Whiteboard consuming cpu-load without any todo
    • 32.0.6
    • Ubuntu 24.04
    • apache 2.4.66
    • traefik 3.6.7
    • nextcloud aio
    • no
    • some weeks ago
    • aio
    • no
since some weeks i see in my container monitoring that the whiteboard container of my nextcloud aio installation always consumes 40% cpu-utilization. Beside also redis is consuming 10-20% cpu-utilization. If i stop the whiteboard also the redis utilization goes down. Sometimes restarting the whole aio-stack or only the whiteboard container solves the problem - today it doesn’t.
Nextcloud App API is not enabled in aio-stack.
  1. stopping aio stack
  2. enabling whiteboard
  3. starting aio stack
nothing helpfull
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.***REMOVED SENSITIVE VALUE***",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "32.0.6.1",
        "overwrite.cli.url": "https:\/\/nextcloud.***REMOVED SENSITIVE VALUE***\/",
        "dbport": "",
        "loglevel": "2",
        "log_type": "file",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "trashbin_retention_obligation": "auto, 60",
        "versions_retention_obligation": "auto, 365",
        "default_phone_region": "DE",
        "activity_expire_days": "60",
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "mail_smtpauth": 1,
        "mail_sendmailmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_smtpport": "465",
        "appsallowlist": false,
        "data-fingerprint": "74055550e28e3e3ee1464b0f76c8851a",
        "memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-amd64",
        "memories.gis_type": 2,
        "memories.vod.disable": false,
        "updatechecker": false,
        "DOMAIN": "nextcloud.***REMOVED SENSITIVE VALUE***",
        "AIO_VERSION": "v12.7.0"
  • activity: 5.0.0
  • admin_audit: 1.22.0
  • bruteforcesettings: 5.0.0
  • calendar: 6.2.0
  • camerarawpreviews: 0.8.8
  • circles: 32.0.0
  • comments: 1.22.0
  • contacts: 8.3.3
  • contactsinteraction: 1.13.1
  • cospend: 3.2.0
  • dashboard: 7.12.0
  • dav: 1.34.2
  • federation: 1.22.0
  • files: 2.4.0
  • files_external: 1.24.1
  • files_pdfviewer: 5.0.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • logreader: 5.0.0
  • mail: 5.7.0
  • memories: 7.8.2
  • nextcloud-aio: 0.8.0
  • nextcloud_announcements: 4.0.0
  • notifications: 5.0.0
  • notify_push: 1.3.0
  • oauth2: 1.20.0
  • password_policy: 4.0.0
  • photos: 5.0.0
  • previewgenerator: 5.12.1
  • privacy: 4.0.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • recognize: 10.0.7
  • recommendations: 5.0.0
  • related_resources: 3.0.0
  • richdocuments: 9.0.2
  • serverinfo: 4.0.0
  • settings: 1.15.1
  • spreed: 22.0.9
  • support: 4.0.0
  • survey_client: 4.0.0
  • suspicious_login: 10.0.0
  • systemtags: 1.22.0
  • theming: 2.7.0
  • twofactor_nextcloud_notification: 6.0.0
  • twofactor_totp: 14.0.0
  • twofactor_webauthn: 2.4.1
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0
  • weather_status: 1.12.0
  • webhook_listeners: 1.3.0
  • whiteboard: 1.5.6
  • workflowengine: 2.14.0
  • app_api: 32.0.0 (installed 4.0.5)
  • deck: 1.16.3 (installed 1.16.3)
  • encryption: 2.20.0 (installed 2.8.1)
  • facerecognition: 0.9.70 (installed 0.9.70)
  • files_rightclick: 0.15.1 (installed 1.6.0)
  • firstrunwizard: 5.0.0 (installed 2.9.0)
  • notes: 4.13.0 (installed 4.13.0)
  • sharebymail: 1.22.0 (installed 1.10.0)
  • tasks: 0.17.1 (installed 0.17.1)
  • text: 6.0.1 (installed 3.6.0)
  • user_ldap: 1.23.0
Hi, this should be reported to https://github.com/nextcloud/whiteboard/issues if not already done
issue created:
