Yunohost -- Webserver does not serve `.mjs` files
    • 32.0.4
    • Yunohost / Debian
    • nginx?
    • nginx
    • 8.3.29
    • Yes
    • I reinstalled Nextcloud
    • Yunohost
    • Not that I know of
JavaScript modules support
Your webserver does not serve .mjs` files using the JavaScript MIME type. This will break some apps by preventing browsers from executing the JavaScript files. You should configure your webserver to serve `.mjs` files with either the `text/javascript` or `application/javascript` MIME type.
Not sure if it’s replicable.
{"reqId":"0hoMZEGBtHuduAUTopHq","level":2,"time":"2026-01-16T08:15:03+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","scriptName":"/var/www/nextcloud/cron.php","message":"failed to create instance of background job: OCA\\AppAPI\\BackgroundJob\\ExAppInitStatusCheckJob","userAgent":"--","version":"32.0.4.1","occ_command":["/var/www/nextcloud/cron.php"],"exception":{"Exception":"OC\\AppFramework\\Utility\\QueryNotFoundException","Message":"Could not resolve OCA\\AppAPI\\BackgroundJob\\ExAppInitStatusCheckJob! Class \"OCA\\AppAPI\\BackgroundJob\\ExAppInitStatusCheckJob\" does not exist","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":140,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/ServerContainer.php","line":154,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":45,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/nextcloud/lib/public/Server.php","line":37,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":322,"function":"get","class":"OCP\\Server","type":"::"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":201,"function":"buildJob","class":"OC\\BackgroundJob\\JobList","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":157,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":129,"message":"failed to create instance of background job: OCA\\AppAPI\\BackgroundJob\\ExAppInitStatusCheckJob","exception":{},"CustomMessage":"failed to create instance of background job: OCA\\AppAPI\\BackgroundJob\\ExAppInitStatusCheckJob"}}
N/A
The output of your Apache/nginx/system log in /var/log/mydomain.tld-error.log:
2026/01/16 06:2026/01/16 06:10:52 [error] 220373#220373: *26610 open() "/usr/share/nginx/html/.well-known/caldav" failed (2: No such file or directory), client: 127.0.0.1, server: mydomain.tld, request: "GET /.well-known/caldav HTTP/2.0", host: "mydomain.tld"
2026/01/16 06:10:52 [error] 220374#220374: *26611 open() "/usr/share/nginx/html/.well-known/carddav" failed (2: No such file or directory), client: 127.0.0.1, server: mydomain.tld, request: "GET /.well-known/carddav HTTP/2.0", host: "mydomain.tld"
            "localhost",
            "mydomain.tld"
        "dbtype": "mysql",
        "version": "32.0.4.1",
        "overwrite.cli.url": "https:\/\/mydomain.tld\/",
        "dbport": "",
        "mysql.utf8mb4": true,
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "updatechecker": false,
        "integrity.check.disabled": true,
        "filelocking.enabled": true,
        "redis": {
            "port": "6379",
            "timeout": "0.0",
        "hashing_default_password": true,
        "localstorage.allowsymlinks": true,
        "default_phone_region": "",
        "mail_smtpmode": "smtp",
        "mail_smtpport": "25",
        "mail_smtpauth": 1,
        "mail_sendmailmode": "smtp",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": true,
                "verify_peer": false,
                "verify_peer_name": false
        "logout_url": "https:\/\/mydomain.tld\/yunohost\/sso\/?action=logout&r=aHR0cHM6Ly9zbHVpbWVycy5uZXQv",
        "app_install_overwrite": [],
        "loglevel": 2
  - activity: 5.0.0-dev.0
  - calendar: 6.1.4
  - circles: 32.0.0
  - comments: 1.22.0
  - contacts: 8.2.1
  - contactsinteraction: 1.13.1
  - dashboard: 7.12.0
  - dav: 1.34.2
  - deck: 1.16.3
  - federation: 1.22.0
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - integration_deepl: 2.1.0
  - logreader: 5.0.0-dev.0
  - mail: 5.6.7
  - music: 2.5.1
  - notes: 4.12.4
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - spreed: 22.0.8
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - tables: 1.0.2
  - text: 6.0.1
  - theming: 2.7.0
  - user_ldap: 1.23.0
  - user_status: 1.12.0
  - user_usage_report: 3.0.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0 (installed 32.0.0)
  - encryption: 2.20.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0 (installed 1.21.0)
Other
$ cat /etc/nginx/mime.types | grep mjs
text/javascript                       mjs;
$ cat nextcloud.conf | grep mjs
# Set .mjs MIME types
  location ~ .(?:css|js|mjs|svg|gif|ico|jpg|png|webp|wasm|tflite|map|ogg|flac)$ {
I found the question now.. not sure still current.
Please review NGINX configuration — Nextcloud latest Administration Manual latest documentation for the official installation guides.
also check the file as “javascript” is not only .mjs it is also .js and both are required
look at other topics tagged mjs for ideas
