... will not be accessible due to incompatible encoding
I am having problems with my nextcloud installation. After doing a filescan, all my data with German Umlaute (äöü) vanished. The error message just is:
“Entry “/Timo/files/Universität/ComputationalPhysics/Python für Physiker/Einführung in die Programmiertechniken (Prof. Dr. L. Pollet - SoSe 2017)/Übungsblätter” will not be accessible due to incompatible encoding”.
I remember that I even uploaded the data using Nextcloud on the Browser. I am hosting Nextcloud on a MacMini using a VM with Ubuntu 20.04 LTS.
Does anyone know how to solve that?
:wink: Nice. Sollte man endlich mal abschaffen.
Germanic umlaut - Wikipedia
Perhaps you find here a solution:
filescan retrun "entry will not be accessible due to incompatible encoding" · Issue #3136 · nextcloud/server · GitHub
convmv -f utf-8 -t utf-8 -r --notest --nfc <nextcloud-data-folder>
Use a test folder.
Echt so :smiley:!
Thats the strange part. My data is already utf-8 and convmv did not help unfortunately…
Ok i can send you two commands for converting file content (not file name).
locale is on this linux system utf-8 but my editor (vim) destroys it for windows systems.
Perhaps file names work similar bad with correct utf-8.
utf-8 to windows
iconv -f UTF-8 -t WINDOWS-1252 $1 > $2
windows to utf-8
iconv -f ISO-8859-1 -t UTF-8 $1 > $2
Dear Community,
I have the same problem. Everything has worked fine so far. The files are stored via Nextcloud in the data directory with german umlauts (äöü). I can edit and access everything properly. Only the command occ files:scan brings the error message “will not be accessible due to incompatible encoding”. The filesystem is utf8 and the database as well:
[client]
default-character-set = utf8mb4
[mysqld]
character-set-server = utf8mb4
collation-server = utf8mb4_general_ci
transaction_isolation = READ-COMMITTED
binlog_format = ROW
innodb_large_prefix=on
innodb_file_format=barracuda
innodb_file_per_table=1
the php-ini:
default_charset = "UTF-8
I use a vserver under ubuntu 16.04 lts with php 7.3 and apache.
I don’t know what to do. But I need the scan. I have imported a backup of data and wanted to scan the files.
I have executed the following commands. Unfortunately without positive result:
php occ files:scan --all
Thank you very much
Christian
Hi Christian,
I have the same problem here and I digged a bit deeper. Just as an example, I took a file with the name “Hände.doc” (storage backend is a Windows machine)
on the Linux side (were NC is running) I did:
strace ls H*.doc
stat("Ha\314\210nde.doc", {st_mode=S_IFREG|0770, st_size=75340, ...}) = 0
Here I can clearly see the raw encoding: “H” + “a”, followed by 0xCC88 (U+0308, COMBINING DIAERESIS) .
=> I conclude that the OS / filesystem is clearly using UTF-8 already. This explains why all attempts to “convert” the file names to UTF-8 have no effect. So it looks like a bug in the application to me.
I guess it is the code in ‘Scan.php’ which does a simple compare of the original path with the “normalized” path. Maybe this causes the trouble, because the character “‘ä’” could also be encoded directly, as 0xC3A4 ? (just a guess)
BTW: I also get tons of similar messages from other files with foreign encoding, for example with greek, chinese or spanish characters…
Do I see this right that all this is only a “warning”, which has no other consequences?
regards,
Thomas
I have the same problem: I ran occ files:scan and the file “Sven Väth_Essential Mix.mp3” will not be accessible due to incompatible encoding as well as all many other files having ä, ö, å or any other non-ASCII letters in the file name.
The file is neither visible in the web interface nor is it synced via the nextcloud client.
So no, this is NOT just a warning.
BUT weirdly enough most files with non-ASCII letter are accepted. I’ll try the strace method proposed by @dg6nee and report back.
Okay, I found two comparable files:
The first has incompatible encoding according to the readout.
Entry "/Elias Doré/Elias Doré @ Rebellion der Träumer, 07.05.16_263237326 - Elias Doré.mp3" will not be accessible due to incompatible encoding
strace shows
lstat64("Elias Dore\314\201 @ Rebellion der Tra\314\210umer, 07.05.16_263237326 - Elias Dor\303\251.mp3", {st_mode=S_IFREG|0777, st_size=178917458, ...}) = 0
But this one throws no error:
File /Elias Doré/Bucht der Träumer 2019 - Atlantis, Friday Night_668487995 - Elias Doré.mp3
lstat64("Bucht der Tr\303\244umer 2019 - Atlantis, Friday Night_668487995 - Elias Dor\303\251.mp3", {st_mode=S_IFREG|0777, st_size=169984834, ...}) = 0
Can anyone read this fluently? I have very little experience with weird encoding errors.
I use rsync to backup my lightroom classic photos from my mac to nextcloud and make them accessible. So I can’t run the convmv command unless I want to run it every time I sync my files. The answer for me is in that great github link you shared:
Can you try doing the encoding conversion while copying (rsync -a --iconv=utf-8-mac,utf-8 ...)
However, my mac has an older version of rsync that does not support iconv. I will have to upgrade rsync according to internet searches. Before I try this, has anyone else had success with this rsync command?
For now, I am going to stick with renaming my files in lightroom to remove the umlauts. There are not so many of them.
Hi all, got the same problem and found the solution on GIT nextcloud
(filescan retrun "entry will not be accessible due to incompatible encoding" · Issue #3136 · nextcloud/server · GitHub)
Just installed convmv and run:
After this a simple reindex helped me to see my data in Nextcloud:
Thanks!!! This (@fjunillon solution above) solved my issue too. Just to add, I also added --replace to the convmv command because some of the files were duplicate with the correct encoding and convmv failed to do anything with these. After adding --replace there were no longer any “incompatible encoding” files left in the directory and the files:scan completed successfully.
Hi this worked for me. I had files with space and ä ü and so on. But now ist honky doory. Thanks
Solved my headaches. Thanks a lot!
