ca nnot Update via Web Updater from 15.0.0.RC1 to 15.0.2 ?!
Nothing happens after i push the [Start Update] Button. Any hints for me?
it’s the first time with a problem like that…
Regards,
ccb
Regards,
ccb
worked fine for me, running php 7.2.10
Hi
I always instal new version with new configuration
z poważaniem
Kind regards
Mit freundlichen Grüßen
Marcin Adamek
Dipl.-Ing. [FH Oldenburg]
ECEM - Europäisches Baumanagement
Maklererlaubnis nach § 34c GewO
Am Hohen Feld 129,
13125 Berlin
T: +49-30-23354689
F: +49-160-4008060
same here. after:
cd /var/www/html/nextcloud/data/updater-*
mv .step .step-previous-update
the web updater had no problems.
regards
martin
The web updater used to work for me on the first time, but it broke a long time ago - so I have to do it manually now. I think the latest time it worked was when Nextcloud was still ownCloud…
Worked fine for me. PHP 7.1
For me, it seemed to have run but after the update I was sent back to my old Nextcloud 14.0.6. I reran the update and that did the trick (for NC14.0.6 to 15.0.2)
If you’re able to install via Docker, you might want to give that a try. Updating seems to be easier when you’re running Nextcloud within a Docker container.
See this recent thread.
Also got problems with the web updater.
Running Nextcloud 14.0.3 on a FreeNAS-11.2-RELEASE-U1 I did a upgrade via the freenas shell.
iocage upgrade nextcloud
This worked fine, but now i got stuck in the webupater.
Possible CSRF attack. Connection will be closed.
Then I switched to shell, having more issues:
root@nextcloud:/usr/local/www/nextcloud # chmod +x occ
root@nextcloud:/usr/local/www/nextcloud # ./occ upgrade
Console has to be executed with the user that owns the file config/config.php Current user: root Owner of config.php: www Try adding 'sudo -u www ’ to the beginning of the command (without the single quotes)
root@nextcloud:/usr/local/www/nextcloud # su www ./occ upgrade
This account is currently not available.
Any suggestions? I don’t want to change to much via the shell and also don’t want to change the owsership of the config.php because it might break even more stuff!
On the Internet I found nothing usefull…
https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/occ_command.html
https://docs.nextcloud.com/server/9/admin_manual/configuration_server/occ_command.html
Check you owner and group
work with chgrp/chmod…
and check here Apache
https://doc.owncloud.org/server/8.2/admin_manual/configuration_server/occ_command.html#http-user-label
Just upgraded via UI without any problems…
