Feel free to edit this Wiki Post. Continuing the discussion from Any apps not yet compatible with PHP 8 and v21?. Please reference that thread for apps still unsupported in 21 …on to 22:
Version 22 Compatibility List
- BPM Viewer - Nextcloud 22 Support · Issue #6 · Loydl/nc-bpm-app · GitHub
- Dicom Viewer - Add compatibility with Nextcloud 22 · Issue #76 · ayselafsar/dicomviewer · GitHub
- End to End Encryption - Update stable22 target versions by nickvergessen · Pull Request #242 · nextcloud/end_to_end_encryption · GitHub
- External Storage: Onedrive - NC22 Support · Issue #63 · hevelius/files_external_onedrive · GitHub
- occweb - OCC Web - Apps - App Store - Nextcloud - App has been abandonded and marked as deprecated due to technical reasons
- PDF Annotations - Nextcloud 21 · Issue #21 · strukturag/pdfdraw · GitHub
- Preview Generator - Unmaintained Github issue
- Radio - Issues · onny / nextcloud-app-radio · GitLab
- Readme.md - README.md not compatible with Nextcloud 21.0.x (#68) · Issues · uncloud / files_readmemd · GitLab
- Share Permissions - NC22 Support · Issue #6 · nextcloud/sharepermissions · GitHub
- Social Sharing via Diaspora - Update for Nextcloud 22 · Issue #50 · nextcloud/socialsharing · GitHub
- Social Sharing via Email - Update for Nextcloud 22 · Issue #50 · nextcloud/socialsharing · GitHub
- Social Sharing via Facebook - https://github.com/nextcloud/socialsharing/issues/50
- Social Sharing via Twitter - Update for Nextcloud 22 · Issue #50 · nextcloud/socialsharing · GitHub
- Social - Social on Nextcloud >=22 · Issue #1290 · nextcloud/social · GitHub
- Transmission - Version 22 support · Issue #8 · qdii/transmission-nc · GitHub
- Two Factor WebAuthn - Accepting Pull Requests Nextcloud 21 Support · Issue #49 · nextcloud/twofactor_webauthn · GitHub
- W2G2 - W2G2 - Apps - App Store - Nextcloud
App Name - link to the project Github issue. Please file an issue if you find an unsupported app in the appstore and no one has reported incompatibility. Check the box once it is supported.
Linked Version 21 Compatibility List
Fixed
- Duplicate Finder - Version 22 Support · Issue #31 · PaulLereverend/NextcloudDuplicateFinder · GitHub
- Extract - Nextcloud 22 App "Extract" cannot be installed because it is not compatible with this version of the server. · Issue #72 · PaulLereverend/NextcloudExtract · GitHub
- Flowupload - Nextcloud 22 · Issue #305 · e-alfred/flowupload · GitHub
- Metadata - Update Nextcloud version 22 · Issue #80 · gino0631/nextcloud-metadata · GitHub
- Ransomware Protection - Version 22 support · Issue #103 · nextcloud/ransomware_protection · GitHub
- Workflow OCR - NC22 Support · Issue #58 · R0Wi/workflow_ocr · GitHub
- - Activities for shared file downloads - Enable Support for Nextcloud 22 · Issue #76 · nextcloud/files_downloadactivity · GitHub
- Activities for shared file downloads, visible to all admins - Nextcloud 22 compatibility · Issue #24 · TimoKunze/files_trackdownloads · GitHub
- BigBLueButton integration - cloud_bbb/info.xml at master · sualko/cloud_bbb · GitHub , Fix:Install on NC 22 failed by pasith3e · Pull Request #166 · sualko/cloud_bbb · GitHub and more
- Bookmarks - Enable Support for Nextcloud 22 · Issue #1590 · nextcloud/bookmarks · GitHub.
- Camera RAW Previews - Update Nextcloud version 22 · Issue #71 · ariselseng/camerarawpreviews · GitHub
- Carnet - Carnet not working with Nextcloud 22 · Issue #159 · CarnetApp/CarnetNextcloud · GitHub
- Cookbook - Nextcloud 22 compatibility · Issue #764 · nextcloud/cookbook · GitHub
- Forms - Enable Support for Nextcloud 22 · Issue #991 · nextcloud/forms · GitHub
- Jitsi Integration - https://pubcode.weimann.digital/projects/nextcloud-jitsi/issues/list
- Keeweb - Nextcloud 22 Support · Issue #185 · jhass/nextcloud-keeweb · GitHub
- Link Editor - NC22 Support · Issue #55 · te-online/files_linkeditor · GitHub
- Mindmap - NC22 Support · Issue #154 · ACTom/files_mindmap · GitHub
- Quick Notes - Allow nunlable to booleans needed due NC 22 changes. by matiasdelellis · Pull Request #67 · matiasdelellis/quicknotes · GitHub
- Quota Warning - Nextcloud 22 compatibility · Issue #79 · nextcloud/quota_warning · GitHub
- Tasks - Nextcloud 22 compatibility · Issue #1676 · nextcloud/tasks · GitHub
- Sharepoint Backend - Update stable22 target versions by nickvergessen · Pull Request #106 · nextcloud/sharepoint · GitHub
- Two Factor Admin - Prepare release 3.1.0 by mejo- · Pull Request #209 · nextcloud/twofactor_admin · GitHub
- Two Factor Email Provider - NC22 Support · Issue #187 · nursoda/twofactor_email · GitHub
- Two Factor Nextcloud Notifications - Update Nextcloud version 22 · Issue #536 · nextcloud/twofactor_nextcloud_notification · GitHub
- Workflow External Scripts - Update version on master by nickvergessen · Pull Request #95 · nextcloud/workflow_script · GitHub
- Workflow PDF - Nextcloud 22 compatibility · Issue #340 · nextcloud/workflow_pdf_converter · GitHub
