Write Read Permissions Docker Synology installation
The community help forum (help.nextcloud.com) is for home and non-enterprise users. Support is provided by other community members on a best effort / ā€œas availableā€ basis. All of those responding are volunteering their time to help you.
    • 32.0.1
    • Debian with Docker
    • See YAML
    • nginx proxy manager (on another jumpserver)
I have installed Nextcloud with Docker-Compose on my Debian ā€œDockerrunnerā€ VM.
This is my Portainer-Stack:
version: '2'
services:
  mariadb:
    image: mariadb
    restart: always
    command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW --innodb-file-per-table=1 --skip-innodb-read-only-compressed
    ports:
      - 9022:3306
    volumes:
      - /root/nextcloud/mariadb:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=PASSWORD
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=root
  nextcloud:
    image: nextcloud
    restart: always
    ports:
      - 8040:80
    links:
      - mariadb:mysql
    volumes:
      - nextcloud-html:/var/www/html
      - nextcloud-apps:/var/www/html/custom_apps
      - nextcloud-config:/var/www/html/config
      - nextcloud-data:/var/www/html/data
    environment:
      - MYSQL_PASSWORD=PASSWORD
      - MYSQL_USER=root
      - MYSQL_HOST=mariadb
volumes:
  nextcloud-data:
    external: true
  nextcloud-html:
    external: true
  nextcloud-config:
    external: true
  nextcloud-apps:
    external: true
As you can see my volumes are external, as i have most of the time all docker volumes on my NAS. This are mounted via the ā€œvolumesā€ tab in Portainer.
This Docker VM is available via VPN ←→ to my Jumpserver (Debian Server hosted in a data center) and on this debian server there is an nginx proxy manager running doing my https reverse proxy and domain.
I started everything up and i installed the app ā€œexternal data storageā€ and mounted my SMB share to my files in nextcloud - this is working great and i can add and remove folders and files.
But i canĀ“t delete the ā€œstandardā€ folders and files created by the installation → on my Volume Data → on my Synology NAS (remote mounted via volumes in Portainer).
I can delete the files on the NAS directly and it will took some time and they disappear on nextcloud - or i can remove them then. But i think there are some write / read permission errors on this side.
Can you help me to fix this? I“m new to nextcloud. If you need more information i can search for them. :slight_smile:
Also my SMB Share External Storage is not visible in the Nextcloud iOS App - Do i have to do more stuff on this side? In the web UI i can see them.
Thanks for your help!
