Currently using nextcloud 14.03 working great with zpush. The issue im having is that the contacts do not sync with zpush. Whats odd is that the calendar, tasks work perfectly. I checked the error logs but nothing odd
when i copy the URL of the contact page on next cloud
https://mail.mydomain.com/remote.php/dav/addressbooks/users/myusername/contacts/
// BackendCardDAV settings
// Server protocol: http or https
define('CARDDAV_PROTOCOL', 'https');
// Server name
define('CARDDAV_SERVER', 'mail.mydomain,.com');
// Server port
define('CARDDAV_PORT', '443');
// Server path to the addressbook, or the principal with the addressbooks
// If your user has more than 1 addressbook point it to the principal.
// Example: user test@domain.com will have 2 addressbooks
// http://localhost/caldav.php/test@domain.com/addresses/personal
// http://localhost/caldav.php/test@domain.com/addresses/work
// You set the CARDDAV_PATH to '/caldav.php/%u/addresses/' and personal and work will be autodiscovered
// %u: replaced with the username
// %d: replaced with the domain
// Add the trailing /
define('CARDDAV_PATH', '/remote.php/dav/addressbooks/users/%u/contacts/');
// Server path to the default addressbook
// Mobile device will create new contacts here. It must be under CARDDAV_PATH
define('CARDDAV_DEFAULT_PATH', '/remote.php/dav/addressbooks/users/%u/contacts/');
// Server path to the GAL addressbook. This addressbook is readonly and searchable by the user, but it will NOT be synced.
// If you don't want GAL, comment it
define('CARDDAV_GAL_PATH', '/remote.php/dav/addressbooks/users/%u/contacts/');
// Minimal length for the search pattern to do the real search.
define('CARDDAV_GAL_MIN_LENGTH', 5);
// Addressbook display name, the name showed in the mobile device
define('CARDDAV_CONTACTS_FOLDER_NAME', '%u Addressbook');
// If the CardDAV server supports the sync-collection operation
// DAViCal and SabreDav support it, but Owncloud, SOGo don't
// SabreDav version must be at least 1.9.0, otherwise set this to false
// Setting this to false will work with most servers, but it will be slower: 1 petition for the href of vcards, and 1 petition for each vcard
define('CARDDAV_SUPPORTS_SYNC', true);
/ / If the CardDAV server supports the FN attribute for searches
// DAViCal supports it, but SabreDav, Owncloud and SOGo don't
// Setting this to true will search by FN. If false will search by sn, givenName and email
// It's safe to leave it as false
define('CARDDAV_SUPPORTS_FN_SEARCH', false);
// If your carddav server needs to use file extension to recover a vcard.
// Davical needs it
// SOGo official demo online needs it, but some SOGo installation don't need it, so test it
define('CARDDAV_URL_VCARD_EXTENSION', '.vcf');
EDIT:
So after troubleshooting more i figured out something is odd with the combined backend i tried with a carddav app on android perfectly worked then saw another error
/var/www/zpush/src/backend/carddav/carddav.php:569 Undefined offset: 0 (8)
/var/www/zpush/src/backend/carddav/carddav.php:570 Undefined offset: 0 (8)
