Latest Official Nextcloud Docker Image
Nextcloud version (eg, 20.0.5): 28.0.0
Operating system and version (eg, Ubuntu 20.04): Docker on Ubuntu 22.04LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.57 (Debian)
PHP version (eg, 7.4): 8.2.13
Database: Type: pgsql
Version: PostgreSQL 14.6 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44), 64-bit
Bookmarks no longer accessible after upgrade
- Access bookmarks (/index.php/apps/bookmarks/) →
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
[no app in context] Error: Could not boot bookmarks: Could not resolve symfonyAdapter! Class "symfonyAdapter" does not exist
GET /index.php/apps/logreader/api/poll?lastReqId=U0875w4bysVyJc8CpuLG
from XXX.XXX.XXX.XXX by USERNAME at 14 Dec 2023, 3:17:42 pm
"reqId":"bqkliEzZgm8R3itB0zmV",
"level":3,
"time":"2023-12-14T04:34:13+00:00",
"remoteAddr":"61.245.150.110",
"user":"USERNAME",
"app":"no app in context",
"method":"GET",
"url":"/index.php/apps/files/",
"message":"Could not boot bookmarks: Could not resolve symfonyAdapter! Class \"symfonyAdapter\" does not exist",
"userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36",
"version":"28.0.0.11",
"exception":{
"Exception":"OC\\AppFramework\\Utility\\QueryNotFoundException",
"Message":"Could not resolve symfonyAdapter! Class \"symfonyAdapter\" does not exist",
"Code":0,
"Trace":[
"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php",
"line":146,
"function":"resolve",
"class":"OC\\AppFramework\\Utility\\SimpleContainer",
"type":"->",
"args":[
"symfonyAdapter"
"file":"/var/www/html/lib/private/ServerContainer.php",
"line":173,
"function":"query",
"type":"->",
"args":[
"symfonyAdapter",
true
"file":"/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php",
"line":443,
"function":"query",
"class":"OC\\ServerContainer",
"type":"->",
"args":[
"symfonyAdapter",
true
"line":64,
"function":"query",
"class":"OC\\AppFramework\\DependencyInjection\\DIContainer",
"type":"->",
"args":[
"symfonyAdapter"
"file":"/var/www/html/lib/private/AppFramework/Bootstrap/FunctionInjector.php",
"line":56,
"function":"get",
"type":"->",
"args":[
"symfonyAdapter"
"function":"OC\\AppFramework\\Bootstrap\\{closure}",
"class":"OC\\AppFramework\\Bootstrap\\FunctionInjector",
"type":"->",
"args":[
"*** sensitive parameters replaced ***"
"line":45,
"function":"array_map",
"args":[
"Closure"
"ReflectionParameter",
"resourceManager"
"file":"/var/www/html/lib/private/AppFramework/Bootstrap/BootContext.php",
"line":50,
"function":"injectFn",
"type":"->",
"args":[
"Closure"
"file":"/var/www/html/custom_apps/bookmarks/lib/AppInfo/Application.php",
"line":104,
"class":"OC\\AppFramework\\Bootstrap\\BootContext",
"type":"->",
"args":[
"Closure"
"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php",
"line":200,
"function":"boot",
"class":"OCA\\Bookmarks\\AppInfo\\Application",
"type":"->",
"args":[
"file":"/var/www/html/lib/private/App/AppManager.php",
"line":434,
"function":"bootApp",
"class":"OC\\AppFramework\\Bootstrap\\Coordinator",
"type":"->",
"args":[
"bookmarks"
"line":213,
"function":"loadApp",
"class":"OC\\App\\AppManager",
"type":"->",
"args":[
"bookmarks"
"file":"/var/www/html/lib/private/legacy/OC_App.php",
"line":125,
"function":"loadApps",
"type":"->",
"args":[
"file":"/var/www/html/lib/base.php",
"line":1049,
"class":"OC_App",
"type":"::",
"args":[
"file":"/var/www/html/index.php",
"line":39,
"function":"handleRequest",
"class":"OC",
"type":"::",
"args":[
"File":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php",
"Line":135,
"exception":{
"CustomMessage":"Could not boot bookmarks: Could not resolve symfonyAdapter! Class \"symfonyAdapter\" does not exist"
