example
longer
example
here
Nextcloud version (eg, 18.0.2): docker latest(18.0.4)
Operating system and version (eg, Ubuntu 20.04):Armbian Buster with Linux 5.4.2-rockchip64
Apache or nginx version (eg, Apache 2.4.25): docker latest
PHP version (eg, 7.1):docker latest
Auto uploads failed on Android. ( nextcloud-dev-20200521.apk) but manual uploads worked.
IOS auto uploads worked fine.
I tried this "HEADERS on invalid stream", but not worked for me.
Is this the first time you’ve seen this error? (Y/N):Y
Fatal webdav Sabre\DAV\Exception\BadRequest: Expected filesize of 4625 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4096 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php - line 156:
OCA\DAV\Connector\Sabre\File->put(null)
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 1096:
OCA\DAV\Connector\Sabre\Directory->createFile("mengtuiUnSelected.png", null)
/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 525:
Sabre\DAV\Server->createFile("实时上传/qk/ico ... g", null, null)
<<closure>>
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/html/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105:
call_user_func_array([ Sabre\DAV\ ... "], [ Sabre\HTTP ... }])
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 479:
Sabre\Event\EventEmitter->emit("method:PUT", [ Sabre\HTTP ... }])
/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php - line 254:
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\R ... "}, Sabre\HTTP\Response {})
/var/www/html/apps/dav/appinfo/v1/webdav.php - line 82:
Sabre\DAV\Server->exec()
/var/www/html/remote.php - line 165:
require_once("/var/www/ht ... p")
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => '192.168.123.3:8888',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'http://192.168.123.3:8888',
'dbname' => 'nextcloud',
'dbhost' => '172.18.0.3',
'dbuser' => 'oc_admin',
'dbpassword' => '***',
'tempdirectory' => '/var/www/html/data/tmp',
PASTE HERE
