Hello Forum,
I hope you can help me with my problem:
Nextcloud version (eg, 20.0.5): 27.0.0.1
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.25.1
PHP version (eg, 7.4): 8.2
ISSUE:
I tried to set up various flows. Tried both in the admin panel as well as user. The flows don´t run, however. Trying to troubleshoot, I checked the database (Mariadb) and found, that in the oc_background-jobs (or called similar) table no entry for “OCA/workflow” is created as it should (tried to implement workflow_ocr and PDF-conversion workflow as well as notification workflow). The cron job seems to be running without issues.
I think the issue might lay in the workflow engine itself.
N
- install workflow plugin
- set up (tag assigned, file created and any combination of these)
- wait for cron job (or force it)
- expected behavior: get notification after a tag was assigned, get a .odt converted to PDF, get OCR done on a PDF or a jpg.
[core] Error: TypeError: OCA\GroupFolders\ACL\ACLManagerFactory::getACLManager(): Argument #1 ($user) must be of type OCP\IUser, null given, called in /var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php on line 206 at <<closure>>
0. /var/www/nextcloud/apps/groupfolders/lib/Mount/MountProvider.php line 206
OCA\GroupFolders\ACL\ACLManagerFactory->getACLManager()
1. /var/www/nextcloud/apps/groupfolders/lib/Versions/VersionsBackend.php line 172
OCA\GroupFolders\Mount\MountProvider->getMount()
2. /var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php line 68
OCA\GroupFolders\Versions\VersionsBackend->getAllVersionedFiles()
3. /var/www/nextcloud/apps/groupfolders/lib/Versions/GroupVersionsExpireManager.php line 59
OCA\GroupFolders\Versions\GroupVersionsExpireManager->expireFolder()
4. /var/www/nextcloud/apps/groupfolders/lib/BackgroundJob/ExpireGroupVersions.php line 43
OCA\GroupFolders\Versions\GroupVersionsExpireManager->expireAll()
5. /var/www/nextcloud/lib/public/BackgroundJob/Job.php line 86
OCA\GroupFolders\BackgroundJob\ExpireGroupVersions->run()
6. /var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php line 103
OCP\BackgroundJob\Job->start()
7. /var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php line 93
OCP\BackgroundJob\TimedJob->start()
8. /var/www/nextcloud/cron.php line 152
OCP\BackgroundJob\TimedJob->execute()
at 2023-08-08T13:55:02+02:00
'passwordsalt' => '****PRIVATE****',
'secret' => '****PRIVATE****',
0 => '****PRIVATE****',
1 => '****PRIVATE****',
2 => '192.168.178.201',
'datadirectory' => '/media/****PRIVATE****/ncdata',
'version' => '27.0.1.2',
'overwrite.cli.url' => 'https://****PRIVATE****',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'default_language' => 'de',
'enable_previews' => true,
'dbuser' => '****PRIVATE****',
'dbpassword' => '****PRIVATE****',
'instanceid' => 'oc92ig3oi41c',
'overwritehost' => '****PRIVATE****',
'activity_expire_days' => 14,
'allow_local_remote_servers' => true,
'auth.bruteforce.protection.enabled' => true,
'blacklisted_files' =>
0 => '.htaccess',
1 => 'Thumbs.db',
2 => 'thumbs.db',
'cron_log' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
'filesystem_check_changes' => 0,
'integrity.check.disabled' => false,
'knowledgebaseenabled' => false,
'log_rotate_size' => '104857600',
'loglevel' => 2,
'preview_max_x' => 1024,
'preview_max_y' => 768,
'preview_max_scale_factor' => 1,
'preview_libreoffice_path' => '/usr/bin/libreoffice',
'profile.enabled' => false,
'redis' =>
'port' => 0,
'password' => '****PRIVATE****',
'timeout' => 0.5,
'dbindex' => 1,
'quota_include_external_storage' => false,
'share_folder' => '/Freigaben',
'skeletondirectory' => '',
'trashbin_retention_obligation' => 'auto, 7',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'system',
'mail_domain' => '****PRIVATE****',
'mail_smtphost' => '****PRIVATE****',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => '****PRIVATE****,
'mail_smtppassword' => '****PRIVATE****',
'default_locale' => 'de_DE',
'data-fingerprint' => 'fead994bf6459f6edb3f3a9caf8a4bf6',
additional config:
0 => '.htaccess',
1 => 'Thumbs.db',
2 => 'thumbs.db',
'cron_log' => true,
0 => 'OC\Preview\PNG',
1 => 'OC\Preview\JPEG',
2 => 'OC\Preview\GIF',
3 => 'OC\Preview\BMP',
4 => 'OC\Preview\XBitmap',
5 => 'OC\Preview\Movie',
6 => 'OC\Preview\PDF',
7 => 'OC\Preview\MP3',
8 => 'OC\Preview\TXT',
9 => 'OC\Preview\MarkDown',
'loglevel' => 2,
'memcache.local' => '\OC\Memcache\APCu',
'memcache.locking' => '\OC\Memcache\Redis',
'redis' =>
'port' => 0,
'timeout' => 0.5,
'dbindex' => 1,
2023/08/08 12:59:02 [warn] 695#695: "ssl_stapling" ignored, host not found in OCSP responder "r3.o.lencr.org" in the certificate "/etc/letsencrypt/ecc-certs/fullchain.pem"
2023/08/08 12:59:02 [warn] 695#695: "ssl_stapling" ignored, host not found in OCSP responder "r3.o.lencr.org" in the certificate "/etc/letsencrypt/rsa-certs/fullchain.pem"
2023/08/08 12:59:04 [error] 821#821: *3 open() "/etc/nginx/html/us" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /us HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:04 [error] 821#821: *4 open() "/etc/nginx/html/status/format/json" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /status/format/json HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:04 [error] 821#821: *5 "/etc/nginx/html/api/index.html" is not found (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /api/ HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:04 [error] 821#821: *8 open() "/etc/nginx/html/status" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /status?full&json HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:06 [error] 821#821: *11 open() "/etc/nginx/html/basic_status" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /basic_status HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:06 [error] 821#821: *17 open() "/etc/nginx/html/server-status" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /server-status?auto HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:06 [error] 821#821: *20 open() "/etc/nginx/html/server-status" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /server-status?auto HTTP/1.1", host: "127.0.0.1"
2023/08/08 12:59:06 [error] 821#821: *21 open() "/etc/nginx/html/admin/api.php" failed (2: No such file or directory), client: 127.0.0.1, server: 127.0.0.1, request: "GET /admin/api.php?auth=&version=true HTTP/1.1", host: "127.0.0.1"
Crontab of www-data:
*/5 * * * * php -f /var/www/nextcloud/cron.php > /dev/null 2>&1
MariaDB oc_jobs:
MariaDB [nextcloud]> SELECT * FROM oc_jobs;
| id | class | argument | last_run | last_checked | reserved_at | execution_duration | argument_hash | time_sensitive |
| 1 | OCA\ContactsInteraction\BackgroundJob\CleanupJob | null | 1691491921 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 2 | OCA\UpdateNotification\Notification\BackgroundJob | null | 1691491930 | 1691502618 | 0 | 16 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 4 | OCA\UserStatus\BackgroundJob\ClearOldStatusesBackgroundJob | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 6 | OCA\Text\Cron\Cleanup | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 7 | OCA\Files_Sharing\DeleteOrphanedSharesJob | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 8 | OCA\Files_Sharing\ExpireSharesJob | null | 1691492015 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 9 | OCA\Files_Sharing\BackgroundJob\FederatedSharesDiscoverJob | null | 1691492023 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 10 | OCA\Photos\Jobs\AutomaticPlaceMapperJob | null | 1691492026 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 11 | OCA\Files_Trashbin\BackgroundJob\ExpireTrash | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 12 | OCA\Files\BackgroundJob\ScanFiles | null | 1691502001 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 13 | OCA\Files\BackgroundJob\DeleteOrphanedItems | null | 1691499001 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 14 | OCA\Files\BackgroundJob\CleanupFileLocks | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 15 | OCA\Files\BackgroundJob\CleanupDirectEditingTokens | null | 1691502001 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 16 | OCA\Files\BackgroundJob\DeleteExpiredOpenLocalEditor | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 17 | OCA\NextcloudAnnouncements\Cron\Crawler | null | 1691461501 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 18 | OCA\ServerInfo\Jobs\UpdateStorageStats | null | 1691495402 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 19 | OCA\Notifications\BackgroundJob\GenerateUserSettings | null | 1691448601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 20 | OCA\Notifications\BackgroundJob\SendNotificationMails | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 21 | OCA\Activity\BackgroundJob\EmailNotification | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 22 | OCA\Activity\BackgroundJob\ExpireActivities | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 23 | OCA\Activity\BackgroundJob\DigestMail | null | 1691499001 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 24 | OCA\Files_Versions\BackgroundJob\ExpireVersions | null | 1691501702 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 25 | OCA\Circles\Cron\Maintenance | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 26 | OCA\DAV\BackgroundJob\CleanupDirectLinksJob | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 27 | OCA\DAV\BackgroundJob\UpdateCalendarResourcesRoomsBackgroundJob | null | 1691499001 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 28 | OCA\DAV\BackgroundJob\CleanupInvitationTokenJob | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 29 | OCA\DAV\BackgroundJob\EventReminderJob | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 30 | OCA\DAV\BackgroundJob\CalendarRetentionJob | null | 1691483401 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 31 | OCA\DAV\BackgroundJob\PruneOutdatedSyncTokensJob | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 32 | OCA\WorkflowEngine\BackgroundJobs\Rotate | null | 1691495402 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 33 | OC\Authentication\Token\TokenCleanupJob | null | 1691456402 | 1691491602 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 34 | OC\Log\Rotate | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 35 | OC\Preview\BackgroundCleanupJob | null | 1691499001 | 1691502601 | 0 | 1 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 45 | OCA\AdminAudit\BackgroundJobs\Rotate | null | 1691495402 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 46 | OCA\Contacts\Cron\SocialUpdateRegistration | null | 1690919101 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 47 | OCA\Calendar\BackgroundJob\CleanUpOutdatedBookingsJob | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 75 | OCA\Registration\BackgroundJob\ExpireRegistrations | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 76 | OCA\TwoFactorNextcloudNotification\BackgroundJob\CleanupTokens | null | 1691499002 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 79 | OCA\SuspiciousLogin\BackgroundJob\ETLJob | null | 1691499002 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 80 | OCA\SuspiciousLogin\BackgroundJob\TrainJobIpV4 | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 81 | OCA\SuspiciousLogin\BackgroundJob\TrainJobIpV6 | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 93 | OCA\Deck\Cron\DeleteCron | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 94 | OCA\Deck\Cron\ScheduledNotifications | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 95 | OCA\Deck\Cron\CardDescriptionActivity | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 96 | OCA\Deck\Cron\SessionsCleanup | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 97 | OCA\Mail\BackgroundJob\CleanupJob | null | 1691456402 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 98 | OCA\Mail\BackgroundJob\OutboxWorkerJob | null | 1691502302 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 99 | OCA\Mail\BackgroundJob\IMipMessageJob | null | 1691502601 | 1691502601 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 116 | OCA\Mail\BackgroundJob\SyncJob | {"accountId":1} | 1691502601 | 1691502601 | 0 | 1 | 562423afc287d53e27bc1d34fbc41ce5 | 1 |
| 117 | OCA\Mail\BackgroundJob\TrainImportanceClassifierJob | {"accountId":1} | 1691456402 | 1691474101 | 0 | 0 | 562423afc287d53e27bc1d34fbc41ce5 | 0 |
| 134 | OCA\Mail\BackgroundJob\PreviewEnhancementProcessingJob | {"accountId":1} | 1691502602 | 1691502602 | 0 | 0 | 562423afc287d53e27bc1d34fbc41ce5 | 1 |
| 166 | OCA\EndToEndEncryption\BackgroundJob\RollbackBackgroundJob | null | 1691502602 | 1691502602 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 1132 | OCA\Richdocuments\Backgroundjobs\ObtainCapabilities | null | 1691502602 | 1691502602 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 1133 | OCA\Richdocuments\Backgroundjobs\Cleanup | null | 1691502602 | 1691502602 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 1136 | OCA\Mail\BackgroundJob\SyncJob | {"accountId":3} | 1691502602 | 1691502602 | 0 | 6 | 377f64949c338b756bd9ce4d6e1db80b | 1 |
| 1137 | OCA\Mail\BackgroundJob\TrainImportanceClassifierJob | {"accountId":3} | 1691456402 | 1691474101 | 0 | 0 | 377f64949c338b756bd9ce4d6e1db80b | 0 |
| 1171 | OC\Core\BackgroundJobs\CleanupLoginFlowV2 | null | 1691502608 | 1691502608 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 1172 | OC\Security\Bruteforce\CleanupJob | null | 1691456402 | 1691491602 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 3435 | OCA\Mail\BackgroundJob\SyncJob | {"accountId":4} | 1691502608 | 1691502608 | 0 | 1 | 227712f808e18b80b419ddf7fa8cdf0e | 1 |
| 3436 | OCA\Mail\BackgroundJob\TrainImportanceClassifierJob | {"accountId":4} | 1691456402 | 1691474101 | 0 | 0 | 227712f808e18b80b419ddf7fa8cdf0e | 0 |
| 26556 | OCA\Mail\BackgroundJob\SyncJob | {"accountId":5} | 1691502609 | 1691502609 | 0 | 9 | 98e2219f8dabff2f439ec3c4cfc986ae | 1 |
| 26557 | OCA\Mail\BackgroundJob\TrainImportanceClassifierJob | {"accountId":5} | 1691456402 | 1691474101 | 0 | 0 | 98e2219f8dabff2f439ec3c4cfc986ae | 0 |
| 26587 | OCA\News\Cron\UpdaterJob | null | 1691499602 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 26597 | OCA\Mail\BackgroundJob\PreviewEnhancementProcessingJob | {"accountId":3} | 1691499602 | 1691502618 | 0 | 0 | 377f64949c338b756bd9ce4d6e1db80b | 1 |
| 26598 | OCA\Mail\BackgroundJob\PreviewEnhancementProcessingJob | {"accountId":4} | 1691499602 | 1691502618 | 0 | 0 | 227712f808e18b80b419ddf7fa8cdf0e | 1 |
| 26599 | OCA\Mail\BackgroundJob\PreviewEnhancementProcessingJob | {"accountId":5} | 1691499602 | 1691502618 | 0 | 0 | 98e2219f8dabff2f439ec3c4cfc986ae | 1 |
| 26600 | OCA\GroupFolders\BackgroundJob\ExpireGroupVersions | null | 1691499602 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 26601 | OCA\GroupFolders\BackgroundJob\ExpireGroupTrash | null | 1691499602 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 27891 | OCA\OpenAi\Cron\CleanupImageGenerations | null | 1691437517 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34892 | OCA\DAV\BackgroundJob\UploadCleanup | {"uid":"********************","folder":"web-file-upload-934a3b105e72869ada05673290313d59-1691281958672"} | 1691456402 | 1691474101 | 0 | 0 | bd8c47f6ffeb0a5fb440302147d25432 | 0 |
| 34913 | OCA\Analytics\BackgroundJob\Hourly | null | 1691500801 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34914 | OCA\Analytics\BackgroundJob\Daily | null | 1691424301 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34915 | OCA\Talk\BackgroundJob\ExpireSignalingMessage | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34916 | OCA\Talk\BackgroundJob\RemoveEmptyRooms | null | 1691473802 | 1691474101 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 0 |
| 34917 | OCA\Talk\BackgroundJob\ResetAssignedSignalingServer | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34919 | OCA\Talk\BackgroundJob\CheckHostedSignalingServer | null | 1691499602 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34920 | OCA\Talk\BackgroundJob\CheckMatterbridges | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34921 | OCA\Talk\BackgroundJob\ExpireChatMessages | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34922 | OCA\Music\BackgroundJob\Cleanup | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34923 | OCA\Music\BackgroundJob\PodcastUpdateCheck | null | 1691502618 | 1691502618 | 0 | 0 | 37a6259cc0c1dae299a7866489dff0bd | 1 |
| 34924 | OCA\DAV\BackgroundJob\UploadCleanup | {"***********************"} | 1691456402 | 1691474101 | 0 | 0 | aaa148acd67c8a41e43eac1f52df197a | 0 |
81 rows in set (0,001 sec)
App list:
- activity: 2.19.0
- admin_audit: 1.17.0
- analytics: 4.9.4
- announcementcenter: 6.6.1
- bruteforcesettings: 2.7.0
- calendar: 4.4.4
- circles: 27.0.1
- cloud_federation_api: 1.10.0
- comments: 1.17.0
- contacts: 5.3.2
- contactsinteraction: 1.8.0
- dashboard: 7.7.0
- dav: 1.27.0
- deck: 1.10.0
- end_to_end_encryption: 1.13.1
- federatedfilesharing: 1.17.0
- files: 1.22.0
- files_accesscontrol: 1.17.0
- files_automatedtagging: 1.17.0
- files_pdfviewer: 2.8.0
- files_rightclick: 1.6.0
- files_sharing: 1.19.0
- files_trashbin: 1.17.0
- files_versions: 1.20.0
- flow_notifications: 1.7.0
- forms: 3.3.1
- groupfolders: 15.0.1
- guests: 2.5.0
- integration_github: 2.0.6
- integration_openai: 1.0.11
- integration_replicate: 1.0.7
- logreader: 2.12.0
- lookup_server_connector: 1.15.0
- mail: 3.2.5
- music: 1.8.4
- news: 22.0.0
- nextcloud_announcements: 1.16.0
- notes: 4.8.1
- notifications: 2.15.0
- oauth2: 1.15.1
- password_policy: 1.17.0
- photos: 2.3.0
- previewgenerator: 5.3.0
- privacy: 1.11.0
- provisioning_api: 1.17.0
- recommendations: 1.6.0
- registration: 2.2.0
- related_resources: 1.2.0
- richdocuments: 8.1.1
- richdocumentscode: 23.5.202
- root_cache_cleaner: 0.1.5
- serverinfo: 1.17.0
- settings: 1.9.0
- sharebymail: 1.17.0
- side_menu: 3.10.3
- spreed: 17.0.3
- suspicious_login: 5.0.0
- systemtags: 1.17.0
- terms_of_service: 2.2.0
- text: 3.8.0
- theming: 2.2.0
- translate: 1.1.6
- twofactor_backupcodes: 1.16.0
- twofactor_nextcloud_notification: 3.7.0
- twofactor_totp: 9.0.0
- updatenotification: 1.17.0
- user_status: 1.7.0
- viewer: 2.1.0
- weather_status: 1.7.0
- workflow_ocr: 1.27.1
- workflow_pdf_converter: 1.12.0
- workflowengine: 2.9.0
- encryption: 2.15.0 (installed 2.15.0)
- federation: 1.17.0 (installed 1.17.0)
- files_external: 1.19.0
- firstrunwizard: 2.16.0 (installed 2.16.0)
- maps: 1.1.0 (installed 1.1.0)
- support: 1.10.0 (installed 1.10.0)
- survey_client: 1.15.0 (installed 1.15.0)
- talk_matterbridge: 1.26.0
- user_ldap: 1.17.0
