- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
- Nextcloud 31.0.11~ynh1
Yunohost12.1.39 (stable)
- PHP version (e.g, 8.3):
- Is this the first time you’ve seen this error? (Yes / No): Yes
When I tried t add a non standard WebDAV server.
bare metal
NO
Not sure if this is an issue or a user error really but you guys are usually excellent at giving pointers in the right direction (cheers!) so her goes …
I have a number of webDav drives connected to my Nextcloud server app that use the default ports 445 or 80, these all work fine. I have one webDAV server that uses a wierd port - 6008. That’s not normally an issue for most apps (e.g. phone app file managers or my laptop, as I can specify the port to use at the web address. However, in the Nextcloud app (on my YNH server) in the External Storage section there does not seem to be an option to specify the port for WebDAV to use. It seems to assume the default options only. Am I wrong? Am I missing an option to customise the port? Any advice or confirmation that this is indeed a missing feature on Nextcloud would be welcome. Many thanks in advance.
Attach external storage WebDAV drive that uses port 6008
no real logs to add, it just refuses to connect.
not applicable
no reverse proxy in use
I am a newbie and am struggling to find this file. I feel that it is not really a bug, its either user error (very possible) or dre I suggest, a missing feature.
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
