Beginner Installation Help
    • Nextcloud All in One 31.0.7
    • Ubuntu 24.04.3 LTS
    • Not Sure
    • Not Sure
    • Not Sure
    • Yes
    • I am a first time user trying to install this program
    • Nextcloud All in One Docker Image
    • replace me
Hi, I am a beginner to both Linux and Nextcloud. I am trying to self host and make my own cloud drive and was advised to install Nextcloud. I installed Ubuntu 24.04.3 LTS and straight after that I followed the instructins on Nextcloud’s website to get the All in One application running.
I first followed these instructions provided:
This I assume lets me install an application called docker, and I believe I did this correctly as it asked me to do a “hello world” test and the output came out to what I should see.
I next went to step 3 on this website which was provided by Nextcloud:
https://github.com/nextcloud/all-in-one?tab=readme-ov-file#how-to-use-this
Currently my terminal is stuck on this message:
NOTICE: ready to handle connections
I’m not sure what I’m supposed to see but I believe there should be an initial startup because step 4 on the github page says “After the initial startup, you should be able to open the Nextcloud AIO Interface now on port 8080 of this server.”.
I am not sure on how to proceed and would like to make sure I do things right so any help would be appreciated.
Hello @NeedOwnHost,
welcome to the Nextcloud community! :handshake:
self-hosting relates to many many different technologies and you should learn them slowly. Review 101: Self-hosting information for beginners.
Nextcloud is fairly complex application and I would recommend you play and learn a lot before you start self-hosting Nextcloud and store important files there (especially backup, restore, upgrades)
Hi and welcome :waving_hand:
I agree with @wwe — start simple and don’t get discouraged by being a beginner. Nextcloud AIO is built so it doesn’t overwhelm you: run it, go through the wizard, and adjust as your needs grow.
Before you dive in, consider a few things that shape the “right” setup for you:
  • Hardware: if you’ve got decent gear, it’d be a pity to dedicate it only to Nextcloud. You might later add Bitwarden, Plex, Paperless…
  • Connectivity/IP: do you have a public IP? Is your ISP blocking ports (80/443, and 3478/UDP for Talk)?
  • Reverse proxy: if you plan other services alongside Nextcloud, it’s clean to run Nginx Proxy Manager outside AIO and let it front everything.
  • Goal: only LAN access, or also domain + HTTPS from the internet?
Don’t worry about starting with Linux. Curiosity is what moves you forward. The forum already has plenty of step-by-step guides with exact settings — just pick the one that matches your conditions.
Thanks for the welcome and I will definitely take a look at the link you’ve provided.
The links mentioned above are a good starting point — but:
There’s no mail server or virtual host management included, so “All-in-One” is a bit misleading.
In many real-world setups, you’ll also want to run things like WordPress or DokuWiki alongside Nextcloud.
A solid alternative is the ISPConfig Autoinstaller:
https://www.howtoforge.com/ispconfig-autoinstall-debian-ubuntu/
It automatically sets up everything you need for Nextcloud — including a mail server and vhost management. After that, you just create a virtual host for Nextcloud via the web interface, and you’re done.
Alternatively, take a look at YunoHost — a beginner-friendly system with a web UI, mail server, app catalog (including Nextcloud), and user management.
@NeedOwnHost
I would also like to give you some well-intended advice. Many Linux and Nextcloud beginners have managed to install Nextcloud. But far fewer have managed to repair Nextcloud in the event of an error.
I don’t want to scare you, but always make sure you have a backup. Be prepared for the possibility that you may not be able to restore Nextcloud to its previous state.
For really important data, I always recommend keeping it available independently of Nextcloud. Nextcloud has the great advantage that files are not encrypted. Backup is very easy. I also strongly advise against activating server-side encryption. It can cause problems in the event of an error and does not offer any security advantages. It only makes sense if the data itself is stored with a third-party provider, e.g. as object storage. That will not be the case for you.
