CalDAV and CardDAV redirects for Nginx proxy don't work anymore since 29.0.0
Nextcloud version : 29.0.0
Operating system and version: Docker image
Apache or nginx version: Couldn’t find it
PHP version: 8.2.19
I am using the Nginx Proxy Manager and had configured it properly for CalDAV and CardDAV synchronization. After upgrading I am told that my webserver isn’t properly set up anymore.
For the Nginx proxy I have used the following redirects
      return 301 $scheme://$host:$server_port/remote.php/dav;
which I had found here once.
Is this the first time you’ve seen this error? (Y/N): Yes
  • File is too big
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => 'redis',
    'password' => '',
    'port' => 6379,
  'instanceid' => 'xxxxxxxxxxxxx',
  'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
  'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxx',
    0 => 'mydomain.de',
    1 => 'myhost',
  'version' => '29.0.0.19',
  'overwrite.cli.url' => 'https://cloud.j29.duckdns.org',
  'overwriteprotocl' => 'https',
  'dbname' => 'nextcloud',
  'dbhost' => 'db',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'Moinsen88!!',
  'mail_from_address' => 'myemail',
  'mail_smtpmode' => 'smtp',
  'mail_domain' => 'web.de',
  'mail_smtpsecure' => 'tls',
  'mail_smtpauth' => 1,
  'mail_smtphost' => 'smtp.web.de',
  'mail_smtpport' => '587',
  'mail_smtpname' => 'myemail',
  'mail_smtppassword' => 'password!',
  'loglevel' => 2,
  'memories.db.triggers.fcu' => true,
  'memories.exiftool' => '/var/www/html/custom_apps/memories/bin-ext/exiftool-amd64-glibc',
  'memories.vod.path' => '/var/www/html/custom_apps/memories/bin-ext/go-vod-amd64',
  'memories.gis_type' => 1,
  • Apache log sin /var/log/apache2 are empty
  • Couldn’t find the Nginx log
  • File is too big and contains too much private information it seems
Hello, i have same issue with a global Nginx reverse proxy server
I don’t see any request to .well-known/carddav in the logs
Try this instead:
      return 301 $scheme://$host:$server_port/remote.php/dav/;
(note the trailing slashes)
Works, thank you! I wonder why the old version worked before and doesn’t now.
