BadRequest Expected filesize of x bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) y bytes
  • Nextcloud Docker installation:
    • nextcloud:latest
  nextcloud:
    image: nextcloud:latest
    container_name: nextcloud
    restart: always
    environment:
      TZ: ${TZ:-Europe/Athens}
      PUID: 1000
      PGID: 1000
      MYSQL_HOST: nextcloud-db
      MYSQL_USER: ${MYSQL_USER}
      MYSQL_PASSWORD: ${MYSQL_PASSWORD}
      MYSQL_DATABASE: nextcloud
      REDIS_HOST: nextcloud-redis
      REDIS_HOST_PORT: 6379
      REDIS_HOST_PASSWORD: ${REDIS_PASSWORD}
      PHP_MEMORY_LIMIT: 50G
      PHP_UPLOAD_LIMIT: 50G
      NEXTCLOUD_ADMIN_USER: ${NEXTCLOUD_ADMIN_USERNAME}
      NEXTCLOUD_ADMIN_PASSWORD: ${NEXTCLOUD_ADMIN_PASSWORD}
      NEXTCLOUD_TRUSTED_DOMAINS: ${DOMAIN}
      TRUSTED_PROXIES: 172.16.0.0/12 192.168.0.0/16 10.0.0.0/8 fc00::/7 fe80::/10 2001:db8::/32
      OVERWRITEPROTOCOL: https
I am trying to upload a single video file (57 MB), through the web client or the desktop client or the android client and I get the error below:
BadRequest Expected filesize of 60096484 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 36290560 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
I 've noticed that the error occurs at around 60-90 seconds
  1. Add file to sync folder / or upload it through the web page
  2. Wait 60 - 90 seconds
  3. Error occurs (BadRequest Expected filesize of…)
{"reqId":"z2TnJ5y8TjiZ1loUQLUW","level":3,"time":"2024-12-25T18:32:55+00:00","remoteAddr":"xxxxxxxxxx","user":"xxxxxxxxxx","app":"no app in context","method":"PUT","url":"/remote.php/dav/files/xxxxxxxxxx/xxxxxxxxxx.mp4","message":"Expected filesize of 60096484 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 36290560 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (Windows) mirall/3.15.2 (build 20241216) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"30.0.4.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 60096484 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 36290560 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","Line":259,"message":"Expected filesize of 60096484 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 36290560 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","exception":{},"CustomMessage":"Expected filesize of 60096484 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 36290560 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."}}
PASTE
nextcloud  | xxxxxxxxxx - xxxxxxxxxx[25/Dec/2024:20:53:02 +0200] "PROPFIND /remote.php/dav/files/xxxxxxxxxx/ HTTP/1.1" 207 964 "-" "Mozilla/5.0 (Windows) mirall/3.15.2 (build 20241216) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
nextcloud  | xxxxxxxxxx - xxxxxxxxxx[25/Dec/2024:20:52:11 +0200] "PUT /remote.php/dav/files/xxxxxxxxxx/xxxxxxxxxx.mp4 HTTP/1.1" 400 1197 "-" "Mozilla/5.0 (Windows) mirall/3.15.2 (build 20241216) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "memcache.locking.timeout": 3600,
        "redis": {
            "port": 6379
        "overwriteprotocol": "https",
        "upgrade.disable-web": true,
            "localhost",
            "xxxxxxxxxxxx.com",
            "192.168.2.100"
        "dbtype": "mysql",
        "version": "30.0.4.1",
        "overwrite.cli.url": "https:\/\/localhost",
        "dbport": "",
        "mysql.utf8mb4": true,
        "default_phone_region": "GR",
        "loglevel": 2,
        "max_execution_time": 3600
  • activity: 3.0.0
  • app_api: 4.0.3
  • bruteforcesettings: 3.0.0
  • circles: 30.0.0
  • cloud_federation_api: 1.13.0
  • comments: 1.20.1
  • contactsinteraction: 1.11.0
  • cookbook: 0.11.2
  • dav: 1.31.1
  • federatedfilesharing: 1.20.0
  • federation: 1.20.0
  • files: 2.2.0
  • files_downloadlimit: 3.0.0
  • files_pdfviewer: 3.0.0
  • files_reminders: 1.3.0
  • files_sharing: 1.22.0
  • files_trashbin: 1.20.1
  • files_versions: 1.23.0
  • firstrunwizard: 3.0.0
  • logreader: 3.0.0
  • lookup_server_connector: 1.18.0
  • nextcloud_announcements: 2.0.0
  • notifications: 3.0.0
  • oauth2: 1.18.1
  • password_policy: 2.0.0
  • photos: 3.0.2
  • privacy: 2.0.0
  • provisioning_api: 1.20.0
  • recommendations: 3.0.0
  • related_resources: 1.5.0
  • serverinfo: 2.0.0
  • settings: 1.13.0
  • sharebymail: 1.20.0
  • support: 2.0.0
  • survey_client: 2.0.0
  • systemtags: 1.20.0
  • text: 4.1.0
  • theming: 2.5.0
  • twofactor_backupcodes: 1.19.0
  • updatenotification: 1.20.0
  • user_status: 1.10.0
  • viewer: 3.0.0
  • weather_status: 1.10.0
  • webhook_listeners: 1.1.0-dev
  • workflowengine: 2.12.0
  • admin_audit: 1.20.0
  • dashboard: 7.10.0 (installed 7.9.0)
  • encryption: 2.18.0
  • files_external: 1.22.0
  • suspicious_login: 8.0.0
  • twofactor_nextcloud_notification: 4.0.0
  • twofactor_totp: 12.0.0-dev
  • user_ldap: 1.21.0
Is this your production Compose file? It doesn’t have any volumes specified for storing data.
I’ve noticed that the error occurs at around 60-90 seconds
What is your typical upload performance? I ask because this may be a simple web server or reverse proxy timeout, particularly since chunking isn’t used by the desktop client for 57M files by default.
Do you have the log output from an attempt via the Web UI? If you upload via the web UI, it should split a 57M file up into 6 chunks (at least in <=v30) unless you’ve changed your chunking settings from the default there (the web UI uses 10M chunk sizes)
Thanks for the reply!
Here is the whole compose
  nextcloud:
    restart: always
    environment:
      PUID: 1000
      PGID: 1000
    depends_on:
      - nextcloud-redis
      - nextcloud-db
      - traefik
    ports:
      - ${NEXTCLOUD_PORT}:80
      # - 443:443
    volumes:
      - nextcloud:/var/www/html
      - ./nextcloud/redis/redis-session.ini:/usr/local/etc/php/conf.d/redis-session.ini:z
      - ${EXTERNAL_HD1_PATH}/nextcloud-data:/var/www/html/data
      - ${EXTERNAL_HD1_PATH}/media:/media
      - ${EXTERNAL_HD2_PATH}/backup:/backup
      - ${EXTERNAL_HD2_PATH}/samba-data:/samba
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.nextcloud.rule=Host(`${DOMAIN}`)"
      - "traefik.http.routers.nextcloud.service=nextcloud"
      - "traefik.http.routers.nextcloud.entrypoints=websecure"
      - "traefik.http.services.nextcloud.loadbalancer.server.port=80"
      - "traefik.http.routers.nextcloud.tls=true"
      - "traefik.http.routers.nextcloud.tls.certresolver=letsencrypt"
      - "traefik.http.services.nextcloud.loadbalancer.passhostheader=true"
      - "traefik.http.routers.nextcloud.middlewares=compresstraefik,traefik-headers,traefik-redirect"
      - "traefik.http.middlewares.compresstraefik.compress=true"
      - "traefik.http.middlewares.traefik-headers.headers.referrerPolicy=no-referrer"
      - "traefik.http.middlewares.traefik-headers.headers.sslRedirect=true"
      - "traefik.http.middlewares.traefik-headers.headers.stsSeconds=315360000"
      - "traefik.http.middlewares.traefik-headers.headers.browserXSSFilter=true"
      - "traefik.http.middlewares.traefik-headers.headers.contentTypeNosniff=true"
      - "traefik.http.middlewares.traefik-headers.headers.forceSTSHeader=true"
      - "traefik.http.middlewares.traefik-headers.headers.stsIncludeSubdomains=true"
      - "traefik.http.middlewares.traefik-headers.headers.stsPreload=true"
      - "traefik.http.middlewares.traefik-headers.headers.customFrameOptionsValue=SAMEORIGIN"
      - "traefik.http.middlewares.traefik-redirect.redirectRegex.permanent=true"
      - "traefik.http.middlewares.traefik-redirect.redirectRegex.regex=https://(.*)/.well-known/(?:card|cal)dav"
      - "traefik.http.middlewares.traefik-redirect.redirectRegex.replacement=https://$${1}/remote.php/dav"
      - "traefik.docker.network=traefik-network"
as well as the traefik compose
  traefik:
    image: traefik:latest
    container_name: traefik
    command:
      #- "--log.level=DEBUG"
      - "--api.insecure=true"
      - "--providers.docker=true"
      - "--providers.docker.exposedbydefault=false"
      - "--entrypoints.web.address=:80"
      - "--entrypoints.web.http.redirections.entryPoint.to=websecure"
      - "--entrypoints.web.http.redirections.entryPoint.scheme=https"
      - "--entrypoints.websecure.address=:443"
      - "--serverstransport.insecureskipverify=true"
      - "--certificatesresolvers.letsencrypt.acme.tlschallenge=true"
      - "--certificatesresolvers.letsencrypt.acme.httpchallenge=true"
      - "--certificatesresolvers.letsencrypt.acme.email=xxxxxxxxx"
      - "--certificatesresolvers.letsencrypt.acme.storage=/etc/traefik/acme/acme.json"
      # - "--entrypoints.dns_tcp.address=:53"
      # - "--entrypoints.dns_udp.address=:53/udp"
      - "--entrypoints.vpn_udp.address=:51820/udp"
    ports:
      - 80:80
      - 443:443
      # - 53:53/tcp
      # - 53:53/udp
      - 51820:51820/udp
      - ${TRAEFIK_PORT}:8080
    volumes:
      - "/var/run/docker.sock:/var/run/docker.sock:ro"
      - ./traefik/letsencrypt:/etc/traefik/acme
      - ./traefik/FileProvider/:/FileProvider/
    restart: always
Upload speed is around 5 Mbps
Web ui logs
chunks fail with same error
{"reqId":"nV5ZuLGuMol2sLwgsJZi","level":3,"time":"2024-12-28T08:17:01+00:00","remoteAddr":"xxxxxxxxxx","user":"jkokotinis","app":"no app in context","method":"PUT","url":"/remote.php/dav/uploads/jkokotinis/web-file-upload-f2de8534184e2950/1","message":"Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7266304 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:133.0) Gecko/20100101 Firefox/133.0","version":"30.0.4.1","exception":{"Exception":"Sabre\\DAV\\Exception\\BadRequest","Message":"Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7266304 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":110,"function":"put","class":"OCA\\DAV\\Connector\\Sabre\\File","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/dav/lib/Upload/UploadFolder.php","line":34,"function":"createFile","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1098,"function":"createFile","class":"OCA\\DAV\\Upload\\UploadFolder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":504,"function":"createFile","class":"Sabre\\DAV\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPut","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":146,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/File.php","Line":259,"message":"Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7266304 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.","exception":{},"CustomMessage":"Expected filesize of 10485760 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 7266304 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side."}}
Thanks for your time!
Edit: Uploading a smaller 17MB video on the same folder works without any issues.
I just tested uploading the video from another network with higher upload speed. The video uploads normally, without any issue. So it is not a max upload size configuration. There seems to be a timeout somewhere, that I cannot find and configure. Any ideas?
I tried to upload a 1GB file, both through the web page and the desktop client.
The 1GB file was split in more chunks than the 50mb file. Most chunks took less than 1 minute to upload. Some chunks took more than 1 minute and failed with the BadRequest error, but they were retried on their own and succeeded the second time.
After more than 3 minutes, the file was uploaded, both through the web client and the desktop client.
So the timeout must be somewhere on the chunk upload process and not on the whole file upload process.
Problem still persists
Any ideas where to start searching for more logs or how to debug the issue?
I am having the same chunk timeout issue with large file upload when on a Wireguard VPN connection. The upload progress also doesn’t show.
When I set a reduced chuck size of 20MB in the config then it works as expected. As per docs
However, I’m puzzled by your upload failing with 7MB chunks and am still wondering what is responsible for the timeouts. I did try some keep alive settings too. But I wonder if changing chunk size is just a bandaid fix and won’t apply to all situations.
The only way to reproduce it is through a slow connection (slow upload speed). I still haven’t found a solution by the way.
@pitsinis
I ran into the same problem. My setup also uses Traefik with Docker containers, and I discovered that the issue started with Traefik version 2.11.2. Its default respondingTimeouts now set the readTimeout to 60 seconds. I fixed it by adding these lines to my compose:
services:
  traefik:
    command:
      - --entrypoints.web.transport.respondingTimeouts.readTimeout=0
      - --entrypoints.websecure.transport.respondingTimeouts.readTimeout=0
For reference, see the Traefik migration notes on this change (Traefik Migration Documentation - Traefik) and the official docs on respondingTimeouts (Traefik EntryPoints Documentation - Traefik).
I also checked the Immich documentation for a similar configuration example (Reverse Proxy | Immich).
I set these settings to 1 hour and tried uploading large files from a slow internet connection. Bad Request error messages now appear every hour. Setting it to an even larger value, uploads the file successfully. Thanks for the help!
