White Page right after Setup
Right after the Page where i Put in details about admin User and Database. - i just get a blank white page. (with no content (checked sourcecode))
When i relead the page, i start over again with the Setup. - and if i try to create the same admin user again it tells me it exists already.
I checked the database - the user(s) are there. I checked config.php - the information gets written. - it looks to me that it just cannot “finish up” the installation.
  • i tried also with everything on 777 same result…
I downloaded the installation with the web-installer - so permissions and dependencies should be alright.
in apache logs i found
[access_compat:error] [pid 7311:tid 47075414812416] [client ***:46548] AH01797: client denied by server configuration: /home/***/public_html/nextcloud/data/htaccesstest.txt
Wow, i also just tried to Setup Nextcloud just with SQlite - same behaviour…
It seems, that you did install Nextcloud in the folder /home/< username >.
Since the webserver is running with limited access permissions, it may not access the /home/< username > folder.
Same behavior with NC 22…
Thanks.
This user seems to be the standard Webserver User on this server.
Also the home/uname/public_html is the standardpath of Apache. (this stuff all seems to be managed by cpanel)
And if i set the entire nextcloud Folder to 777 - everything and everyone should be able to access it no?
The installation guide might help you with the permissions, specially with owner and group name.
https://docs.nextcloud.com/server/latest/admin_manual/installation/system_requirements.html
You also should check the config/config.php in the Nextcloud program folder and the nextcloud.log in the Nextcloud data folder.
nextcloud.log says
{"reqId":"YcRRG4TS-HnuxI3pNa-dgwAAAAQ","level":2,"time":"2021-12-23T10:36:11+00:00","remoteAddr":"****","user":"--","app":"no app in context","method":"POST","url":"/4/index.php","message":"Could not detect any host in https:///4/data/htaccesstest.txt","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Firefox/78.0","version":""}
hmm
Either during installation a hostname/domain had been entered as an empty string or the Apache configuration needs some more settings.
You should post your configuration to get a better view to the problem.
here is the config of my last attempt
  'instanceid' => '*****',
  'passwordsalt' => '*****',
  'secret' => '*****',
    0 => '*****',
  'datadirectory' => '/home/*****/public_html/nextcloud/4/data',
  'version' => '22.2.3.0',
  'overwrite.cli.url' => 'http://*****/4',
  'dbname' => '*****',
  'dbhost' => 'localhost',
  'dbuser' => '*****',
  'dbpassword' => '*****',
What did you replace with the asterisk - an IP-address or an URI?
It is recommended to set both in the array:
    0 => 'myhost.domain.tld',
    1 => 'x.x.x.x',
where “x.x.x.x” will be replaced by the IP-address of your Nextcloud server.
So you will be able to call your Nextcloud by IP-address or URI.
Additional:
What hardware-platform is running?
What operating system and version?
What php-version?
What database is running now and version?
How is what web-server software configured?
Did you install all PHP modules as described in the installation guide - see link below?
Did you do all configurations as described in the installation guide - see link below?
https://docs.nextcloud.com/server/latest/admin_manual/installation/source_installation.html
Hey thanks a lot, for pointing to the reccources and questions.
Unfortunatly the system would have to be up by yesterday and i couldnt make it, and il be away for some days now.
I still try to answers questions i know without much diggging: And maybe i investigate futher in some weeks:
  1. It was the URL, i know how the error looks like if it missmatches - i still can try to add the ip as well. (i also access it through the URL)
  2. Its php 7.3 latest
  3. CentOS 7.9 on KVM
  4. MariaDB 10.2.41
  5. I have no idea how exactly the apacheConfig works - i think its done by thirdparty tools (WHM, Cpanel) which i habe limited/no Access to, its not my server other stuff is running there, as i understand there is no proper backup and i dont want to break things…
thank you so much for you help so far!
