Wouldn't it be nice to integrate a FOSS IT asset management system?
I recently found out about a nice FOSS project helping with your (home) IT assets/licenses and how to manage them. To be found here
it apparently relys upon the same tools as NC and so I was wondering if it would be easy (or not) to integrate that one (as an app) to NC or not.
At least it would make sense to have it, I think.
I’m also interested in this! Have you found a way for this to work?
There is no Nextcloud integration or app available afaik. But according to their documentation it should be fairly easy to install beside Nextcloud on the same server, if you are already using a LAMP or LEMP Stack to serve Nextcloud. However, I would probably not want to expose it directly to the Internet, so maybe it would be better to install it on a separate server / VM anyways.
