Nextcloud version (eg, 20.0.5): 24.0.0.12
Operating system and version (eg, Ubuntu 20.04): DietPi v8.1
Apache or nginx version (eg, Apache 2.4.25): Not using nginx
PHP version (eg, 7.4): 8.0.19
Mount external storage via sshfs, giving it uid=33 and gid=33 to make sure www-data is the owner of the mount point. Mount that ssfs directory into the nextcloud docker container (I used /mnt/nextcloud as the internal mount point). Confirmed that the owner and group transferred to the docker container.
Try adding that directory as external storage in Settings, but it doesn’t work.
OCP\Files\StorageNotAvailableException: Storage with mount id 1 is not available
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'oc5eaz45jcal',
'passwordsalt' => '<salt>',
'secret' => '<secret>',
0 => '<ip-addr>',
'version' => '24.0.0.12',
'overwrite.cli.url' => '<ip-addre>',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb',
'dbuser' => '<user>',
'dbpassword' => '<pwd>',
N/A
nextcloud.log Error:
{"reqId":"7hQa2VZOpT7BR7vpCXtL","level":2,"time":"2022-05-20T19:30:48+00:00","remoteAddr":"192.168.29.155","user":"parag","app":"no app in context","method":"PROPFIND","url":"/remote.php/dav/files/parag/","message":"Error while getting quota info, using root quota","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:100.0) Gecko/20100101 Firefox/100.0","version":"24.0.0.12","exception":{"Exception":"OCP\\Files\\StorageNotAvailableException","Message":"Storage with mount id 1 is not available","Code":1,"Trace":[{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php","line":548,"function":"getAvailability","class":"OC\\Files\\Storage\\FailedStorage","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php","line":548,"function":"getAvailability","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Availability.php","line":81,"function":"getAvailability","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Availability.php","line":92,"function":"isAvailable","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Availability.php","line":342,"function":"checkAvailability","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->","args":[]},{"file":"/var/www/html/lib/private/Files/Storage/Wrapper/Wrapper.php","line":334,"function":"free_space","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->","args":[""]},{"file":"/var/www/html/lib/private/legacy/OC_Helper.php","line":548,"function":"free_space","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":[""]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Directory.php","line":341,"function":"getStorageInfo","class":"OC_Helper","type":"::","args":["/parag/files/Local",{"__class__":"OC\\Files\\Node\\Folder"},false]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":765,"function":"getQuotaInfo","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->","args":[]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"Sabre\\DAV\\{closure}","class":"Sabre\\DAV\\CorePlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":769,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->","args":["{DAV:}quota-available-bytes",{"__class__":"Closure"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Connector\\Sabre\\Directory"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["propFind",[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Connector\\Sabre\\Directory"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Connector\\Sabre\\Directory"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/parag",["{DAV:}getlastmodified","{DAV:}getetag","{DAV:}getcontenttype","{DAV:}resourcetype","{http://owncloud.org/ns}fileid","And 15 more entries, set log level to debug to see all entries"],1]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\Xml\\Writer","elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[]},{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":166,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Files/Storage/FailedStorage.php","Line":209,"Hint":"Storage is temporarily not available","Previous":{"Exception":"OCP\\Files\\StorageNotAvailableException","Message":"Storage with mount id 1 is not available","Code":1,"Trace":[{"function":"OCA\\Files_External\\Config\\{closure}","class":"OCA\\Files_External\\Config\\ConfigAdapter","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/files_external/lib/Config/ConfigAdapter.php","line":137,"function":"array_map","args":[{"__class__":"Closure"},{"1":"*** sensitive parameter replaced ***"},{"1":"*** sensitive parameter replaced ***"}]},{"file":"/var/www/html/lib/private/Files/Config/MountProviderCollection.php","line":124,"function":"getMountsForUser","class":"OCA\\Files_External\\Config\\ConfigAdapter","type":"->","args":[{"__class__":"OC\\User\\User"},{"__class__":"OC\\Files\\Storage\\StorageFactory"}]},{"file":"/var/www/html/lib/private/Files/SetupManager.php","line":213,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->","args":[{"__class__":"OC\\User\\User"},{"__class__":"OC\\Files\\Mount\\Manager"},{"__class__":"Closure"}]},{"file":"/var/www/html/lib/private/Files/SetupManager.php","line":302,"function":"OC\\Files\\{closure}","class":"OC\\Files\\SetupManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/SetupManager.php","line":214,"function":"setupForUserWith","class":"OC\\Files\\SetupManager","type":"->","args":[{"__class__":"OC\\User\\User"},{"__class__":"Closure"}]},{"file":"/var/www/html/lib/private/Files/SetupManager.php","line":386,"function":"setupForUser","class":"OC\\Files\\SetupManager","type":"->","args":[{"__class__":"OC\\User\\User"}]},{"file":"/var/www/html/lib/private/Files/Mount/Manager.php","line":128,"function":"setupForPath","class":"OC\\Files\\SetupManager","type":"->","args":["/parag/files",true]},{"file":"/var/www/html/lib/private/Files/View.php","line":1411,"function":"findIn","class":"OC\\Files\\Mount\\Manager","type":"->","args":["/parag/files"]},{"file":"/var/www/html/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["/parag/files"]},{"file":"/var/www/html/lib/private/Files/Node/LazyUserFolder.php","line":43,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/parag/files"]},{"function":"OC\\Files\\Node\\{closure}","class":"OC\\Files\\Node\\LazyUserFolder","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":69,"function":"call_user_func","args":[{"__class__":"Closure"}]},{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":208,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["getId",[]]},{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Node.php","line":247,"function":"getId","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":[]},{"file":"/var/www/html/apps/text/lib/DAV/WorkspacePlugin.php","line":102,"function":"getId","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->","args":[]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"OCA\\Text\\DAV\\WorkspacePlugin","type":"->","args":[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Files\\FilesHome"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["propFind",[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Files\\FilesHome"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\DAV\\PropFind"},{"__class__":"OCA\\DAV\\Files\\FilesHome"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->","args":["files/parag",["{DAV:}getlastmodified","{DAV:}getetag","{DAV:}getcontenttype","{DAV:}resourcetype","{http://owncloud.org/ns}fileid","And 15 more entries, set log level to debug to see all entries"],1]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\Xml\\Writer","elementMap":[],"contextUri":"/remote.php/dav/","namespaceMap":{"DAV:":"d","http://sabredav.org/ns":"s","http://owncloud.org/ns":"oc","http://nextcloud.org/ns":"nc"},"classMap":[]},{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Generator"},false]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["method:PROPFIND",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":352,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":166,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/files_external/lib/Config/ConfigAdapter.php","Line":142,"Hint":"Storage is temporarily not available"},"CustomMessage":"Error while getting quota info, using root quota"}}
I have an external storage server setup, that I have mounted on my Docker host via SFTP. I used the default setup instructions to setup Nextcloud with MariaDB via docker-compose, and mounted the SFTP instance to the /mnt/homeserver directory inside the nextcloud docker container. However, when I enable the External Storage addon and try adding the directory via the Local option, it fails.
From what I can tell, the problem is probably that the mounted directory inside the docker container is owned by root, causing Nextcloud to not be able to read it. Is that the correct reason, or is something else wrong that is causing this issue? I would use the SFTP option in the External Storage menu, but as far as I know, I can’t access machines on the LAN from inside a docker container (I would be gladly proven wrong if that isn’t the case).
