Workaround/fix for Thunderbird failing to connect to CardDav contacts?
  • Nextcloud Server version (e.g., 29.x.x): 33.0.2
  • PHP version (e.g, 8.3): 8.4
  • Are you using CloudfIare, mod_security, or similar?no
Thunderbird used to be able to use the CardDav address book, but Thunderbird 152 and 153 fail to connect/sync.
I think this is a Thunderbird bug (see my report) but I’m posting here just in case anyone has a workaround/hack. It’s really difficult not having my contacts in Thunderbird!
  1. Thunderbird addressbook → add address book. It asks for username and URL
  2. Enter my username, enter the https://example.org/remote.php/dav/addressbooks/users/myuser/Contacts/ URL, hit enter
    1. Says cannot connect - it doesn’t ask for a password(!)
  3. Enter my username, enter the https://myuser:appPassword@example.org/remote.php/dav/addressbooks/users/myuser/Contacts/ URL, hit enter
    1. connects and lists my contacts! But then clicking continue gives an error in Thunderbird can’t access property “then”, authPromise is undefined’. So fails.
nothing logged in nextcloud when this occurs.
Has anyone found a way to get it working (again)?
EDIT Aug 2026
The original problem with Thunderbird is when it has stored your server’s password. Then even after deleting the NC address book, the old credential is applied when you newly enter your URL to your webdav contacts causing auth fail. The solution is to go to Thunderbird settings, find the “saved passwords” and delete the ones belonging to your nextcloud domain. Then repeat the add-addressbook process. Now webdav contacts show. Upstream edits get synced to TB and TB edits+additions get synced to upstream, but upstream additions do not. So you may still be best using the CardBook plugin. :person_shrugging:
this does look like the Thunderbird issue you reported. Nextcloud’s normal setup should ask for a password after the server URL, so that missing prompt isn’t expected.
for now, I’d use CardBook. Nextcloud documents it as the contacts-only fallback: add a remote address book, choose CardDAV, then enter the server URL, username and password. use an app password if you have 2FA enabled, and don’t put credentials in the URL.
Thanks, this works!
