Hello new here. Also a Linux novice. I have installed nextcloud on an Odroid xu4 running dietpi.
I had lost my login, as the install was just a test, so I figured I’d just start over clear. Upon uninstalling nextcloud there was a prompt that some data would be backed up in case I wanted to install again.
When I did the new install I am taken to the original login screen, the setup wizard doesn’t load because it is using the old settings.
I had erased a folder under mnt/dietpi/nextcloud_data or something to that affect. The Linux file structure is foreign to me. But that didn’t help.
My goal is to just start from scratch but wasn’t wanting to wipe the entire device if I didn’t have to.
