Nextcloud version : 17.0.1
Operating system : Debian 10 (NextcloudPi)
Apache Version: 2.4.38
PHP version : 7.3.11
After the configuration of my Nextcloud Server I started the initial synchronisation with my PC as the first client device. It successfully uploaded 820 MB, but since then my client always crashes in the uploading phase. In the nextcloud logs, something like the following gets logged:
Expected filesize of 57634 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 8192 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
I checked it by uploading files manually over the web interface and indeed, all files with more than 8192 Bytes are denied, while those below are successfully uploaded.
In similar posts like Sabre\DAV\Exception\BadRequest: expected filesize 10485760 got 2554891 this problem normally happens with really big files in combination with the apache module mod_reqtimeout. I disabled with the entry
<IfModule reqtimeout_module>
RequestReadTimeout header=0
RequestReadTimeout body=0
</IfModule>
in /etc/apache2/apache2.conf . However, this doesn’t solve the problem. Does anyone have an idea?
- Upload a file bigger than 8 kb via web interface or Nextcloud client
Nextcloud Log
[webdav] Fatal: Sabre\DAV\Exception\BadRequest: Expected filesize of 57634 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 8192 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. at <<closure>>
0. /var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php line 156
OCA\DAV\Connector\Sabre\File->put(null)
1. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1096
OCA\DAV\Connector\Sabre\Directory->createFile("1612511462-hors ... g", null)
2. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 525
Sabre\DAV\Server->createFile("1612511462-hors ... g", null, null)
3. <<closure>>
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
4. /var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
undefinedundefinedcall_user_func_array([Sabre\DAV\CorePlugin {},"httpPut"], [Sabre\HTTP\Requ ... }])
5. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 479
Sabre\Event\EventEmitter->emit("method:PUT", [Sabre\HTTP\Requ ... }])
6. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
7. /var/www/nextcloud/apps/dav/appinfo/v1/webdav.php line 80
Sabre\DAV\Server->exec()
8. /var/www/nextcloud/remote.php line 163
undefinedundefinedrequire_once("/var/www/nextcl ... p")
PUT /remote.php/webdav/test.jpg
from 192.168.2.100 by ncp at 2019-12-19T20:46:57+00:00
config.php
'passwordsalt' => '*hidden*',
'secret' => '*hidden*',
*hidden*
'datadirectory' => '/media/nextcloud-data',
'version' => '17.0.1.1',
'overwrite.cli.url' => '*hidden*',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '*hidden*',
'dbpassword' => '*hidden*',
'instanceid' => '*hidden*',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => '*hidden*',
'tempdirectory' => '/media/nextcloud-data/tmp',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'admin',
'mail_domain' => 'ownyourbits.com',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'logfile' => '/media/nextcloud-data/nextcloud.log',
'loglevel' => 2,
There are different log files, and I don’t know which one is useful here. Please tell me if one of them is useful for you.
Thanks for your help!
