNS entry. It is in the Debian package repository, so you can install it directly. Here is its documentation:
…and it explicitly supports FreeDNS.
Ah, cool, I didn’t know NCP could do that directly - great tool! :slight_smile:
Hi “garyf”, I have the same setup as yourself but with a different router. Trying to keep things simple, I can access my NextCloud RPi2 server from anywhere.
I use a service like no-ip and have my router’s Dynamic DNS option point to that.
Then, still in my router, the NAT menu option for “Virtual Servers” is set for the outside port 445 pointing to inside port 443 of my RPi2’s IP.
Also, if you can’t find a Dynamic DNS option in your router, you can use the ddclient which was mentioned by “simonspa” in a previous posting :wink:
I know different makes of routers use different names for services, but all-in-all they’re pretty much the same. Hope that helps.
PS - once you get all working, I recommend you start using a https service such Cloudfare, this keeps you safe!
This is solved already
There is depending on your ISP. With a lot of ISP’s you can request to have a static IP address. Some ISP’s charge an extra $5 per month for this, it all depends on the ISP.
No need, we already set up freedns’s dynamic dns service
Cloudflare is not a “https service” its a ddos protection, but it tends to be unstable due to unqualified behaviour of their dev, so actually you protect your cloud from failing by using an unstable service, which seems kind of counterproductive.
What should be used is letsencrypt certificates and force https on your server, that is what keeps you safe…
