Nextcloud version 12.0.3
Zimbra Drive NextCloud Version: 0.8.15
Operating system and version Centos 7
PHP version 7.0.25
SSL Let’s Encrypt : yes
Zimbra
Zimbra zcs-8.7.11_GA_1854
SSL Let’s Encrypt Yes
Is this the first time you’ve seen this error?: yes
Can you reliably replicate it? (If so, please outline steps):
the integration with zimbra and nextcloud.
when I do the test from nexcloud, the following error occurs:
[FAILED] Zimbra Drive extension connection test: Impossible to connect to Zimbra Drive extension (response http code: 400) URL: https: // midomain: 443 / service / extension / ZimbraDrive_ConnectivityTest VALUE: 2
and from the zimbra I have no problems the drive tab is visualized with the content that is in nextcloud,
but if I’m going to authenticate with a zimbra user in nextcloud, it does not enter.
Doing the test from Nextcloud shows the following:
[OK] Zimbra Drive app installation test : Zimbra Drive app is installed.
[OK] Enabled Zimbra’s users test : Zimbra’s users are enabled.
[OK] Enabled Zimbra’s user login : Zimbra Drive authentication is enabled.
[OK] Is server url set test : The server url is set.
[OK] Is server port set test : The server port is set.
[OK] Zimbra host connection test : Zimbra Drive app can reach the host.
[OK] Zimbra authentication page connection test : Zimbra Drive app can reach Zimbra’s authentication page.
[FAILED] Zimbra Drive extension connection test : Impossible to connect to Zimbra Drive extension (response http code: 400 ) - URL: https:midomain:443/service/extension/ZimbraDrive_ConnectivityTest VALOR: 2
‘instanceid’ => ‘ID’,
‘passwordsalt’ => ‘SECRET’,
‘secret’ => ‘SECRET’,
‘trusted_domains’ =>
0 => ‘IP’,
1 => ‘MIDOMAIN.COM’,
‘datadirectory’ => ‘/RUTA/nextcloud/data’,
‘overwrite.cli.url’ => ‘https://MIDOMIAN.COM’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘12.0.3.3’,
‘dbname’ => ‘DB NAME’,
‘dbhost’ => ‘localhost’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘USER’,
‘dbpassword’ => ‘PASSWD’,
‘installed’ => true,
‘onlyoffice’ =>
‘verify_peer_off’ => true,
‘user_backends’ =>
0 =>
‘class’ => ‘OCA\ZimbraDrive\Auth\ZimbraUsersBackend’,
‘arguments’ =>
‘ldapIgnoreNamingRules’ => false,
‘ldapProviderFactory’ => ‘\OCA\User_LDAP\LDAPProviderFactory’,
The output of your Apache/nginx/system log in /var/log/httpd/:
